ESP Easy Flasher
- budman1758
Re: ESP Easy Flasher
I just tried to move the com port to com1 like your example and it now shows a USB/Serial device. Tried to flash a module but nothing happens. ESP Tool window does not come up. Module not flashed.
The ESPTOOL command window is hidden and should not pop up (might need to make a device debug setting which show everything)... I need to fix the issue with unassigned com1. Is the found com port the correct one of you check in the device manager?budman1758 wrote: ↑03 Jan 2018, 20:37 I just tried to move the com port to com1 like your example and it now shows a USB/Serial device. Tried to flash a module but nothing happens. ESP Tool window does not come up. Module not flashed.
- budman1758
Almost every time I insert the USB flasher it comes up as com4 or com5. Using your example I "forced" it to com1. It now shows as a USB Serial device. But it does not flash the module. Zero activity shows on the device. It has two leds for rx and tx. Click the flash button in the app and info window says "Start flashing on com1" but nothing is happening.
Super weird. What does the log file say? (Located in the log folder)budman1758 wrote: ↑03 Jan 2018, 22:01 Almost every time I insert the USB flasher it comes up as com4 or com5. Using your example I "forced" it to com1. It now shows as a USB Serial device. But it does not flash the module. Zero activity shows on the device. It has two leds for rx and tx. Click the flash button in the app and info window says "Start flashing on com1" but nothing is happening.
- budman1758
Now that tells me that something else is causing the problem!
Can you tell me the search way / path that you have your exe in?
- budman1758
C:\Users\Budman\Documents\Arduino Docs\ESPeasy Stuff\Flash Utilities\ESP_Easy_Flasher-master
Made a copy and put it the root of the C drive and getting same behaviour.
Perhaps also try in C:\Users\Budman\Documents\budman1758 wrote: ↑03 Jan 2018, 23:10 C:\Users\Budman\Documents\Arduino Docs\ESPeasy Stuff\Flash Utilities\ESP_Easy_Flasher-master
The root of the C drive may be a permission issue to write there and the other one has a space in the path, which is generally very often an issue with software.
So just to exclude both, try to save in your own documents folder.
Of try to run it as administrator.
- budman1758
Tried it in Documents root. Same behaviour.TD-er wrote: ↑03 Jan 2018, 23:37
I always run it as Admin.
- budman1758
I'm also having the same problems on my Win 7 64 bit machine. Is this a "64 bit" problem?
As a side note. After hitting the x to close the program it is still running in Task Manager. Have to kill the process. This is on Win 7 and NOT on my Win 10 machine. Strangeness abounds......
I will test it further today. Hopefully I can trigger the behavior on another computer. Sir thank you for your time and help!budman1758 wrote: ↑04 Jan 2018, 01:25 I'm also having the same problems on my Win 7 64 bit machine. Is this a "64 bit" problem?
- budman1758
Ain't no thing Bro. Anyway I can help, I'm there.grovkillen wrote: ↑04 Jan 2018, 05:55 I will test it further today. Hopefully I can trigger the behavior on another computer. Sir thank you for your time and help!
I just wish I could help on the programming side. There, me be pretty much useless....
Same here. i do not see any com ports.
I'm really sorry to hear this. I will try to make a version with more debug output. Thank you all for the feedback. I will make this work!
I have now released a new version (not in released folder) but in the main code page. Please download it and test. You need to save a default settings file and change the debug level from 0 to 1. If you don't get that far you can download it from me here (place it in the settings folder).budman1758 wrote: ↑04 Jan 2018, 07:04Ain't no thing Bro. Anyway I can help, I'm there.grovkillen wrote: ↑04 Jan 2018, 05:55 I will test it further today. Hopefully I can trigger the behavior on another computer. Sir thank you for your time and help!
You can upload the DEBUG FILE here: https://dbinbox.com/harkrank
I have started to re-write the com scanner module, I think it will work more generically. Stay tuned.
I have now commited 0.00.014 with the new com scanner module. I hope this will fix a lot of the issues reported here
ONLY usb com ports are being scanned with this new com scanner, I think no one really uses "true" com ports?
Just a rough idea:
If i remember right the Esptool is able to detect the flash type/size and it is able to erase the flash.
Would be a nice expansion to your tool if I'm right
I might add that as well, thanks for the idea. Erase flash is actually something I'd use from time to time. Thanks!
