Ask for pro asiistance in making quite banal rule:
I have one press Button and 2 relays (=2 GPIO used)
Need to make the rule for several single consequtive presses like:
[first short press] : relay1=ON and relay2=ON
[second press]: relay1=ON and relay2=OFF
[third press]: relay1=OFF and relay2=ON
[forth press]: both relays are OFF
I tried.... many possible ways but failed..
seemed to me quite easy with condition:
if RELAY1=1 and RELAY2=0
do
RELAY1=0
RELAY2=1
I failed... Of course I used correct syntax in rule , upper is just example of idea (bad idea)..
Thank you!
RULES: press button switcher for 2 or 3 relays (no longpress!)
Re: RULES: press button switcher for 2 or 3 relays (no longpress!)
Please provide the version you're running and the rules you're using.
mega-20181112 dev for ESP8266 (nodeMCU)
my rules are not working...
LED_switcher#Switcher: pushbutton
LED_warm#Switch: relay1
LED_cold#Switch: relay2
On LED_switcher#Switcher do
if [LED_warm#Switch]=0 and if [LED_cold#Switch]=0
gpio,14,1
gpio,13,1
gpio,14,0
gpio,13,0
I tried to mention various IF conditions like:
if [LED_warm#Switch]=0 and if [LED_cold#Switch]=0 // FIRST press - relay1=ON and relay2=ON
do
gpio,14,1
gpio,13,1
if [LED_warm#Switch]=1 and if [LED_cold#Switch]=1 // SECOND pRESS - relay 1=OFF relay2=ON
do
gpio,14,0
gpio,13,1
if [LED_warm#Switch]=0 and if [LED_cold#Switch]=1 // THIRD PRESS relay1=ON relay2=OFF
do
gpio,14,1
gpio,13,0
if [LED_warm#Switch]=1 and if [LED_cold#Switch]=0 // another press relay1=OFF relay2=OFF
do
gpio,14,0
gpio,13,0
etc .. - but it is not working.
gpio,14,1
gpio,13,1
gpio,14,0
gpio,13,0
do
gpio,14,1
gpio,13,1
do
gpio,14,0
gpio,13,1
do
gpio,14,1
gpio,13,0
do
gpio,14,0
gpio,13,0
AND/OR is not using ifs, just the first if should be there.
Thank you! Stupid mistake...
now the code is like and working ppefectly
on System#Boot do
GPIO,14,0
GPIO,13,0
if [LED_warm#Switch]=0 and [LED_cold#Switch]=0
gpio,14,1
gpio,13,1
if [LED_warm#Switch]=1 and [LED_cold#Switch]=1
gpio,14,1
gpio,13,0
if [LED_warm#Switch]=1 and [LED_cold#Switch]=0
gpio,14,0
gpio,13,1
if [LED_warm#Switch]=0 and [LED_cold#Switch]=1
gpio,14,0
gpio,13,0
on System#Boot do
GPIO,14,0
GPIO,13,0
gpio,14,1
gpio,13,1
gpio,14,1
gpio,13,0
gpio,14,0
gpio,13,1
gpio,14,0
gpio,13,0
Users browsing this forum: No registered users and 102 guests
