ESP 12F won't connect once DeepSleep is enabled (Solved)
Posted: 07 Jul 2018, 14:49
Running (or at least trying to) Release mega-20180625 Build.
I set the unit up with a BME280 and a DSB18B20, along with the Analogue input monitoring the battery voltage from a resistor divider network.
The unit is powered from a solar board charged Li-Ion 18650 battery with an LDO regulator and ample smoothing capacitor (Though the same happens when I power the unit from a regulated PSU)
The controller is set as Thingspeak
All works well untill I enable deep sleep to wake up every 12 minutes at which point it will never reconnect to WiFi...
Pressing reset has the same result so the unit becomes stuck never able to connect.
Whilst it is awake, I enter 'settings' from a serial terminal.. (Ive edited the AP names and passwords but they are reported as correct)
The only way to get back to the unit is to enter 'Reset' from the serial terminal and re set up the unit once again.
I've had this hardware perviously running fine on much earlier versions but it's driving me nuts trying to get it to connect on wakeup from the versions released more recently.
INIT : Booting version: mega-20180625 (ESP82xx Core 2_4_1, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3)
236 : INIT : Rebooted from deepsleep #2 - Restart Reason: Deep-Sleep Wake
241 : FS : Mounting...
267 : FS : Mount successful, used 75802 bytes of 957314
577 : CRC : program checksum ...OK
609 : CRC : SecuritySettings CRC ...OK
712 : INIT : Free RAM:24184
713 : INIT : I2C
713 : INIT : SPI not enabled
1542 : INFO : Plugins: 48 [Normal] (ESP82xx Core 2_4_1, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3)
1542 : WIFI : Set WiFi to STA
1574 : WIFI : Connecting MyWifi_Main attempt #0
1595 : WD : Uptime 0 ConnectFailures 0 FreeMem 23456
1600 : ADC : Analog value: 1009 = 4.082
15032 : HTTP : connection failed
15061 : DS : Temperature: 28.12 (28-ff-89-3f-20-18-1-f2)
30067 : HTTP : connection failed
30073 : SYS : -51.00
45100 : HTTP : connection failed
45137 : EVENT: System#Sleep
45163 : SLEEP: Powering down to deepsleep...
>settings
6098 : Command: settings
System Info
IP Address : 192.168.1.105
Build : 20102
Unit : 1
WifiSSID : MyWifi_Main
WifiKey : Main_Password
WifiSSID2 : MyWifiGuest
WifiKey2 : Guest_Password
Free mem : 22280