Yesterday I added some info (in a pull request) to display all information of the flash possible.
Adding a "erase all flash" from within ESPeasy is not that hard. (just to erase all settings, not the firmware itself)
I already saw the instructions for it, when browsing the code to determine the flash size, speed, etc.
It now prints in the sysinfo screen:
ESP Chip ID: 1649343
ESP Chip Freq: 80 MHz
Flash Chip ID: Vendor: 0xE0 Device: 0x4016
Flash Chip Real Size: 4096 kB
Flash IDE Size: 4096 kB
Flash IDE speed: 40 MHz
Flash IDE mode: DIO
Please give me feedback if the new com scanner is not working!
- budman1758
OK. Here is whats happening on my Win 10 64bit system. I have 2 USB to serial devices. 1 is a CH340 1 dollar China unit. The other is a genuine FTDI chip unit I got from Adafruit.
No matter what com port I either manually assign or let windows assign the flash program NEVER identifies the FTDI device.
The flash program correctly identifies the CH340 EVERY time with the correct com port.
NEITHER of them work however. I go through the motions to flash a module and the program acts like all is well but nothing happens. Zero activity out of the serial device. Program window says "flashing.. might take a few" but nothing is working. When I press flash button it greys out and stays that way until I exit the program.
Maybe of interest... When I exit the program BEFORE attempting to flash it exits cleanly. If I press flash button and then try to exit the program it ACTS like it exits cleanly but in Windows task manager it is still running. Couple of screenshots of that are in your upload folder.
Always run as admin. There are 2 hidden windows running in the background. Might be helpful if those were visible during testing.
I uploaded some screenshots and log files to your upload location. Log file does not look very helpful. (to me anyway. )
Hope this is helpful. Sorry it took a while to get back on this. Let me know what else I can do to help.
Thank you very much. The debug should show the command windows, I will make that in the next version. The debug log is supposed to be filled with approx 10000+ of code of working properly so we have some issue there it seems. The screenshots of the device manager showing com5, is that the FTDI programmer? Shouldn't the driver state something more specific than "serial..."?
I will upload a new version tomorrow, much appreciated that you take your time. I will get to the bottom of this!
- budman1758
Yes, it is. It does show more detail if you go into the properties a bit deeper. I would have thought the same thing. Kinda generic for a $17 dollar "genuine FTDI".grovkillen wrote: ↑08 Jan 2018, 22:38 The screenshots of the device manager showing com5, is that the FTDI programmer? Shouldn't the driver state something more specific than "serial..."?
Please try latest release ... https://github.com/Grovkillen/ESP_Easy_ ... g/0.00.016budman1758 wrote: ↑08 Jan 2018, 23:19Yes, it is. It does show more detail if you go into the properties a bit deeper. I would have thought the same thing. Kinda generic for a $17 dollar "genuine FTDI".grovkillen wrote: ↑08 Jan 2018, 22:38 The screenshots of the device manager showing com5, is that the FTDI programmer? Shouldn't the driver state something more specific than "serial..."?
- budman1758
OK. Still not finding my FTDI serial port. Correctly finds the CH340 on correct com port. Lots of windows flicker in background.grovkillen wrote: ↑09 Jan 2018, 11:26 Please try latest release ... https://github.com/Grovkillen/ESP_Easy_ ... g/0.00.016
When the app window appears it is still scanning for comports.
When done a command window opens and at the top is says cannot find the specified path.
The command line is focused in the APP_DATA folder of the flash app.
Even when trying with my CH340 device nothing happens.
I uploaded my debug file to your dropbox. It's quite a bit more informative.
Hope this helps.
budman1758 wrote: ↑09 Jan 2018, 20:18OK. Still not finding my FTDI serial port. Correctly finds the CH340 on correct com port. Lots of windows flicker in background.grovkillen wrote: ↑09 Jan 2018, 11:26 Please try latest release ... https://github.com/Grovkillen/ESP_Easy_ ... g/0.00.016
Hope this helps.
Great! I have come to the conclusion that since I now only scan for USB TTL ports the FTDI might not consider itself as such?
(COM4) Silicon Labs CP210x USB to UART Bridge
(COM6) USB-SERIAL CH340
(COM7) USB-SERIAL CH340
(COM8) USB-SERIAL CH340
Those are found with USB but I bet the FTDI specifies itself as good ol serial..? If you go to the device manager and look in the code described in the picture below. What does that say for the FTDI programmer?
