SendToHTTP not working
Re: SendToHTTP not working
I cannot understand that SendToHTTP would ever work on the same unit as the receiver. Why? Because the ESP8266 is a single threaded unit and during the time the unit is sending the HTTP request it is occupied doing that and are not able to respond to any HTTP requests. The internal rules are different since it will write to memory and in later loops the unit will read this from memory, thus you can make commands trigger internally.
So first of, stop experimenting with the command on the same unit that you want to test. Second I'd try to only use a computer to send these requests. If this is working as intended I'd start testing sending from another ESP unit. If this is not working we might have a bug on our hands.
Thanks for the explanation and suggestions. I'll be away on a trip for 2 weeks. I'll try them out when I get back.
Do you know how could I somehow trace the http request message?
I personally use Fiddler but Wireshark is also possible. Maybe even try Postman which I use for testing HTTP based API.
Hi guys,
took me a while to reply. I think I found the problem. Let me give you some more information about my configuration:
module-1: wemos d1 mini pro, running build 120
module-2: wemos d1 mini pro, running a custom build: ESPEasy-v2.0.0-dev12+P073.rar, which I found here: Connecting a TM1637 4-Digit Display
The idea is: module-1 has an LCD display. Module-2 has a 7-segment display (supported by the custom build) and a ds18b20 sensor. Module-2 displays the temperature on the 7-segment display and also sends it using http to module-1.
Module-1 displays the temperature received.
Now, it seems there is a problem with sendToHTTP with the custom build. SendToHTTP works from module-1 to module-2, but not the other way around.
Do you have any ideas? Or how to further troubleshoot?
Try the official (mega) build. The plugin is part of it now.
https://www.letscontrolit.com/wiki/inde ... nt_display
thanks for the reply. I tried with this: ESPEasy_mega-20180209
but it still doesn't work.
And one more thing: When my Rules contain "on Clock#Time do" (to trigger sendToHTTP), I can see "ACT : SendToHTTP..." in the log. But when my Rules contain a timer, I don't see the timer expiring in the log (and the log entry about SendToHTTP). As if the timer never expires.
Just so I understand. The time with timer is executed but the log is not populated?sentinel wrote: ↑11 Feb 2018, 16:11 thanks for the reply. I tried with this: ESPEasy_mega-20180209
There's nothing in the log. I don't know if the time is executed, because all I had was the SendToHTTP. Or did I not understand your question?
Yes, I wanted to know if the problem was that the rule never triggered or if it "only", was the missing information in log. I guess you don't know?
no, I don't know, since what the rule contains is SendToHTTP, which also doesn't work.
I think the rule is never triggered. I started 2 timers: When timer-1 expires, I switch the on-board LED on. When timer-2 expires, I switch it off. Nothing happens.
You mind sharing screen shots?
here is a screenshot of my rules. Do you need another tab?
- rules tab
- rules.png (51.08 KiB) Viewed 49196 times
Okay, that explains it. You cannot use timers like that. They will start tugging for that poor gpio 2. You need to do it like this.
You need to do this in order to know that they will trigger in sequence.
On System#Boot Do
TimerSet,1, 5
EndOn
On Rules#Timer=1 Do
Gpio,2,1
TimerSet,2,10
EndOn
On Rules#Timer=2 Do
Gpio,2,0
TimerSet,1,5
EndOn
This also doesn't work. My Rules are:
Take a look at the log:
I think the timer starts but never expires?
I have also tried my code (the one in my screenshot) in a module running build 120 and it works ok.
On System#Boot Do
TimerSet,1, 2
EndOn
On Rules#Timer=1 Do
Gpio,2,1
TimerSet,2,4
EndOn
//on Clock#Time do
// SendToHTTP 192.168.1.9,80,/control?cmd=lcd,1,1,--%systime%--
//endon
On Rules#Timer=2 Do
Gpio,2,0
TimerSet,1,2
EndOn
5390 : EVENT: System#Boot
5395 : ACT : TimerSet,1, 2
5426 : EVENT: Processing time:36 milliSeconds
5427 : WD : Uptime 0 ConnectFailures 0 FreeMem 18832
5442 : EVENT: Clock#Time=Sun,21:50
5474 : EVENT: Processing time:32 milliSeconds
32470 : EVENT: Clock#Time=Sun,21:51
32498 : EVENT: Processing time:28 milliSeconds
35426 : WD : Uptime 1 ConnectFailures 0 FreeMem 18688
65426 : WD : Uptime 1 ConnectFailures 0 FreeMem 18688
92724 : EVENT: Clock#Time=Sun,21:52
92751 : EVENT: Processing time:27 milliSeconds
95426 : WD : Uptime 2 ConnectFailures 0 FreeMem 18688
125426 : WD : Uptime 2 ConnectFailures 0 FreeMem 18688
152837 : EVENT: Clock#Time=Sun,21:53
152864 : EVENT: Processing time:27 milliSeconds
155426 : WD : Uptime 3 ConnectFailures 0 FreeMem 18688
185426 : WD : Uptime 3 ConnectFailures 0 FreeMem 18688
213269 : EVENT: Clock#Time=Sun,21:54
213296 : EVENT: Processing time:27 milliSeconds
Don't use spaces here:
Instead use:
TimerSet,1, 2
TimerSet,1,2
Yes, my phone added those spaces. Sorry!TD-er wrote: ↑11 Feb 2018, 21:27 Don't use spaces here:Instead use:Code: Select all
TimerSet,1, 2
TimerSet,1,2
thanks guys. I tried it without space but it also doesn't work
After the module boots, I can see the following in the log:
5449 : ACT : timerSet,1,2
but there is no other similar log entry. And of course no led blinking
Please try another esp board if possible.
ok, I flashed my other module with this binary: ESP_Easy_mega-20180209_test_ESP8266_1024.
