hi friends
i want remove my espeasy from old modem and add this to new modem, what am i do ? this is not any setting for this ? also i upload again firmware but can not....
please help thank you
how remove esp from old modem and add to new modem? please help
Re: how remove esp from old modem and add to new modem? please help
When the old modem (WiFi access point) cannot be found, it will switch into 'access point mode' which will be called "ESP_easy_0" or something like that.
Then you connect to it via your phone with default password: configesp
Then you should be able to connect the module to another access point.
can you connect the ESP module via usb/serial to a computer?
Then you can reach it through serial monitor to change settings:
>wifissid ***yourwifiaAPname***
Ok
WD : Uptime 9 ConnectFailures 0 FreeMem 17816
>Wifikey ****yourwifikey****
Ok
>wificonnect
WIFI : Connecting... 1
(should display connected)
>save
FILE : File saved
Users browsing this forum: No registered users and 46 guests
