I am importing data from mqtt in Home Assistant of a DHT22 sensor to a EspEasy node and i need to format value and show in a oled display, for example 3130 to 31.3, can anyone help me whats wrong in the formula?
https://photos.google.com/share/AF1QipN ... 9neW14dzhB
I hope you see the pictures
thanks
Format data from mqtt
Re: Format data from mqtt
Perhaps use as formula:
%value%/100
I`m still having de problem with de format from mqtt,
In the example I need to format from mqtt value 2820 to 28.2 and show in the oled display
I use de formula: %value%/100 but nothing change.
- IMG_20180307_213957362_LL.jpg (35.58 KiB) Viewed 3928 times
I think it could be a bug that formula isn't working for the mqtt import plugin..? You might want to report it on GitHub.
You should see the computed value (after processing by formula) in the device overview tab.
And can you use real screenshots for the web-interface images, these photo's are too small and too unclear to see.
sorry for the bad photos before, the forum don't have a good image loader
I am still having problems formating the mqtt value
- IMG_20180318_024315112.jpg (3.33 MiB) Viewed 3777 times
- IMG_20180318_024217214_LL.jpg (351.61 KiB) Viewed 3777 times
- IMG_20180318_023952514.jpg (1.94 MiB) Viewed 3777 times
Users browsing this forum: No registered users and 62 guests
