Thank you. Just to clarify, I knew it was 1 bus, I thought you meant 1 device on the single i2c bus. I think i'm clear now that there is a single i2c bus (good) that can handle multiple (uniquely addressed) devices.
Regarding hx711 and the "B" channel, I tried it and it did not work. Provided similar values on the A (128 resolution) and B (64 bit resolution) so i'm going back to dual esp 8266s with 1 hx711 on each one. Oh well
Thanks again for your help.
HX711 weight sensor and conversion to gram
Re: HX711 weight sensor and conversion to gram
So simply said. No i2c devices AND the hx711?
That is a bummer, but will find another solution!
Please open a issue on GitHub.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 99 guests
