_P124_Ventus_W266_RFM69.ino Update to work with current MEGA
I'm using the _P124_Ventus_W266_RFM69.ino Plugin from Playground.
Since the recent update of ESPEasy Mega, the Plugin does not work anymore. The GUI of that Plugin shows an error.
Is there anyone who can fix this?
This would be great. Thanks.
Re: _P124_Ventus_W266_RFM69.ino Update to work with current MEGA
It is already included in the main branch and I even added it to PlatformIO.ini, so you can build a version with a single click.
And here a build with that plugin from a few days ago: https://www.dropbox.com/s/0f3lhz4chr4nn ... 6.rar?dl=0
Thank you.
Which Plugin-Nr it got?
Are you shure, that you were talking about the P124 Plugin which works witn an rfm69 to directly receive the data from the ventus w266.
There is no inside module of the ventus needed.
It is different to the Plugin P046.
I am not entirely sure. I just saw Ventus W266 and that was something I had to build a version for last week.
Sorry if that was the incorrect one.
Maybe we should have a look at all the Playground plugins to make them compatible again with the mainline source changes.
So I've tested the P124 from Playground and it works great except for the GUI issue, I've mentioned.
I think, this plugin can also be transferred to the regular branch.
Do you need something else (in terms of testing) to do this?
An issue on Github as a reminder, I guess
how can I install the p125, it will not work for me if I copy into the scr directory!
You also have to "include" it by adding the USES_P124 define in the file define_plugin_sets.h
For example in the PLUGIN_SET_STABLE set of plugins.
Users browsing this forum: No registered users and 109 guests
