espeasy doesn't send information to the thingspeak - deep sleep
My configuration: d1 mini + DHT22, espeasymega 20181002, soldered RST and GPIO 16, data send to thingspeak, powerconsumption about 50mA and it works. When I check sleep mode (sleep time 300s, time awake 10s) after 30seconds the power consumption decreases to 0,00mA, after 5 minuts d1 wake up for 10s (power consumption - 50-70mA, led blinks twice) and go to sleep (0 mA). In this case thingspeak doesn't show informationa about temp and humidity. When I disable deep sleep everything is ok. I try change espeasy to other versions and the situation is the same. Should I change additional options in espeasy that thingspeak displays data when deepsleep mode is on?? Thank you for your help.
Re: espeasy doesn't send information to the thingspeak - deep sleep
I don't know how much time it takes to read the sensor value.
You could experiment with the awake time (Config => Sleep awake time) and the interval of the plugin which reads the sensor.
Also look into the settings of the controller itself. Maybe it tries to send several messages, but Thingspeak may be refusing sending with a short interval?
Users browsing this forum: No registered users and 90 guests
