that's great news!!!grovkillen wrote: ↑02 Aug 2018, 12:09 I think we're on the same page here. Only a quick add to the discussion. The upcoming GPIO handler will make stuff like this possible.
Switch Button Long Push
Re: Switch Button Long Push
Just for completeness, a part of the discussion between Jimmy and I about this:
The idea is to read 1 single register to inspect all GPIO pins. Mask (AND) that with just the bits you want to check and compare with the last known value.
That's about 5 clock cycli, so can be done as often as possible.
When something has changed, it has to see what bit has changed (XOR) and process the change.
Such a change may result in an "event", which is now not more than add a job to the scheduler.
Then the plugin that should deal with the event can read the last change, the time high and the time low.
Also we have the actual pin state, because it is not cached
hello, I'm making a switchboard with 4 channel mains relay module with 4 buttons. I want when one of the buttons long pressed to turn ON/OFF all 4 relays. anyway, Can I do this?
I love playing a digital piano
I've done it with this plugin:
https://github.com/enesbcs/ESPEasyPlugi ... button.ino
Using "butonname#Longpress" event on all four buttons.
enesbcs wrote: ↑29 Nov 2018, 12:08I've done it with this plugin:
Just wanted to say thanks for this. I've been using the plugin for ~ 6 months now
I also wrote a blog post about how to use it as well
https://techlife.nz/blog/create-an-esp8 ... g-espeasy/
Thanks for mentioning. In fact, the new P001_Switch plugin in ESPEasy also capable of sensing longpress and doubleclick events.mattie47 wrote: ↑18 Jun 2019, 12:05 Just wanted to say thanks for this. I've been using the plugin for ~ 6 months now
Users browsing this forum: Google [Bot] and 103 guests
