ESP Easy Flasher
Re: ESP Easy Flasher
I have now released the first beta (0.01.000) https://github.com/Grovkillen/ESP_Easy_Flasher/releases
This version supports spaces in SSID and removes special characters in Unit Name. I hope it'll be of use
hi
can it be used to flash other firmwares, too? I actually use the flasher included in every espeasy 2.0 release package, with no issues, so i think yes... the wifi credential setting is a standard, or it changes from one board/firmware to an other? If it's usable, i could pass credentials to tasmota and espurna, too, which would be nice... i have to try, of course it's not what your tool is intended for... i remember once when changing from one firmware to an other, the latter was already connected to my wifi without me doing anything... thanks in advance
Flashing the ESP with whatever bin file is not a problem. Pushing the credentials will probably not work since the commands that ESP Easy use is not likely the same as other firmware use.
nice program. It works great with esp8285.
It would be greater if you could add the config file after flashing.
I will consider that. Thanks for the feedback
I have just updated the flasher (0.02.000) which fixed a bug if you had high density screens. With new Patreon supporters we're getting closer to the point of doing this full time. Thanks to those of you who support us!
https://github.com/Grovkillen/ESP_Easy_ ... g/0.02.000
- martin8310
Hello everyone,
I am enthusiastic about the espeasy project and would like to give feedback on the esp easy flasher.
I have also the font issue (letters are too big) and therefore not readable.
My Sytem is Windows 10 64bit with the ESP Easy Flasher in Version 0.02.004.Screen Resolution 2560x1600
will there be a working version?
Thank you in advance.
regards martin
regards martin
Did you drag and drop the font file?
- martin8310
Unfortunately not. Thanks for the tip, the problem is solved. It's just a bit too complicated Now I understand why all the windows are always open.
Thank you.
Thank you.
I put the info in the message box
loving this tool.
MAybe an enhancement request.
for fixed ip, I would recommend to be aple to set all IP datails.
Gateway
Subnetmask
Does this make sence?
Can this be added?
Thanks Thomas
loving this tool.
Gateway
Subnetmask
Can this be added?
Thanks Thomas
I could make it optional yes.
@grovkillen, thank you for creating this flashing tool. I started using it this week and appreciate its user interface.
Today I noticed that it has a file name length problem. For example, this file is ignore (not shown in the drop down):
ESP_Easy_mega-20181207_normal_core_241_ESP8266_1024.bin
The workaround is to rename it so it is shorter. For example, this works:
ESP_Easy_mega-20181207_normal_241_ESP8266_1024.bin
BTW, my PC is WIN10 Pro 64 bit, build 16299.
I will make the window wider. Release Monday.
By the way. Latest release allows for custom serial commands using an external txt file.
@riker1 you can add your special subnet and gateway in this file. They will be added after the standard commands so you will see the "wrong" subnet and gateway first but these will be overrun by the custom commands right before the save is made.
how do I flash Espeasy on new esp32 (Wroom32)?
Giobbe
Giobbe
ESP32 is not yet supported by the flasher. Sorry! It's on the road map though.
ok, thanks will checkgrovkillen wrote: ↑08 Dec 2018, 11:52 By the way. Latest release allows for custom serial commands using an external txt file.
Higrovkillen wrote: ↑08 Dec 2018, 11:52 By the way. Latest release allows for custom serial commands using an external txt file.
wanted to test this,
how do I have to name the gateway and subnet in settings file?
Fixed IP=True
IP1=192
IP2=168
IP3=3
IP4=9
gateway=192.168.0.1
subnet=255.255.0.0
The checkbox is disabled for this action.....how to enable it?
Thanks Thomas
Save the commands in a file called "SerialCommands.txt" in the settings folder.
Commands are syntaxed just as any serial commands.
gateway,192.168.0.1
subnet,255.255.0.0
ok, but how to enable the checkbox?
to use serialcommands?
If it's there [the file] it will be enabled upon start of app or rescan (button for rescanning COM ports).
strange, not working for me.
see hardcopy
file in settings/SerialCommands.txt exists
refreshed often, and restarted
default is stored in settings folder.
But still disabled ?
Thanks for checking Thomas
see hardcopy
...ups solved..
user error.
strangewise the extention ini was not shown and file was
serialcommand.txt.ini
now having the file without ini it is working.
Sorry
Thomas
user error.
Sorry
Thomas
Ah! Great!
New version is delivered with today's release.
Version mega 20181216; Just a minor in convenience, as I normally set the scree to 125% (win7) to make it eaisier for my eyes; I am missing the bottom part of the flasher gui, does not seems to able to scale or resize, so I cant click flash.
However if I change display size back to 100% it is ok.
Thansk,
kEN
Thansk,
kEN
ALT+S will save current settings to the Settings/Default.ini change the "pixels per inch" value and the zoom will work better. Save and restart the app.kenkoknz wrote: ↑17 Dec 2018, 09:22 Hi,
Thansk,
kEN
I have a questions
How do I set IP
via Serial commands?
