grhhm
#1
Post
by grhhm » 22 Mar 2018, 19:35
Boot fails when build v2.0-20180319 is burned into WROOM-02
INIT : Booting version: v2.0-20180319
INIT : Warm boot #7
FS : Mounting...
FS : Mount successful, used 75802 bytes of 957314
Soft WDT reset
ctx: cont
sp: 3fff4a10 end: 3fff4ce0 offset: 01b0
>>>stack>>>
3fff4bc0: 40253c43 00000128 3fff0cd0 4021a2a7
3fff4bd0: 3fff6aa4 40201b0c 3fff4c30 3fff0d20
3fff4be0: 00000001 00000000 3fff363c 40233d43
3fff4bf0: 3fff4e88 00000025 00000025 4020f13c
3fff4c00: 3fff363c 3fff28ac 3fff4c30 4020f5a8
3fff4c10: 3fff6aa4 40201b0c 00000001 4020b0c0
3fff4c20: 3fff363c 3fff28ac 00000001 40234032
3fff4c30: 00000000 00000000 0000207e 40217ae7
3fff4c40: 3fff28cc 0000000c 00000000 40217b00
3fff4c50: 3ffe87a7 0000000c 3fff23fc 3fff3cb4
3fff4c60: 00000001 0000000c 00000000 40236d93
3fff4c70: 3fff5fac 0000000f 00000000 4021aa1f
3fff4c80: 3fff0f48 0000000c 00000001 40236e0f
3fff4c90: 3fff0f48 0000000c 3fff23fc 4023ec3a
3fff4ca0: 00000000 00000000 00000000 3fff61ac
3fff4cb0: 0000002f 00000015 feefeffe feefeffe
3fff4cc0: 3fffdad0 00000000 3fff3cae 4020c188
3fff4cd0: feefeffe feefeffe 3fff3cc0 4020f6a4
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
Might this be useful?
Post
by TD-er » 22 Mar 2018, 20:05
There are some issues with the WiFi.
The last build without the major changes to WiFi, I made, is 20180316.
The last version 20180322, should also work, since I extended the wifi connect timeouts.
But some still report issues.
Just a quick question, do you use DHCP, or a fixed IP-address?
Build 20180319 will not work on a new device, without stored settings.
grhhm
#3
Post
by grhhm » 23 Mar 2018, 21:03
TD-er wrote: ↑22 Mar 2018, 20:05
DHCP. I recall painful experience of static addresses
BTW, is it possible somehow in Github to mark really unusable builds?
I think many people burning tons of neurons and time trying to ignite broken builds. So marking builds can be useful for all.
Post
by TD-er » 24 Mar 2018, 01:33
That's something we should do I guess.
For now, I'm just asking people to test the current PR, before running into unusable versions again...
So could you test this PR:
https://github.com/letscontrolit/ESPEasy/pull/1165
It's an entirely different approach of connection management and in theory simpler.
papperone
#5
Post
by papperone » 24 Mar 2018, 12:19
WROOM-02 has 2Mb flash and I'm not sure we have a 2Mb bin in the nightly build...
when I was testing a module with this chip I had to compile myself with the right flash size, else it won't work!
Post
by TD-er » 24 Mar 2018, 12:44
And 1M flash versions? Then you cannot OTA, but at least you can try them.
papperone
#7
Post
by papperone » 25 Mar 2018, 07:50
TD-er wrote: ↑24 Mar 2018, 12:44
can't test them as I don't have them anymore, I installed in a friend setup with selfcompiled ESPEasy with 2Mb Flash settings... happily running so far for him
