I think there are still problems with the thingspeak controller.
No matter if Blynnk or MQTT the values are always right at things peak which rounds up as he likes up or down.
Also, I did not quite understand the new settings (Max Queue Depth) (Max Queues Action) and (Check Reply)
For the other controllers, standard 10 10 Delete Oldest and Ignore Acknowledgment were all right.
I have 2 I2C devices, BME280, TSL2561 and a DS18B20 running on the ESP8266.
Firmware
Build:⋄ 20102 - Mega
Libraries:⋄ ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3
GIT version:⋄ mega-20181107
Plugins:⋄ 75 [Normal] [Testing] [Development]
Build Md5: 5899dd414bb9d289cfb21b37d743891
Md5 check: passed.
Build time:⋄ Nov 7 2018 03:38:09
Binary filename:⋄ ESP_Easy_mega-20181107_dev_ESP8266_4096.bin
Timingstats
P_4_Environment - DS18b20 ONCE_A_SECOND 2 0.80 0.018 0.018 0.019
P_4_Environment - DS18b20 TEN_PER_SECOND 24 9.61 0.011 0.011 0.012
P_4_Environment - DS18b20 FIFTY_PER_SECOND 116 46.46 0.006 0.009 0.019
P_15_Light/Lux - TSL2561 ONCE_A_SECOND 2 0.80 0.006 0.006 0.007
P_15_Light/Lux - TSL2561 TEN_PER_SECOND 24 9.61 0.002 0.004 0.007
P_15_Light/Lux - TSL2561 FIFTY_PER_SECOND 116 46.46 0.002 0.007 0.018
P_25_Generic - System Info ONCE_A_SECOND 2 0.80 0.019 0.019 0.019
P_25_Generic - System Info TEN_PER_SECOND 24 9.61 0.007 0.009 0.023
P_25_Generic - System Info FIFTY_PER_SECOND 116 46.46 0.002 0.010 0.023
P_27_Environment - BMx280 ONCE_A_SECOND 2 0.80 0.827 0.833 0.839
P_27_Environment - BMx280 TEN_PER_SECOND 24 9.61 0.003 0.009 0.027
P_27_Environment - BMx280 FIFTY_PER_SECOND 116 46.46 0.007 0.017 0.034
Plugin call 50 p/s 116 46.46 1.847 2.001 2.352
Plugin call 10 p/s 24 9.61 1.825 1.873 2.198
Plugin call 10 p/s U 24 9.61 0.933 1.237 1.630
Plugin call 1 p/s 2 0.80 3.623 3.639 3.656
setNewTimerAt() 163 65.28 0.236 0.265 0.344
What am I doing wrong or what is the problem?
thingspeak controller Probleme
Re: thingspeak controller Probleme
You need to have the thingspeak controller updating only once per 15 seconds. So if you have multiple sensors you need to either have them sent in one message or have the sensors reporting alternatingly.
