My problem is that I can Upload the ESPEasy Mega bin File to a blue ESP-01 512k without problems. Actually I use the ESP_Easy_v2.0-20180313_normal_ESP8266_1024.bin on my ESP-01
Now I want the use the _P123_LIGHTS.ino For that I removed all unused _P0xx.ino's. From the _P0xx.inos I use only the _P001_Switch, the _P026_Sysinfo.ino and the _P123_LIGHTS.ino. I tryed it on a NodeMCU 4M board and I can compile and runt this without errors. Then I changed to the ESP-01 and received the following Error
Archiving built core (caching) in: D:\SYSTEM~2\TMP\arduino_cache_1319\core\core_esp8266_esp8266_generic_CpuFrequency_80,FlashFreq_40,FlashMode_dio,UploadSpeed_115200,FlashSize_512K64,ResetMethod_ck,Debug_Disabled,DebugLevel_None_____f7025fb08a3574e99f1785948801a9c1.a
c:/program files (x86)/arduino/portable/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: D:\SYSTEM~2\TMP\arduino_build_636611/ESPEasy.ino.elf section `.irom0.text' will not fit in region `irom0_0_seg'
exit status 1
Error compiling for board Generic ESP8266 Module.
I tried
512k /64k SPIFFS
512k /128k SPIFFS
with the same results
If I use
512k / no SPIFFS
1M / 64k SPIFFS
I can compile and upload, but the the esp doesnt start
Sketch uses 484049 bytes. Global variables use 51404 bytes
Can anyone help me what I did wrong?
My settings are