Also the date format is messing with my variables since the US "\" between the dates are interpreted as path's (in my code). I will hard code ISO date
Lastly, the APP_DATA folder, what files is inside of it?
(Flickering is me pinging com ports, I will continue ping 10 com ports above the last one scraped from the registry...)
- Skärmklipp.PNG (202.79 KiB) Viewed 125480 times
- budman1758
My device is not the one in your screenshot. It is COM5 also.
The APP_DATA folder contains:
esptool.exe
TimeStamp.vbs
Screenshot of what I believe is similar to yours.
I have hidden devices showing. Those are the ones that are greyed out.
Hope this helps.
esptool.exe
TimeStamp.vbs
Hope this helps.
I have now hopefully squished the last two bugs (the date/time and the FTDI problem)...
https://github.com/Grovkillen/ESP_Easy_ ... g/0.00.017
- budman1758
Methinks you be making great progress dude!! It WORKS!!!grovkillen wrote: ↑09 Jan 2018, 21:35 I have now hopefully squished the last two bugs (the date/time and the FTDI problem)...
Found the correct ports for both of my devices.
Tried to flash a new -01 module and it flashed it fine but the app says it ended with an error. I had it set to post flash options and I think that's where the error might be cause the unit flashed fine. I connected with Putty and set the wifi stuff and its up and running. Here is the log output.
######2018-01-09######
#######0.00.017#######
######FLASH INFO######
BIN file: ESP_Easy_v2.0.0-dev13_test_ESP8266_1024.bin
COM port: (COM5) USB Serial Port
Baud rate: 115200
######POST FLASH######
Unit name: test
Unit number: 26
Admin password:
WiFi SSID 1: xxxxxxxxxx
WiFi password 1: xxxxxxxxxx
WiFi SSID 2:
WiFi password 2:
IP: <DHCP>
######FLASH LOG######
[esptool.exe -vv -cd nodemcu -cb 115200 -cp COM5 -ca 0x00000 -cf "C:\Users\Budman\Documents\Arduino Docs\ESPeasy Stuff\Flash Utilities\ESP_Easy_Flasher-master\BIN\ESP_Easy_v2.0.0-dev13_test_ESP8266_1024.bin"]
[1/9/2018 12:50:04 PM] esptool v0.4.12 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
[1/9/2018 12:50:04 PM] setting board to nodemcu
[1/9/2018 12:50:04 PM] setting baudrate from 115200 to 115200
[1/9/2018 12:50:04 PM] setting port from to COM5
[1/9/2018 12:50:04 PM] setting address from 0x00000000 to 0x00000000
[1/9/2018 12:50:04 PM] espcomm_upload_file
[1/9/2018 12:50:04 PM] espcomm_upload_mem
[1/9/2018 12:50:04 PM] setting serial port timeouts to 1000 ms
[1/9/2018 12:50:04 PM] opening bootloader
[1/9/2018 12:50:04 PM] resetting board
[1/9/2018 12:50:04 PM] trying to connect
[1/9/2018 12:50:04 PM] flush start
[1/9/2018 12:50:04 PM] setting serial port timeouts to 1 ms
[1/9/2018 12:50:04 PM] flush complete
[1/9/2018 12:50:04 PM] espcomm_send_command: sending command header
[1/9/2018 12:50:04 PM] espcomm_send_command: sending command payload
[1/9/2018 12:50:04 PM] espcomm_send_command: receiving 2013 bytes of data
[1/9/2018 12:50:04 PM] read 0, requested 1
[1/9/2018 12:50:04 PM] error: failed reading byte
[1/9/2018 12:50:04 PM] warning: espcomm_send_command: can't receive slip payload data
[1/9/2018 12:50:04 PM] serialport_receive_C0: 72 instead of C0
[1/9/2018 12:50:04 PM] espcomm_send_command: receiving 2 bytes of data
[1/9/2018 12:50:04 PM] Uploading 623136 bytes from C:\Users\Budman\Documents\Arduino Docs\ESPeasy Stuff\Flash Utilities\ESP_Easy_Flasher-master\BIN\ESP_Easy_v2.0.0-dev13_test_ESP8266_1024.bin to flash at 0x00000000
[1/9/2018 12:50:04 PM] erasing flash
[1/9/2018 12:50:04 PM] size: 098220 address: 000000
[1/9/2018 12:50:04 PM] first_sector_index: 0
[1/9/2018 12:50:04 PM] total_sector_count: 153
[1/9/2018 12:50:04 PM] head_sector_count: 16
[1/9/2018 12:50:04 PM] adjusted_sector_count: 137
[1/9/2018 12:50:04 PM] erase_size: 089000
[1/9/2018 12:50:04 PM] setting serial port timeouts to 15000 ms
[1/9/2018 12:50:04 PM] writing flash
