ok, thanks
i suppose 0-10ppm CO = 0V
but 1000ppm CO = how many volts?
MQ2 smoke/gas detector support?
Re: MQ2 smoke/gas detector support?
I would also love to use some MQ-Sensors. Are there any plans for this?
Maybe this helps:
https://github.com/IntranetOfThings/wemos-mq135
http://electronics.stackexchange.com/qu ... controller
http://davidegironi.blogspot.de/2014/01 ... -with.html
Maybe this helps:
I also want to know if there are any plans to support MQ sensors? there are quite a few variants, I got a few now one year ago but never tryed to use them
Can someone tell if the CO sensor MQ-9 will work with 2.0 ?
Add MQ135 plugin at https://github.com/letscontrolit/ESPEas ... Playground
Please test
Please test
I installed the MQ135 plugin, but reading out looks a factor 10 to high.
Is plugin based on 5 volt feed on sensor or 3,3 Volt ?
- mq135_espeasy.png (10.25 KiB) Viewed 14255 times
