SOLVED/Working: Wiegand26 input from Fingerprint - and RFID Tag
Re: Wiegand26 input from Fingerprint - not RFID Tag
thanks,
now that i prooved to myself it is working,
i google for easy and foolproof level-shifting from weigand 5v to espeasy 3.3 volt.
it seems that the 74xxxCMOS logic ICs could do...i will report.
i checked the wiegand code in espeasy and it seems to work like on the arduino/nano with falling edges on interrupt.
so i think i must work with levelshifting and espeasy... we will see..
an adventure ended here:
the 74HC4050 are only uni-directional level-shifter. it could have worked, but i failed with these ics again.
than i went back to my nano and the wiegand-sketch. this worked.
i could send to UDP, after tryout of different libraries for the ENC28j60 Ethernet ship.
one had CC on pin 10, the other on pin 8. i sorted this, tried different sketches, added a UDP.header and could send via UDP.
ok. than i tried to send also via MQTT, but the libs for the ENC28J60 are 5 years old. the nanode-lib has mqtt, but no udp-send.
i went back to my espeasy and had the idea of using the nano as a extender to the esp8266.
the nano has 5v, the esp8266 has3.3v, so i needed a level-shifter again for i2c communication for the extender.
i looked again at my level-shifter, found a new hint about bi-directional transfer 5v-3.3V on TXI-TXO (both outer pins on my pcb).
i gave it another try to use the fingerprint with the wiegand-out (5V) and the bi-directional level-shifter pins to the esp8266 on my gizwit-board.
(i put in addtion to the mqtt some rules for udp-send in the espeasy, hoping i could terminate the udp-send string with special characters in future firmware...)
BINGO! it works!
BINGO! it works!
Re: SOLVED/Working: Wiegand26 input from Fingerprint - and RFID Tag
@tozett
Nice item
Can you tell me how it's preforming? Is the fingerprint scan preforming well?
How does the fingerprint part works? Does it hashes a scan and returns a x digit unique code on the wiegand interface, or does it returns a 1 on the lock port when a valid fingerprint has been scanned?
I'd like to replace my simple wiegand rfid reader by this reader, but i want to control when the lock is open and when it's closed.
Of course i can still use my old RFID tags, but i would love to combine it with fingerprint, and my doorbell is broken, so this seems a great upgrade of my perfectly working system to me. I don't expect i have to change my code, because it's using / working with wiegand already.
It is stable, and working for over 2 years now without failing even once
Nice item
hi,
thanks for interest. all works well with the espeasy (wating for bugfix for different IDs from TAGs from MQTT/LOG and SendToUDP ), before i mount it on the door. i wanted to do this today, but i wait...
but the fingerprint reader is fast and (as far as i can tell) reliable. it reads 4001-chips SUPERfast, sends all allowed! tags and fingers out of the Wiegand-interface (maybe all unallowed? didnt noticed yet..)
i have another fingerprint for more than 2 years at our door at home. bought it as a "sebury f007", (manual,german) sold as differnt brand everywhere on the net ali-**. this old one reads only after two tries. the finger must be warm, and blowing air from my mouth on the finger helps all the time.
but the new one works instantanly correct and fast. i bought two different models with wiegand-output at random on aliexpress, i want the finger-code on my homeserver. i must try the other model, too. no time yet. on my homeserver i check, if a finger/tag has accesstime for a certain door.
maybe it is as with every fingerprint, you must put your finger correct on the reader-display. but the new one seems very good for around ..40EUR.. find it here on aliexpress, as long as it is sold. there is a wiring diagram and the one-sheet-manual. i dont had more in the package.
your other questions:
it returns (what seems normal, i am new to this) the usual wiegand-information for finger/tag. that is facilty-code/ID -> means finger-id/tag-id on the wiegand.i looked all up wiegand-format on the net, as it was not working with my level-shifting. especially here and here.
finger and Tag's (i think) must have been read-into the reader (up to 3000), than it sends them on a finger-tag access out on wiegand (and via espeasy on the wlan. means, that i must enable all finger/tags before on the reader, than i get them over wiegand/lan on my homeserver to unlock. works for me, because i manage access-times on my gira-homeserver (took some time to implement, i attach screenshot.. )
maybe worth copying some ideas from my screenshot? i have timers with one-shot opening, group-access over single-access, 8hrs validity for ...
- Zwischenablage02-keymatrix2.png (94.68 KiB) Viewed 44818 times
Wow, thanks for your fast - and helpfull reply.
I think i understand how the reader is working now, first you "learn" new fingers, by pushing the buttons on the back.
After that, the fingers, once recognized send "some" - ID though the wiegand interface.
Nice
I'm gonna order one and see how it's preforming!
