Write R148 to sonoff according to the steps, but the reboot can not find esp_0 WiFi, the brushing should be successful, and the result is consistent with the tutorial.
https://www.npmjs.com/package/homebridg ... ic-espeasy
Do this in this step, please help me. Thank you
When sonoff is restarted, no ESP_0 WiFi can be found
Re: When sonoff is restarted, no ESP_0 WiFi can be found
Hello and welcome to the forum.
This might have several reasons.
First, which memsize did you choose?
The Sonoffs usually have 1 MB (1024 KB).
Second, which CPU type is built in?
There are several versions of the sonoff in the wild, or maybe
some "remakes" from the chinese market. Some seem to have the ESP8266
on the board, others the ESP8285. These chips have same functionallity generally
but need a bit different handling by the firmware, so there is an extra version for
the ESP8285.
Third, if there is an ESP8266 built in the Sonoffs may have different flash ram types
which need different handling when flashed. Try to flash in DOUT mode if possible and
the other points above are OK.
Regards,
the ESP8285.
Regards,
Users browsing this forum: Google [Bot] and 41 guests