[1/9/2018 12:50:13 PM] ................................................................................ [ 13% ]
[1/9/2018 12:50:21 PM] ................................................................................ [ 26% ]
[1/9/2018 12:50:30 PM] ................................................................................ [ 39% ]
[1/9/2018 12:50:39 PM] ................................................................................ [ 52% ]
[1/9/2018 12:50:48 PM] ................................................................................ [ 65% ]
[1/9/2018 12:50:57 PM] ................................................................................ [ 78% ]
[1/9/2018 12:51:06 PM] ................................................................................ [ 91% ]
[1/9/2018 12:51:12 PM] ................................................. [ 100% ]
[1/9/2018 12:51:12 PM] starting app without reboot
[1/9/2018 12:51:12 PM] espcomm_send_command: sending command header
[1/9/2018 12:51:12 PM] espcomm_send_command: sending command payload
[1/9/2018 12:51:12 PM] espcomm_send_command: receiving 2 bytes of data
[1/9/2018 12:51:12 PM] closing bootloader
[1/9/2018 12:51:12 PM] flush start
[1/9/2018 12:51:12 PM] setting serial port timeouts to 1 ms
[1/9/2018 12:51:12 PM] setting serial port timeouts to 1000 ms
[1/9/2018 12:51:12 PM] flush complete
[2018-01-09 12:49:55] STOPPED due to errors! (try reset on the unit, then start a new flash attempt)
Did you run it in debug mode or normal mode?
I think we're close now!! I will make some effort tomorrow. Thanks for your persistent.
Thank you for that log. If possible please download 0.00.019 and test. I changed some code but are not really able to test it since the old code works for me as well.budman1758 wrote: ↑09 Jan 2018, 22:05Methinks you be making great progress dude!! It WORKS!!!grovkillen wrote: ↑09 Jan 2018, 21:35 I have now hopefully squished the last two bugs (the date/time and the FTDI problem)...
######2018-01-09###### #######0.00.017####### ######FLASH INFO###### BIN file: ESP_Easy_v2.0.0-dev13_test_ESP8266_1024.bin COM port: (COM5) USB Serial Port Baud rate: 115200 ######POST FLASH###### Unit name: test Unit number: 26 Admin password: WiFi SSID 1: xxxxxxxxxx WiFi password 1: xxxxxxxxxx WiFi SSID 2: WiFi password 2: IP: <DHCP> ######FLASH LOG###### [esptool.exe -vv -cd nodemcu -cb 115200 -cp COM5 -ca 0x00000 -cf "C:\Users\Budman\Documents\Arduino Docs\ESPeasy Stuff\Flash Utilities\ESP_Easy_Flasher-master\BIN\ESP_Easy_v2.0.0-dev13_test_ESP8266_1024.bin"] [1/9/2018 12:50:04 PM] esptool v0.4.12 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de> [1/9/2018 12:50:04 PM] setting board to nodemcu [1/9/2018 12:50:04 PM] setting baudrate from 115200 to 115200 [1/9/2018 12:50:04 PM] setting port from to COM5 [1/9/2018 12:50:04 PM] setting address from 0x00000000 to 0x00000000 [1/9/2018 12:50:04 PM] espcomm_upload_file [1/9/2018 12:50:04 PM] espcomm_upload_mem [1/9/2018 12:50:04 PM] setting serial port timeouts to 1000 ms [1/9/2018 12:50:04 PM] opening bootloader [1/9/2018 12:50:04 PM] resetting board [1/9/2018 12:50:04 PM] trying to connect [1/9/2018 12:50:04 PM] flush start [1/9/2018 12:50:04 PM] setting serial port timeouts to 1 ms [1/9/2018 12:50:04 PM] setting serial port timeouts to 1000 ms [1/9/2018 12:50:04 PM] flush complete [1/9/2018 12:50:04 PM] espcomm_send_command: sending command header [1/9/2018 12:50:04 PM] espcomm_send_command: sending command payload [1/9/2018 12:50:04 PM] espcomm_send_command: receiving 2013 bytes of data [1/9/2018 12:50:04 PM] read 0, requested 1 [1/9/2018 12:50:04 PM] error: failed reading byte [1/9/2018 12:50:04 PM] warning: espcomm_send_command: can't receive slip payload data [1/9/2018 12:50:04 PM] trying to connect [1/9/2018 12:50:04 PM] flush start [1/9/2018 12:50:04 