I bought a card with ESP14 + HDC1080 + BMP280 + BH1750FVI, but I do not know if it is now compatible with ESP Easy, I saw that there is a post on the subject but without solution.
Is someone able to retrieve the information from the sensors?
https://nl.aliexpress.com/item/HDC1080- ... 37797.html
Thank you
Re: ESP14 + HDC1080 + BMP280 + BH1750FVI
The ESP14 is not the same as a ESP12.
It appears to have a separate 8-bit processor which is connected to the outside pins and thus blocking pins on the ESP8266.
Good evening,
Thank you for your answer, I think it was based on an ESP12 + STM8S003, that's why I think there was perhaps a solution with ESP Easy.
Apparently this is not the case, would you know where I could find information on this map and especially on how I could remount these sensors?
cordially
cordially
