Custom firmware problem
Re: Custom firmware problem
im totally blank, dont know what u mean??
can't test it now, my MacBook Air won't connect to esp at all, so gone try when im back at the Mac mini
"Don't let hope become a memory"
i couldn't be more happy, my parents it gonna love it sooooo many tnx, but that did i do wrong ?
- Screen Shot 2018-05-07 at 19.50.36.png (103.34 KiB) Viewed 20964 times
You can see the changes I made over here:
https://github.com/letscontrolit/ESPEas ... 1378/files
Who is responsible for this plugin?
the rain sensor isn't listed, and i can't get it to report inside temp / humidity to the mutt
- Screen Shot 2018-05-08 at 11.57.06.png (28.01 KiB) Viewed 20940 times
- Screen Shot 2018-05-08 at 11.56.47.png (131.99 KiB) Viewed 20940 times
Justme-nl is the writer of the online guide and I believe that he's the one who first created this plugin. I don't own a Ventus W266/RenkForce W205GU so I cannot fix this myself. Maybe someone else can? And I wouldn't say that "someone" is responsible for this, we're all in this together
yar thats why we are help ;D will glady help others to
but are u sure about the name ? Justme-nl i can't find him
I’m not 100% but I think I did read in the plugin readme Tint and RHint are not “interfaced” to the plugin due to hardware reasons.
For the rain maybe read more of the project data, as I changed course I stopped my interest in the W266
Belgium and land of ESP ... counting
yar read that after, and got the rain and outside temp enabled
hope they can fix the in temp to
Help,
I do not get displayed values, have no idea where the problem could be. In the log you can see that there is a connection!
i am using an esp8266 notemcu, is there anything functional to install?
3931717: WD : Uptime 66 ConnectFailures 0 FreeMem 21536 WiFiStatus 3
3961717: WD : Uptime 66 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
3991717: WD : Uptime 67 ConnectFailures 0 FreeMem 23224 WiFiStatus 3
4021717: WD : Uptime 67 ConnectFailures 0 FreeMem 21728 WiFiStatus 3
4051717: WD : Uptime 68 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4081717: WD : Uptime 68 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4111717: WD : Uptime 69 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4141717: WD : Uptime 69 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4171717: WD : Uptime 70 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4201717: WD : Uptime 70 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4231717: WD : Uptime 71 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4261717: WD : Uptime 71 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4291717: WD : Uptime 72 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4321717: WD : Uptime 72 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4351717: WD : Uptime 73 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4381718: WD : Uptime 73 ConnectFailures 0 FreeMem 22520 WiFiStatus 3
4385549: Ventus W266 Rcvd(00:00:00) 7FB1:60:1B:C40000D400:03:00000000:880000:12:3FB1:0000D9 > EE
4411717: WD : Uptime 74 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4416549: Ventus W266 Rcvd(00:00:00) 7FB1:60:1A:D40000D400:03:00000000:800000:01:3FB1:000197 > C2
4441718: WD : Uptime 74 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4447549: Ventus W266 Rcvd(00:00:00) 7FA1:60:1A:9C0000D400:03:00000000:880000:10:3FB1:0000D9 > C5
4471718: WD : Uptime 75 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4478550: Ventus W266 Rcvd(00:00:00) 7FB1:40:1A:F40000D400:03:00000000:880000:12:3FB1:0000D9 > 36
- 3.JPG (53.54 KiB) Viewed 17678 times
- 2.JPG (85.1 KiB) Viewed 17678 times
- 1.JPG (72.46 KiB) Viewed 17678 times
I have no experience myself with this plugin.
But considering the labels of the GPIO functions, it looks like it is using SPI.
The pins you're showing in your config are not the pins connected to the hardware SPI in the ESP.
Signal IO index ESP8266 pin
HSPI CLK 5 GPIO14
HSPI /CS 8 GPIO15
HSPI MOSI 7 GPIO13
HSPI MISO 6 GPIO12
See: https://nodemcu.readthedocs.io/en/master/modules/spi/
I would suggest to reconnect your device to these pins. I have not looked at the code of that plugin, so I'm not sure if the code does try to address the hardware SPI. (your mileage may vary so to speak)
HSPI CLK 5 GPIO14
HSPI /CS 8 GPIO15
HSPI MOSI 7 GPIO13
HSPI MISO 6 GPIO12
I tested, unfortunately, nothing helped.
In the log, data arrives, but nothing is displayed. Everything stays at 0. Perhaps something has been changed by the manufacturer. With the app USES_P124 have the same result or worse, it does not do anything in the log!
854305: Ventus W266 Rcvd(00:00:00) 7FB0:57:1A:EF0000EE00:0F:00004C00:880000:12:3FB0:010076 > D2
83950: Ventus W266 Rcvd(16:22:43) 7FB1:58:1A:E50000E400:01:02003600:980000:12:3F31:0100CB > EF
Data stays at 0
Data stays at 0
- 5.JPG (92.07 KiB) Viewed 17634 times
- 4.JPG (92.31 KiB) Viewed 17634 times
You are running multiple instances of the plugin.
Not sure if that plugin is capable of handling multiple instances. It is just that a lot of other plugins can't.
I don't know that plugin myself, so I cannot help here without diving into the code myself.
With one instance I had the same result. It looks to me as if the data can no longer be decrypted by the APP. My device is version V4. Possibly. something has changed in the data and would have to be adapted by the developer. How to contact the developer?
I don't have such a device, nor am I the developer of that plugin.
So I don't think I can be of much help, especially since I don't have something to test with.