PM] setting serial port timeouts to 1 ms [1/9/2018 12:50:04 PM] setting serial port timeouts to 1000 ms [1/9/2018 12:50:04 PM] flush complete [1/9/2018 12:50:04 PM] espcomm_send_command: sending command header [1/9/2018 12:50:04 PM] espcomm_send_command: sending command payload [1/9/2018 12:50:04 PM] read 0, requested 1 [1/9/2018 12:50:04 PM] trying to connect [1/9/2018 12:50:04 PM] flush start [1/9/2018 12:50:04 PM] setting serial port timeouts to 1 ms [1/9/2018 12:50:04 PM] setting serial port timeouts to 1000 ms [1/9/2018 12:50:04 PM] flush complete [1/9/2018 12:50:04 PM] espcomm_send_command: sending command header [1/9/2018 12:50:04 PM] espcomm_send_command: sending command payload [1/9/2018 12:50:04 PM] serialport_receive_C0: 72 instead of C0 [1/9/2018 12:50:04 PM] resetting board [1/9/2018 12:50:04 PM] trying to connect [1/9/2018 12:50:04 PM] flush start [1/9/2018 12:50:04 PM] setting serial port timeouts to 1 ms [1/9/2018 12:50:04 PM] setting serial port timeouts to 1000 ms [1/9/2018 12:50:04 PM] flush complete [1/9/2018 12:50:04 PM] espcomm_send_command: sending command header [1/9/2018 12:50:04 PM] espcomm_send_command: sending command payload [1/9/2018 12:50:04 PM] read 0, requested 1 [1/9/2018 12:50:04 PM] trying to connect [1/9/2018 12:50:04 PM] flush start [1/9/2018 12:50:04 PM] setting serial port timeouts to 1 ms [1/9/2018 12:50:04 PM] setting serial port timeouts to 1000 ms [1/9/2018 12:50:04 PM] flush complete [1/9/2018 12:50:04 PM] espcomm_send_command: sending command header [1/9/2018 12:50:04 PM] espcomm_send_command: sending command payload [1/9/2018 12:50:04 PM] espcomm_send_command: receiving 2 bytes of data [1/9/2018 12:50:04 PM] espcomm_send_command: receiving 2 bytes of data [1/9/2018 12:50:04 PM] espcomm_send_command: receiving 2 bytes of data [1/9/2018 12:50:04 PM] espcomm_send_command: receiving 2 bytes of data [1/9/2018 12:50:04 PM] espcomm_send_command: receiving 2 bytes of data [1/9/2018 12:50:04 PM] espcomm_send_command: receiving 2 bytes of data [1/9/2018 12:50:04 PM] espcomm_send_command: receiving 2 bytes of data [1/9/2018 12:50:04 PM] espcomm_send_command: receiving 2 bytes of data [1/9/2018 12:50:04 PM] Uploading 623136 bytes from C:\Users\Budman\Documents\Arduino Docs\ESPeasy Stuff\Flash Utilities\ESP_Easy_Flasher-master\BIN\ESP_Easy_v2.0.0-dev13_test_ESP8266_1024.bin to flash at 0x00000000 [1/9/2018 12:50:04 PM] erasing flash [1/9/2018 12:50:04 PM] size: 098220 address: 000000 [1/9/2018 12:50:04 PM] first_sector_index: 0 [1/9/2018 12:50:04 PM] total_sector_count: 153 [1/9/2018 12:50:04 PM] head_sector_count: 16 [1/9/2018 12:50:04 PM] adjusted_sector_count: 137 [1/9/2018 12:50:04 PM] erase_size: 089000 [1/9/2018 12:50:04 PM] espcomm_send_command: sending command header [1/9/2018 12:50:04 PM] espcomm_send_command: sending command payload [1/9/2018 12:50:04 PM] setting serial port timeouts to 15000 ms [1/9/2018 12:50:04 PM] setting serial port timeouts to 1000 ms [1/9/2018 12:50:04 PM] espcomm_send_command: receiving 2 bytes of data [1/9/2018 12:50:04 PM] writing flash [1/9/2018 12:50:13 PM] ................................................................................ [ 13% ] [1/9/2018 12:50:21 PM] ................................................................................ [ 26% ] [1/9/2018 12:50:30 PM] ................................................................................ [ 39% ] [1/9/2018 12:50:39 PM] ................................................................................ [ 52% ] [1/9/2018 12:50:48 PM] ................................................................................ [ 65% ] [1/9/2018 12:50:57 PM] ................................................................................ [ 78% ] [1/9/2018 12:51:06 PM] ................................................................................ [ 91% ] [1/9/2018 12:51:12 PM] ................................................. [ 100% ] [1/9/2018 12:51:12 PM] starting app without reboot [1/9/2018 12:51:12 PM] espcomm_send_command: sending command header [1/9/2018 12:51:12 PM] espcomm_send_command: sending command payload [1/9/2018 12:51:12 PM] espcomm_send_command: receiving 2 bytes of data [1/9/2018 12:51:12 PM] closing bootloader [1/9/2018 12:51:12 PM] flush start [1/9/2018 12:51:12 PM] setting serial port timeouts to 1 ms [1/9/2018 12:51:12 PM] setting serial port timeouts to 1000 ms [1/9/2018 12:51:12 PM] flush complete [2018-01-09 12:49:55] STOPPED due to errors! (try reset on the unit, then start a new flash attempt)
https://github.com/Grovkillen/ESP_Easy_Flasher
EDIT: I found that your log contained an small error (error: failed reading byte) and this is interpreted by my wrapper as an error big enough for close down. Maybe I should only report the error, and carry on the rest of the post flash stuff?...
EDIT2: Updated the version to 0.00.019 and will let errors slide if flash seems to be done allright anyway...
- budman1758
OK. Tried your latest version. It flashed the unit just fine but when it was time to do the post flash options I think it failed there because the unit did not reboot first b4 the flasher tried to save the post flash settings. After the flasher was done I immediately connected to the unit with Putty and there was no activity at all. Once I reset the module it booted up fine and went into AP mode and none of the post flash settings were saved to it. I uploaded the log to your dropbox.
Ah, I see. I might need to do a wait before the post flash... hm... let me think about that one for a little while.
PS: if you reflash the same unit, does it respond to the serial communication?
- budman1758
Same thing. I don't think the unit is resetting at all. There was no activity light flashing on my usb unit and the module was doing nothing when I connected after the flasher was done. I had to reset the module b4 there was anything in the serial console.grovkillen wrote: ↑10 Jan 2018, 19:51 PS: if you reflash the same unit, does it respond to the serial communication?
I might need the user to actually press the reset switch? Hmm... My nodeMCU and D1 mini that I use accept the serial commands right away.budman1758 wrote: ↑10 Jan 2018, 20:31Same thing. I don't think the unit is resetting at all. There was no activity light flashing on my usb unit and the module was doing nothing when I connected after the flasher was done. I had to reset the module b4 there was anything in the serial console.grovkillen wrote: ↑10 Jan 2018, 19:51 PS: if you reflash the same unit, does it respond to the serial communication?
https://github.com/Grovkillen/ESP_Easy_Flasher/releases
Version 0.00.020 is released with a new checkbox which will let the user manually reboot the device after flash.
I made a small error in the latest release, will update it tomorrow.
- budman1758
Tried it. Flashed fine but after flash settings still no workie. I uploaded a debug file to your dropbox.grovkillen wrote: ↑11 Jan 2018, 15:07 https://github.com/Grovkillen/ESP_Easy_Flasher/releases
Tried to get a screenshot of one of the powershell windows but they flash on and off too fast. Might help if they stay visible. Pretty sure the problems are related to Powershell. Are admin privileges transferring to them?
https://github.com/Grovkillen/ESP_Easy_Flasher/releasesbudman1758 wrote: ↑12 Jan 2018, 05:06Tried it. Flashed fine but after flash settings still no workie. I uploaded a debug file to your dropbox.grovkillen wrote: ↑11 Jan 2018, 15:07 https://github.com/Grovkillen/ESP_Easy_Flasher/releases
I have now tried to fix the issue regarding serial commands not being accepted. Please update to latest 0.00.021 version...
