Is it possible to us adafruit io mqtt with espeasy ?
Thanks Nikki
adafruit io mqtt ?
Re: adafruit io mqtt ?
Yes it is possible i just got this working myself!
You need to use the OpenHab MQTT protocol and edit the publish template and subscribe templates.
CONFIG PAGE
Protocol: OpenHAB MQTT
Locate Controller: Use Hostname
Controller hostname: io.adafruit.com
controller port: 1883
controller User: <adafruit username>
controller password: <adafruit AIO Key>
Devices
Edit the device
Note down the "Value Name" settings
TOOLS > ADVANCED PAGE
Subscribe Template:
<adafruit username>/feeds/#
Publish Template:
<adafruit username>/feeds/%sysname%%valname%
For me i have a DHT22 (reads both temperature and humidity) so in the device settings value 1 name = temp, and value 2 name = hum
So this creates two feeds, one for temp and one for humidity
And my sensor name is "sensor01"
So for me...
<adafruit username>/feeds/sensor01hum
<adafruit username>/feeds/sensor01temp
The bit after the feeds/... needs to be matched in adafruit.io
So in my example you need a feeds called "sensor01hum" and "sensor01temp"
Note: you could also use the name you have given to the device in the feed name.
%tskname%
<adafruit username>/feeds/%sysname%%tskname%valname%
could look like this...
<adafruit username>/feeds/sensor01dhttemp
CONFIG PAGE
Devices
Edit the device
Subscribe Template:
Publish Template:
So for me...
%tskname%
Hello, Thanks for your help. it was very interesting.
i was created dongle switch on io.adafruit, but and all the feeds works great! but i cant turn on/off the sonoff relay from adafruit website. (Locally from the switch:Yes)
have you any sollution for that?
Regards.
Regards.
Users browsing this forum: Bing [Bot] and 88 guests
