I followed the guide on the wiki flashing my NODEmcu..
Seemed like it worked, didnt get any errors in the cmd...
Next step in the setup guide is to look for the ESP_Easy_0 in your wifi network..it isnt there? Only my normal networks and my neighbours.. ..
What to do?
Flashed but dont see access-point?
Re: Flashed but dont see access-point?
You can try my flasher (included in the zip).
I downloaded ESPEasy_R120 and used the flash file in that zip..
Ok, we're pretty close to releasing a new stable/freeze so you should really try the latest found here:
https://github.com/letscontrolit/ESPEas ... a-20181220
Nice.. I opened easy flasher.. I have no clue what to do with this..
- What firmware i should use in that long list?
- Unit, is this free to fill out with anything of choise?
- Rules?
You should use normal (4096 if you have a regular Wemos or similar board). You shouldn't care about rules if you don't know what it is.
Unit number is 1...254 pick with care, you don't want to have two units with the same number.
EDIT: No, wait.. I entered my SSID into fallback to and now I could see my ESP_Easy_0 network and connect via myphone.. it disconnectid after a minute.. cant see it anymore..
I can see it on my laptop byt cant connect.. No.. cant see it on my peter either anymore
Flashed it again.. doesnt come up again..
OPS.. seems like the flash didnt make it clean so at already is connected to my network.. thets why I didnt see it as a network again. Opened the ne IP i got from serial monitor.. well lets see now.. following guides again*
Original post below:
Still cant see it as a network.
Pressed "Open serial monitor in the flash window"
It says "no valid wifi settings"?
I have entered my SSID for 2,4wifi and pass for that network..
{l $▄ƒ| älα|älΣ#|Äé∞█r¢bîpî≥no▀dNo£ΓΣbpîÄ$r$r$p√oαé$ä▄Bo┬πolΣÅpä√NnεlîÅl Énol nrÄ█Æn#▄lr█ÆnB▄l£"cB£Ärl ⁿâo▄¬U101 :
INIT : Booting version: mega-20181220 (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
102 : INIT : Warm boot #1 - Restart Reason: External System
104 : FS : Mounting...
129 : FS : Mount successful, used 75802 bytes of 957314
471 : CRC : program checksum ...OK
482 : CRC : SecuritySettings CRC ...OK
483 : CRC : binary has changed since last save of Settings
591 : INIT : Free RAM:23984
593 : INIT : I2C
594 : INIT : SPI not enabled
607 : INFO : Plugins: 46 [Normal] (ESP82xx Core 2_4_2, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
610 : WIFI : No valid wifi settings
612 : WIFI : Could not connect to AP!
613 : WIFI : Set WiFi to AP
1534 : WIFI : AP Mode ssid will be ESP_Easy_0 with address 192.168.4.1
2869 : WD : Uptime 0 ConnectFailures 0 FreeMem 20576
Users browsing this forum: No registered users and 100 guests