- budman1758
Hate to rain on the parade but post flash still no workie. You have a new debug file in yer dropbox.grovkillen wrote: ↑12 Jan 2018, 09:48 I have now tried to fix the issue regarding serial commands not being accepted. Please update to latest 0.00.021 version...
I will send you some test files to try to use powershell manually to send serial data to the esp.
I did some testing with version 00.021 (Win 10 64bit) and wanted to give some feedback. I really like the idea of being able to configure as many settings as possible during the initial flash and haven’t seen that attempted before in other flash utilities or wrappers. Hopefully this software can be further developed so people have that feature in a general purpose esp easy gui flash program.
The first time I ran it in a directory already populated with other files and folders. It failed to run giving me the following pop up message [much later I tried to reproduce this and was unable to (??)].
Windows cannot find 'M:\[...]\%RUN_FILE_NAME%'. Make sure you typed the name correctly, and then try again.
Next, I ran it in an empty directory. It started, created subfolders and populated them. This surprised me as I didn’t expect this behavior. I was curious what would happen if some of those directories already existed, so I tried again in another folder after manually creating conflicting directories and files. The program assumed that any directories that are there are fine to use and that any files in those directories are the correct ones. I’m not sure this is the best approach, but at least it’s safer than silently over writing over existing files. It would be much better to warn the user what is going happen during this first run and get confirmation before proceeding.
Operations
The program had no problem finding my generic CH340 based serial converter. I only had one attached and it defaulted to it correctly.
Initially, I couldn’t figure out how to browse to the directory where the binary was contained. I eventually realized one has to put the binary in the bin directory under the program. This is not the standard way of doing things and will be confusing. Additionally, people with multiple esp easy project trees would likely want to keep binaries for each esp easy project near the respective source tree and browse to the correct one when they flash. As it is, either one has to mix all the binaries together in the same folder and be sure the names are unique, or have a separate flasher program tree for each respective project. Neither are great solutions, it’s much better to just have the user browse to the directory with the binaries and remember the last location of the bin files between runs.
I then set the post flash actions to populate the name and WiFi information, and set it off. It seemed to finish the first phase of downloading the firmware then hung when trying to set post flash actions requiring me to kill it in task manager to fully exit all the background processes.
After inspecting the log, it was obvious what the problem was. The call to esptool.exe is hard coded for nodemcu. This is a big issue as espeasy runs on many boards, not just those that support nodemcu style of GPIO0 and RESET control. The software needs to have the user select the board type, pass it to esptool.exe, and if the board type is none, pause between esptool.exe operations so the user can manually reset the board. For most of my boards, this is a show stopper on using the post flash action feature.
Running it again without using the post flash action, it ran to completion without error, however the firmware was corrupted on the board and wouldn’t boot getting a checksum error. This took some time to figure out. This particular board I had not flashed before and I determined that it needed a slow flash clock to flash correctly.
Any flasher has to give the user the option to set the flash chip speed (20m/26m/40m/80m) and the flash mode (DIO/DOUT/QIO/QOUT). Not all boards work with the same settings. For my particular board, this was a total showstopper. Esptool.py and esptool.exe have these options for a reason and they must be supported by any wrapper to provide broad compatibility.
Feature enhancements
It would be nice if the software provides a full chip erase option before writing firmware. I’ve found many times going from one type of esp firmware to another requires a full erase for it to work properly. FYI- esptool.exe as far as I know does not correctly support a full erase so one has to write a blank file that is the same size of the flash chip to accomplish this.
As it stands, this flasher only supports boards that are highly compatible with nodemcu so it’s not of use to me as is. I would love to see the project finished so it can support most esp8266 boards.
Operations
It's still in a early stage. Will improve but main focus is standard boards (covered by the official supported ESP hardware found on wiki). I personally don't own them all though. DOUT is possible to use but that is it for now. Erase flash will be supported in time. Thanks for the feedback.
Thanks for working on it, I know it's early and my intent was to be helpful.
