ESP8266 MQTT IR Transmitter with ESPEasy
I'm using the schematic below:
The modules works perfect for capturing and transmitting IR signals. They are very simple to use, along with the IRremoteESP8266 library on Arduino IDE.
With the: IRremoteESP8266/examples/IRrecvDumpV2 I get code 8166817E
Converting for DEC=2170978686
With the: IRremoteESP8266/examples/IRServer work very well.
But PLEASE I need help understanding ESPEasy!!!
My Devices setting is as below.
MQTT work very well.
I using GIT version:mega-20181112
IP:192.168.50.179
If I change the "led" pin is set for GPIO the command
http://192.168.50.179/control?cmd=GPIO,4,0
Turn OFF the led.
And the command
http://192.168.50.179/control?cmd=GPIO,4,1
Turn ON the led
How do I send the code, “2170978686” through IR?
HTTP bellow does not work...
http://192.168.50.179/control?cmd=IRSEND,2170978686
MQTT send 2170978686 bellow does not work...
/IR/GPIO/04
Please How should I send the code in ESPEasy?
Marcelo Miranda
How should I send the IR Transmit code?
Re: How should I send the IR Transmit code?
If this helps, IRrecvDump V2 sends
IRrecvDumpV2 is now running and waiting for IR input on Pin 14
Timestamp : 000035.723
Encoding : NEC
Code : 8166817E (32 bits)
Library : v2.5.2
Raw Timing[71]:
+ 9068, - 4444, + 624, - 1614, + 624, - 496, + 626, - 496,
+ 624, - 496, + 624, - 498, + 624, - 498, + 624, - 492,
+ 624, - 1618, + 624, - 496, + 624, - 1620, + 624, - 1616,
+ 628, - 498, + 624, - 496, + 620, - 1618, + 624, - 1618,
+ 624, - 496, + 624, - 1614, + 624, - 498, + 624, - 498,
+ 624, - 498, + 624, - 498, + 624, - 498, + 624, - 496,
+ 624, - 1614, + 628, - 492, + 624, - 1618, + 624, - 1620,
+ 624, - 1614, + 628, - 1614, + 624, - 1618, + 624, - 1620,
+ 624, - 498, + 624, - 42326, + 9072, - 2208, + 602
uint16_t rawData[71] = {9068, 4444, 624, 1614, 624, 496, 626, 496, 624, 496, 624, 498, 624, 498, 624, 492, 624, 1618, 624, 496, 624, 1620, 624, 1616, 628, 498, 624, 496, 620, 1618, 624, 1618, 624, 496, 624, 1614, 624, 498, 624, 498, 624, 498, 624, 498, 624, 498, 624, 496, 624, 1614, 628, 492, 624, 1618, 624, 1620, 624, 1614, 628, 1614, 624, 1618, 624, 1620, 624, 498, 624, 42326, 9072, 2208, 602}; // NEC 8166817E
uint32_t address = 0x6681;
uint32_t command = 0x81;
uint64_t data = 0x8166817E;
Then I tried the command
http://192.168.50.179/control?cmd=IRSEN ... 166817E,32
Also does not work, neither HTTP nor MQTT.
Encoding : NEC
Library : v2.5.2
Raw Timing[71]:
IRSEND,NEC,8166817E should work. If not check your schematic. R2 has to be calculated, depending on the LED you use.
Users browsing this forum: No registered users and 107 guests
