Portable syslog server for test/bug check
#1 Post by grovkillen » 19 Jan 2018, 13:30
I use this setup for getting the logging done in a easy way (normally I use serial debugging but once a unit is online and placed somewhere it's not easy to get to it physically).
Just download the portable application and unzip it somewhere on your Windows machine: https://github.com/peacepenguin/tftpd64/releases I use the tftpd64 portable edition (4.60).
On the ESP Easy you go to advanced, enter the IP of your machine where you run the tftpd64 application. Change syslog level to 4 and then you just go to the correct tab (Syslog server) and wait for incoming messages.
Remember to remove the settings (IP="blank" and loglevel=0) once you're done.
Re: Portable syslog server for test/bug check
#2 Post by Shardan » 19 Jan 2018, 15:18
+1
budman1758
#3 Post by budman1758 » 19 Jan 2018, 20:45
+1
Now we need a "enable" checkbox for the syslog function. :mrgreen: :mrgreen:
#4 Post by grovkillen » 19 Jan 2018, 21:00
Let's make an issue budman! 8-)
budman1758
#5 Post by budman1758 » 19 Jan 2018, 21:10
Done! :D
#6 Post by grovkillen » 19 Jan 2018, 21:15
budman1758 wrote: 19 Jan 2018, 21:10Done! :D
Thanks 👍😊
micropet
#7 Post by micropet » 14 Mar 2018, 11:10
Wau!! Thank you.
#8 Post by grovkillen » 22 Aug 2018, 14:02
Users browsing this forum: Ahrefs [Bot] and 18 guests