The board I was testing it on is listed as a known supported ESPEasy board on www.letscontrolit.com/wiki/index.php/ESP_Hardware. It is a recently purchased Sonoff basic. None of the Sonoff devices support nodemcu style control of GPIO0 and RESET, they all need to be manually reset between esptool operations, and Sonoff boards are *very* popular. Some people use an Arduino as ISP mode to program them, I use an inexpensive USB/Serial converter that supports both 5V and 3.3V and works very well (cost about $2 from ebay/china, $7 on amazon).
Thanks for pointing out the "force DOUT" option, I don't know how I missed the checkbox at the bottom. This latest sonoff basic I purchased needed to slow down the memory clock. I'm guessing the manufacturer changed to a different memory chip. Other sonoff devices I have used (over a dozen) did not require this.
I'm also wondering if I have some sort of font issue, the windows looks a little odd especially along the bottom and different from the one in your first post. Here is a image of how it displays for me:
Any idea of what the problem might be with the window?
Yeah, the problem is that windows 10 is rendering the window in a different way compared to windows 7. I will take care of that issue once I get the basic function working.
Have you used the "halt" checkbox for manual reboot? I have successfully flashed several basic units with the tool. Older versions though.
Okay, I just flashed (+post flashed) a Basic but the new ones need to be flashed using the ESP8255 bin file. Everything worked then... at least for me.Zeric wrote: ↑16 Jan 2018, 03:11 Thanks for working on it, I know it's early and my intent was to be helpful.
I just tried an older sonoff (with "Force -DOUT" unchecked, and "Halt app before port flash" checked). After FW flashing, it waited for the manual reset, then proceeded. The Wifi information was set correctly and connected to my network (cool), however the name of the device remained the default "ESP_Easy" and did not change to the name I specified "sonoff_a". The unit number did update correctly. The log clearly showed where the name was set to what I specified and I didn't see any errors, maybe a bug? Rebooting made no difference. Changing the name in the web interface worked fine. I did not try updating any rule sets.
As far as the memory chip...
I closely looked at both the sonoff boards, the one I successfully flashed today with ESP Easy Flasher (with DOUT unchecked), and the one that gave me issues before (not only in this wrapper program). The part number on the former is PN25F08 and the latter PN25F08B and they seem to be different manufacturers (ID 0xE0 vs 0x5E). There are many posts saying the "B" suffix chips need DOUT. As mentioned earlier, I had to set mode to DOUT and slow down the write speed in esptool.py after doing a full flash wipe to get a good write. I need to experiment more with that board, maybe the slow write requirement was a fluke.
On your use of the esp8285 FW bin
The esp8285 requires DOUT, just like esp8266 boards using PN25F08B chips. I saw a post where someone confirmed that the esp8285 bin file would work with an esp8266 board using a PN25F08B chip.
Feedback on Halt check box
When I first saw this setting, I misunderstood what it was for and it may just be a language issue. "Halt" normally means the abrupt total termination of a program (the has been true from old mainframes to modern day linux). But the intent of the checkbox is not for the program terminate, it's to wait for a user action. I think it would be more clear to say something like "Wait for user to reset before post flash".
Feedback on visual Layout
To me anyway, the current layout is scattered with comm related settings at both the top (COM port) and bottom (baud rate), and the board related settings in the middle (Halt app before post flash) and bottom (Force -DOUT). I suggest the top section have all the comm and board related settings. Top section: COM port, serial baud rate, board type, memory speed, memory write method, etc first. Next, the firmware location, then next the Post flash settings, then status window window near the bottom as you have it.
Great feedback! It's my first attempt in making something for the public so I totally get your points. I will rename the "halt" checkbox but the overhaul of GUI will have to wait. But I have noted the feedback and will take it into the final release (1.00.000).
I have just added serial monitoring using plink.exe: https://github.com/Grovkillen/ESP_Easy_Flasher/releases
Please observe that the serial monitoring will lock the COM port and making it un-responsive if you try to flash at the same time. Nothing bad will happen except that you get an error. With this new feature you can use the ESP Easy Flasher to quickly open a serial monitor for an attached ESP Easy unit, even though you might not want to re-flash that unit.
Serial programing only is now supported as of 0.00.026 (https://github.com/Grovkillen/ESP_Easy_Flasher/releases)
In other words, you can reprogram a unit without the need to reflash it. Doh!
Users browsing this forum: No registered users and 79 guests
