I understand the need for a frozen version.
But if it's there and not thoroughly tested, users come with a bug report, and you have to point them to .... try the latest ...
If you offer a frozen version it needs to be good for (say) 90% of the community.
I remember a proud post from grovkillen .... running for 150 days! (on my disk: ESPEasy_mega-20180323 reported as 150 day stable.zip)
When I was lazy, I would choose that release.
A massive amount of testers is very useful/needed, as we can see now:
TDer sees hardly any problems in his test set-up.
The few (???) users of the latest releases do have problems ...
Searching for a pattern, I stopped a few days with upgrades.
My results:
Since 19-12-2018 evening counter reset:
No 14: 2 reboots mega-20181128 Wemos D1 mini batch 1 Jul 2017
No 18: 8 reboots mega-20181128 Wemos D1 mini batch 2 Febr 2018
No 19: 2 reboots ESP82xx Core 2.5.0-beta1 Wemos D1 mini batch 2
No 21:11 reboots mega-20181120 Wemos D1 mini batch 2
No 23: 6 reboots mega-20181128 Wemos D1 mini batch 3 Oct 2018
No 24: 3 reboots mega-20181128 Wemos D1 mini batch 3
No 28: 3 reboots mega-20181128 LOLIN D1 mini V3.1.0 batch 4 Nov 2018
All have strong (-60dB) to extreem strong (-35dB) RSSI
All have Wemos marking (looks as no clone), No 28 has the new LOLIN marking.
All running this configuration:
viewtopic.php?f=2&t=5955&p=32477#p32473
Power Supply: TSP-05 or HLK-PM01
with different plugged configurations of
- 0 or 2 DS18B20
- no PWM active
- No 18: with flow counter
For reference, ... running problem free:
#3
NodeMCU units with ESPEasy_v2.0.0-dev11 (July 2017!!) and a Rule for the 49 day reboot, are running trouble free with #8-12 DS18B20 sensors in the same WiFi network as today's tests. Up-time follows the 49 day Rule, and hardly any NAN on display.
My noob conclusion is that the improved performance/timing effort has had a bad influence on WiFi and DS18B20.
As I understood from the Github discussions, the DS18B20 timing is not obeyed (and it worked in the past due to slower performance..??).
For WiFi, I already suggested earlier: offer a temporarily switch back to 802.11 B/G, to rule out bad WiFi conditions.
Or ... is it Wemos ???
