Acknowledge GPIO change using MQTT
mkuttnig
#1 Post by mkuttnig » 11 Sep 2018, 21:46
Hi All,
A common pattern with multiple control apps seems to be, that if you are turning on /of a relay, the node responds with a state message (MQTT)
I am using openhab and I send an MQTT message to turn on/off the pool light:
/pool/GPIO/2 : 1
/pool/GPIO/2 : 0
The switch in openHab turns to the new status. That works fine.
However, if i use Alexa or some other source to publish that MQTT message, the switch does not update. (of course)
What i'd like to do is sending something like:
/pool/light : 1
/pool/light : 0
And the device responding:
/pool/light/state : 1
/pool/light/state : 0
That way, all others will know that the light was in fact turned on (by whoever)
I was able to get this done creating my own firmware like this:
  if (!strcmp(topic,"/pool/light")) {
    if (!memcmp(payload,"ON",length)) {
      state=LOW; action=true; // LOW is LED ON (inverted driver)
    if (!memcmp(payload,"OFF",length)) {
      digitalWrite(LED_BUILTIN, LOW);
      state=HIGH; action=true; // HIGH is LED ON (inverted driver)
    if (action) {
      digitalWrite(LED_BUILTIN, state);
      client.publish("/pool/light/state",state==LOW ? "ON" : "OFF");
but I'd like to use ESPEasy instead...
Can this be done?
Thank you!
Re: Acknowledge GPIO change using MQTT
#2 Post by grovkillen » 11 Sep 2018, 21:58
I just skimmed through but yes, you can do that with rules. I always use events to trigger commands and then I publish an acknowledgement message on a specific topic. Pretty much what you are aiming for I reckon.
mkuttnig
#3 Post by mkuttnig » 12 Sep 2018, 16:24
Thank you @grovkillen!
Are you saying you define custom events in rules like switchon, switchoff and then invoking them through a particular MQTT message (e.g. /pool/light/cmd : event,switchon)
I was thinking that already, that will work. Not the most elegant solution, but it will do the job ;-)
I will investigate deeper into event parameters. I think I read something that there is a way to pass params with just any event...
#4 Post by grovkillen » 12 Sep 2018, 17:01
mkuttnig wrote: 12 Sep 2018, 16:24 Thank you @grovkillen!
Yep it's a common use of rules. We think it's a rather elegant easy ourself but it's in the eye of the beholder I guess ;)
We'll try to make the rule editor better in the future though, I can agree on that.
Currently only one parameter (a float value) but up to three parameters are in the scoop for upcoming releases.
mkuttnig
#5 Post by mkuttnig » 12 Sep 2018, 18:22
It might be more elegant than I thought using the eventvalue:
on light do
    if [%eventvalue%]=1
        GPIO,2,1
        Publish %sysname%/light/state,0
        GPIO,2,0
        Publish %sysname%/light/state,1
unfortunately the comparison always goes to the ELSE branch.
I tried to publish the eventvalue back to MQTT and it comes in as a string "%eventvalue% - looks like the placeholder is never set to the real event value.
I post to this topic: pool/cmd with this payload: event,light=1 - yet always the ELSE is executed...
That's what I get in the log:
EVENT: light=1
ACT : GPIO,2,0
SW : GPIO 2 Set to 0
ACT : Publish pool/light/state,1
EVENT: light=0
ACT : GPIO,2,0
If that worked, I agree it is a nice way to do this :-)
#6 Post by grovkillen » 12 Sep 2018, 18:58
Doing that is currently not working but on the wish list. It's a good suggestion. In the meantime you need to assign the eventvalue to a dummy variable.
Users browsing this forum: Ahrefs [Bot] and 110 guests
