SendToHTTP not working
sentinel
Re: SendToHTTP not working
#41 Post by sentinel » 18 Mar 2018, 13:28
sentinel
#42 Post by sentinel » 25 Mar 2018, 17:49
Should we add a note in wiki in the plugin development page to indicate that plugins should not by default return success = true (if the plugin didn't do anything), since Rules, Timers and other plugins will be affected?
#43 Post by TD-er » 25 Mar 2018, 20:22
sentinel wrote: 25 Mar 2018, 17:49 Should we add a note in wiki in the plugin development page to indicate that plugins should not by default return success = true (if the plugin didn't do anything), since Rules, Timers and other plugins will be affected?
I totally agree such important things should be documented.
And maybe we should just add some kind of template file for plugin/controller in the sourcecode, describing what should be where.
This may be comment code, but it should turn up when searching for some keywords in the source.
sentinel
#44 Post by sentinel » 27 Mar 2018, 17:14
This is a very good idea.
I made an attempt to create a plugin template file (which needs a lot of description added). I have gone through the bugs and wiki and created a list of hints I thought are good to know when developing a plugin. I have also added a few bugs which I think provide good information, but I can't summarise it :?
Does that help?
_Pxxx_PluginTemplate_hints.zip
(3.75 KiB) Downloaded 397 times
updated 28/3/18: added one more hint
#45 Post by TD-er » 30 Mar 2018, 19:03
sentinel wrote: 27 Mar 2018, 17:14
Does that help?
Can you add a Github issue for this?
On the forum, good ideas tend to get lost.
sentinel
#46 Post by sentinel » 30 Mar 2018, 21:33
here is is: #1211 Plugin template file and hints on writing new plugins
#47 Post by TD-er » 31 Mar 2018, 01:54
esp8266
#48 Post by esp8266 » 27 Sep 2018, 18:18
Hello, all
first I want to thank the developers and everyone involved for this wonderful product - ESP Easy
with all due respect, the ESP Easy wiki lacks real, living examples, only syntax.
well, my hard:
1. esp8266 nodemcu, bme280 mega-20180822 (192.168.0.6)
2. esp8266 nodemcu, tm1637 mega-20180822 (192.168.0.7)
my task: to simplify (without mosquito and the like) transfer the temperature value from unit1 to the display of tm1637 unit2
my settings look at the attached screenshots
please correct the settings of the rules
Thank you
(I apologize for me the bad english)
The attachment ESPEASY_1.jpg is no longer available
esp8266
#49 Post by esp8266 » 27 Sep 2018, 18:22
2 attachment
#50 Post by grovkillen » 27 Sep 2018, 18:32
We are very much aware that the wiki is lacking in every aspect. We're working on a new GUI and integrated wiki which will be easier to maintain.
sentinel
#51 Post by sentinel » 02 Oct 2018, 18:38
you can try the following:
Add the following Rule on unit#1 (which has the BME280 sensor):
on sendData do
  SendToHTTP 192.168.0.7,80,/control?cmd=7dt,[bme280#temp]
And add the following Rules on unit#2 (which has the display):
on WiFi#Connected do
  sendToHTTP 192.168.0.6,80,/control?cmd=event,sendData
  timerSet,1,2
on Rules#Timer=1 do
  sendToHTTP 192.168.0/6,80,/control?cmd=event,sendData
  timerSet,1,2
So my idea is:
Unit#2
- when unit#2 connects to the wifi, it sends a request to unit#1 to execute "sendData". It also starts a timer
- when the timer expires, it sends a request to unit#1 to execute "sendData". It also re-starts the timer
Unit#1
- contains simply sendData, which will call 7dt and send the temperature to unit#1 using sendToHTTP
esp8266
#52 Post by esp8266 » 03 Oct 2018, 21:27
sentinel
it works ! :D
thank you very much for your help
sentinel
#53 Post by sentinel » 04 Oct 2018, 18:05
you are welcome :D
Users browsing this forum: Ahrefs [Bot] and 12 guests
