"Alive item", Regular (planned) reboots
Tom Bombadil
#1 Post by Tom Bombadil » 13 Dec 2018, 17:58
for the time being, I am having a bunch of D1mini and NodeMCU devices, reporting Temp/Hum/Pres values to my home automation System through UDP as follows:
Sensors ----> UDP Controller in ESPEasy --> Backend ( smarthomeNG ) ---> Frontend ( smartVISU ).
In general, this is working fine and smooth. However, I am having issues with some of the ESP's (hourly reboots, sometimes an ESP hangs without being noticed, etc). Just this week I had one device offline for 3 days, and didn't notice it.
Besides the sensor values, my backend also stores date/time for 'value last updated' and 'value last changed' for each submitted item. So I am thinking about introducing a new 'alive' dummy value for each of the ESP's, that is frequently sending an update to the backend. If the dummy value hasn't been updated for like 30 minutes or so, I know the device is offline and needs a reboot. This status could easily be displayed in the frontend by a separate bool item next to the temp/hum/pres values as a 'traffic light' red/green.
So far all is clear, I am just not sure what would be the best / most reliable way to configure ESP Easy (I am still pretty much a noob on rules etc). Also, I read somewhere that ESP Easy Controllers only send protocols once a value has changed (so: no sending for unchanged values). The following two rule sets came into my mind, but before bringing this 'live' I wanted to ask if someone else has some hints or a better solution for this, or if maybe someone has done something similar before:
//?on System#Boot do?//
on Time#Initialized do
  TaskValueSet 3,2,1          // set dummy 'alive' item to 1
  timerSet,1,900              // wait for 15 mins
on Rules#Timer=1  do
  TaskValueSet 3,2,0          // set dummy 'alive' item to 0
  timerSet,2,900              // wait for 15 mins
on Rules#Timer=2  do
on Clock#Time=All,03:00 do     // every day at 03:00
  Reboot
Alternatively:
  TaskValueSet 3,2,%unixtime%  // write seconds into dummy item
on Rules#Timer=1  do
  Reboot
Thanks for your comments and suggestions!
/tom
Re: "Alive item", Regular (planned) reboots
#2 Post by grovkillen » 13 Dec 2018, 18:32
I'd do it like this:
on System#Boot do
  timerSet,1,30
on Rules#Timer=1 do
  //Whatever you want to do
  TimerSet,1,30
Tom Bombadil
#3 Post by Tom Bombadil » 13 Dec 2018, 19:09
Thanks - looks pretty much straightforward. Wasn't sure if I could activate a timer from itself. Only System#Boot seems too early, it is delivering a 2-digit value (like '16') to the dummy item, representing the seconds from Jan-01-1970. So I will stick to Time#Initialized, which delivers a 'real-world' %unix_time%.
What makes me wonder - I set the interval of the timer to '15' (seconds), but the value is only changing like every 2 minutes or so (investigating details right now):
on Rules#Timer=1  do
  timerSet,1,15                // wait for 15 secs
Bug or feature?
/tom
#4 Post by grovkillen » 13 Dec 2018, 19:57
TaskValueSet doesn't "trigger" the task to be re-read. You have to make a TaskRun after the task value is being set for it to "trigger". So your dummy is then only checked more infrequently if you do not do that TaskRun command.
Tom Bombadil
#5 Post by Tom Bombadil » 15 Dec 2018, 23:43
Thanks the help again! Quick update - got it running well with the following rules:
on Sensor#Temperature do
  TaskValueSet,3,1,%c_dew_th%([Sensor#Temperature],[Sensor#Humidity])
  TaskValueSetAndRun 3,2,%unixtime%  // write seconds into dummy item
  TimerSet,1,600                     // wait for 15 mins
on Rules#Timer=1 do
  Reboot
Nice side effect - the hardware watchdog reboots seem to have disappeared, or at least delayed by >100% (not sure yet). Before no uptime >4 hours, now all sensors lasting since >8hrs already. Only other thing I changed besides the rules is the BME280 reading time 30s --> 120s.
/tom
Users browsing this forum: No registered users and 96 guests
