is it possible to start with Core 2.4.1 for next stable.
The pwm flicker problematic is only fixed in core 2.4.1.....
regards
Klaus
EDIT:
With core 2.4.2 the pwm flicker is back again !!
Is it possible to start with Core 2.4.1 for next stable ?
Re: Is it possible to start with Core 2.4.1 for next stable ?
rtttl function also only works with Core 2.4.1 to me, but serial 2way communication with 128 byte buffer works only with Core 2.4.0 for some reason.
I already tested it last week.
It sure is possible to go back to 2.4.1, but then I also have to take a look (again) at memory usage.
One of the big improvements on 2.4.2 is the free memory.
Another thing we really have to double/triple check is the building stability.
We don't want to have those issues again like we had in March/April where the nightly builds yield all kinds of impossible to reproduce bugs, which were eventually build related.
And hopping between core versions may also trigger such issues.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 25 guests