Thanks Thomas
do I just enter those command in console? putty?
Name ESP01S
Unit 202
ip xx.xx.xx.xx
WifiSSID ssid
etc?
I found it: just have to enter the commands in arduino serial command line.
I have a questions
How do I set IP
Thanks Thomas
Name ESP01S
Unit 202
ip xx.xx.xx.xx
WifiSSID ssid
etc?
You can add custom Commands using the serialcommands.txt way.
thanks
where do I find a list of available serial commands?
thanks Thomas
thanks Thomas
Not 100% complete list but here is the official commands:
https://espeasy.readthedocs.io/en/lates ... mmand.html
If you're missing something, give me a ping here.
another question.
how can I set ip to dhcp via serial?
Thanks T
Thanks T
Set all DNS, gateway and IP to "0.0.0.0"
... hello again from Germany,
after a OS-crash last week I have installed the OS from scratch. Today now I download the Installer but have some Problems with it:
1. Fonts
I install the two fonts to the Windows folder more then twice but nothing helps. The Flasher show the right Font (I believe) but always open the both windows again telling me they can't find the Fonts.
2. GUI resolution
Have anybody try the Flasher on UHD? That is not realy funny if you need a Microscope to handle the Flasher (see Picture)
EDIT: ... and I can't open any firmware- File. Explorer opens but I can't chose one ...
1. Fonts
2. GUI resolution
- The Flasher-GUI
- Clipboard01.jpg (26.52 KiB) Viewed 39526 times
- The whole desktop, UHD resolution
- Clipboard01.jpg (114.47 KiB) Viewed 39527 times
DLzG
Micha
Micha
Click save or CTRL+S and a settings file will appear in the settings folder. Open that file and change the pixels per inch value to something smaller (and save the file) and then start the flasher again.
... ty ... that works well. I have now set it to 96px and now it's ok.
The remaining problem is that the script folders pop up over and over again, no matter how often you install the fonts. That should be taken out of it completely. Simply put the reference to the fonts to be installed in a ReadMe and it is good
DLzG
Micha
Micha
Yeah, I really need to update the Flasher.... Sorry for inconvenience.
... next problem ...
The Flasher don't find the active COM-port.
I use a flash- adapter ( see picture ) that use a CP10x from Silicon Labs. I also have some USB2SER and USB2I²C and USB21W that also use the same Chip.
The Flasher is known as COM6 but the Flashtool only see COM3 and COM4 as inactive (right). Now I have set the Flasher to COM1 but the same... They don't see them. Only if I overwrite the known COM3 or COM4 the tool see it... Is there an other way to flash ESPeasy to the ESP without using the Flashertool?
BTW:
For me it's not possible to flash with that Flasher... Nice idea, but what good is it if it just does not work?
BTW:
DLzG
Micha
Micha
Ok, easy now. I will try to get time to fix issue with not finding ports. It feels a lot better if I get some love...
... I believe in that... If you do it right then I spend you many hugz
BTW:
Is there a way after flashing to send the data inside "Post flash action" by hand via a terminal (putty or same like this)? I remember that this haven't work often and I never can connect to my wifi...
Or is there a way to connect the ESP via RXTX to a terminal-program to configure it over this way?
BTW:
DLzG
Micha
Micha
If you save a file with the name serialcommands.txt you can add commands in that one and only do a programming.
... ty, but witch vommands I have to send tu set the data for WIFI (i.e. UUID, Password a.s.o.)?
Meanwhile I have connect a terminal to the UART while botting, telling me that the WIFI- Settings are wrong:
INIT : Booting version: mega-20190630 (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
70 : INIT : Free RAM:29352
71 : INIT : Cold Boot - Restart Reason: External System
73 : FS : Mounting...
98 : FS : Mount successful, used 75802 bytes of 957314
451 : CRC : program checksum ...OK
462 : CRC : SecuritySettings CRC ...OK
464 : CRC : binary has changed since last save of Settings
572 : INIT : Free RAM:26504
574 : INIT : I2C
574 : INIT : SPI not enabled
589 : INFO : Plugins: 47 [Normal] (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
591 : WIFI : No valid wifi settings
592 : WIFI : Could not connect to AP!
593 : WIFI : Set WiFi to AP
1514 : WIFI : AP Mode ssid will be ESP_Easy_0 with address 192.168.4.1
2780 : AP Mode: Client connected: C0:C9:76:0D:1C:27 Connected devices: 1
2785 : Webserver: start
2849 : WD : Uptime 0 ConnectFailures 0 FreeMem 17800 WiFiStatus 0
574 : INIT : I2C
DLzG
Micha
Micha
It's all here: https://espeasy.readthedocs.io/en/lates ... mmand.html
I am trying to use the esp_easy_flasher.exe tool but I can't get the application to select a bin file
I click on the "open folder" button, an explorer windows open where I select a file but there is no OK button to accept the file so there is no way for me to enter the bin file in the application
help please
help please