The timers start and expire correctly, led flashes. I also added a SendToHTTP command when a timer expires. It also works! I am sending the http request to my laptop. I have apache and run wireshark so I see that the request from wemos is fine. I'll test sending it to the other module with the display (I need to do some re-wiring). But it should also work.
I'll erase the flash and re-flash the other module. What can be the problem?
Corrupted flash maybe. Hard to tell.
I think the problem is with the TM1637 plugin:
When I disable the plugin and reboot the device, both the timers and SendToHTTP work. When I enable it, both stop working. This happens with both my modules.
What version are you running?
I am running: mega-20180209 (ESP_Easy_mega-20180209_test_ESP8266_1024.bin)
I have also tried the following rules:
and the behaviour is the same: when the plugin is not enabled, both SendToHTTPs work. When it is enabled they don't work.
Just to clarify: when I say "plugin enabled" I mean that I have configured the display and then I enable/disable it using the tick-box.
On System#Boot Do
SendToHTTP 192.168.1.2,80,/control?cmd=lcd,1,1,booting
EndOn
On Clock#Time Do
SendToHTTP 192.168.1.2,80,/control?cmd=lcd,2,2,--%systime%--
EndOn
did you reproduce it?
I'm trying to find out what goes wrong when the 7-segment is enabled. I'm slow
I can see that after I enable the device, when the code reaches the point to check if there are any timers active, it finds no timer active.
There has been a proposed fix for these displays.
It was just merged, so perhaps check tomorrow's build?
no, unfortunately the problem still exists. I tried with ESPEasy_mega-20180305.zip
Still broken for me on ESPEasy_mega-20180315.zip
Could you add an issue on Github about this, describing as much as you can.
I'm loosing track of where to gather information on issues/bugs here on the forum and although the issue list on Github isn't perfect either, it is at least a bit more contained than the forum here.
Should we add a note in wiki in the plugin development page to indicate that plugins should not by default return success = true (if the plugin didn't do anything), since Rules, Timers and other plugins will be affected?
I totally agree such important things should be documented.
And maybe we should just add some kind of template file for plugin/controller in the sourcecode, describing what should be where.
This may be comment code, but it should turn up when searching for some keywords in the source.
This is a very good idea.And maybe we should just add some kind of template file for plugin/controller in the sourcecode, describing what should be where.
I made an attempt to create a plugin template file (which needs a lot of description added). I have gone through the bugs and wiki and created a list of hints I thought are good to know when developing a plugin. I have also added a few bugs which I think provide good information, but I can't summarise it
Does that help?
updated 28/3/18: added one more hint
Can you add a Github issue for this?sentinel wrote: ↑27 Mar 2018, 17:14This is a very good idea.And maybe we should just add some kind of template file for plugin/controller in the sourcecode, describing what should be where.
Does that help?
_Pxxx_PluginTemplate_hints.zip
On the forum, good ideas tend to get lost.
here is is: #1211 Plugin template file and hints on writing new pluginsCan you add a Github issue for this?
Hello, all
first I want to thank the developers and everyone involved for this wonderful product - ESP Easy
with all due respect, the ESP Easy wiki lacks real, living examples, only syntax.
well, my hard:
1. esp8266 nodemcu, bme280 mega-20180822 (192.168.0.6)
2. esp8266 nodemcu, tm1637 mega-20180822 (192.168.0.7)
my task: to simplify (without mosquito and the like) transfer the temperature value from unit1 to the display of tm1637 unit2
my settings look at the attached screenshots
please correct the settings of the rules
Thank you
(I apologize for me the bad english)
well, my hard:
Thank you
We are very much aware that the wiki is lacking in every aspect. We're working on a new GUI and integrated wiki which will be easier to maintain.
you can try the following:
Add the following Rule on unit#1 (which has the BME280 sensor):
And add the following Rules on unit#2 (which has the display):
So my idea is:
Unit#2
- when unit#2 connects to the wifi, it sends a request to unit#1 to execute "sendData". It also starts a timer
- when the timer expires, it sends a request to unit#1 to execute "sendData". It also re-starts the timer
Unit#1
- contains simply sendData, which will call 7dt and send the temperature to unit#1 using sendToHTTP
on sendData do
SendToHTTP 192.168.0.7,80,/control?cmd=7dt,[bme280#temp]
on WiFi#Connected do
sendToHTTP 192.168.0.6,80,/control?cmd=event,sendData
timerSet,1,2
on Rules#Timer=1 do
sendToHTTP 192.168.0/6,80,/control?cmd=event,sendData
timerSet,1,2
Unit#2
Unit#1
sentinel
it works !
thank you very much for your help
it works !
you are welcome
Users browsing this forum: No registered users and 58 guests