Thanks for your suggestion. I will look at your web interface later. For now i'm planning to keep it simple, just change it with my current reader
Nice
the manual is somehow...chinese...and as only one addition:
you can define a chip/tag or a special finger as a "learning"-Tag.
hold it to command the reader into learning a new tag/finger, it beeps, than present the new tag/finger. And the reader has learned it.
i would be difficult to push the buttons on the back if it is once mounted to the wall ...
one thing: i did not see, how one can delete a special tag, if you lost it.
a normal case, which can happen, i would think. but i have no clue how to delete a lost tag/finger from the reader. if you recognize something with your new toy, please keep me informed?!
The point is, i dont want the reader itself to control wether acces is allowed - or not.
If it's sending tag numbers, or finger id's to my esp module, that's fine by me.
The programmed white list inside the esp module is leading, so if that's rejecting the key, found valid by the reader, yes, you see a green led but the door won't open.
I don't trust the chinese stuff that much and like to be in controll myself.
Of course i will let you know if i found out some more details or nice use cases.
I have not tried it yet, but i am planning on getting rid of my modyfied ESP sketch and i want to use the latest, since the new versions allow conditions.
I'm thinking about: If key == 0011001 || key = 0030202 || etc. etc.
Then: pulseout x,x && notify domoticz / send push message or something else
Else:
Event xxx (Notify domoticz / send push message or something else)
I'm coming short on development time, but i have two weeks vacation and scool isn't starting before september so i'm planning on renewing my solution.
Have you tested a little bit with the conditions part?
Else:
sorry, what do you mean? RULES in Espeasy? need some explanation?Have you tested a little bit with the conditions part?
i played with the RULES in espeasy ....
i like the same you like: to control a whitelist on my homeserver. i think, the cheap reader will only send IDs, if they are on the readers whitelist.
so you have to read in all possible fingers and tags, than you can block them (on time,group, ...) in a whitelist/server afterwards. otherwise the reader wont send, i guess (but i have to check twice..)
just if you meant the RULES=Conditions from the wiki,
these are my testing RULES at the moment. (missing an option to send special characters like "\x0F" or "\n" or "\cr\lf")
for a NFC/finger/tag-solution it is missing a web-gui. i am afraid one has to code a plugin for this...
Rules:
Rules:
//on a reading-event do ..
On rfid#tag do
// ** send direct to homeserver-key-check **
//SendToUDP,192.168.14.204,8899,Haustuer Key:[rfid#tag]%
//SendToUDP,192.168.14.253,4747,Haustuer [rfid#Tag]%
SendToUDP,192.168.14.253,4751,[rfid#Tag]
// ** MQTT use additional topic for node-red **
//publish ESP/01/Haustuer/Key/[rfid#tag]
// ** specific tag, specific action...test-case **
if [rfid#tag]=25323
SendToUDP,192.168.14.204,8899,Haustuer [rfid#tag]%
Ok
I Received the reader yesterday.
The RFID reader is more sensitive then the one i was using before.
- I just swapped the old raid reader with the new one, without modifications it's just working.
- After that, i replaced the esp module with a new 12F one, uploaded the latest version of espeasy, made some basic rules and i can confirm that's working out of the box also. My door opens after reading a valid key.
- Next thing is to get fingerprints working, did some testing. The readings are fast and accurate. Once a finger is added, it sends u unique id over the wiegand interface. The ID is just some id, every new finger is just the baseID + 1.
- There is no ID send when the finger is not "programmed" into the device, so you need to keep the two RFID Tags.
So the summary:
The RFID reader is working out of the box with espeasy + level shifter.
The fingerprint reader is working also, it's sending finger id's to the esp module / domoticz.
The doorbell is connecting two pin's when the button is pushed, i tried putting one pin to GND, the other to a GPIO input port, but then the reader won't boot. For now i attached my classic doorbel to the pins.
Problem:
I might have a defective item, or i'm doing something wrong. The reader starts beeping after two / three minutes. After those beeps, it stops reading fingers. The RFID reader remains working, the lights remain on. I have tried without the wiegand / doorbell wires connected, but it's not helping.
Do you have the same experience? And do you know what the button below the reader is doing?
So the summary:
Problem:
had the reader running for testings around 30 minutes. i heard no beepes.
mine reader appeard to me as without any malfunction.
i also wanted to use the bell-button, but had to time to check this,
which button on the button of the reader do you mean? you have a picture?
(sorry, but i am on the road for a round 14 days..so updates from me are may less frequent here...)
Thanx for your reply.tozett wrote:had the reader running for testings around 30 minutes. i heard no beepes.
After some further investigation i think i found and solved the problem.
There was one tanta condensor inside the reader not well soldered. I applied some more tin, reconnected the reader and the problem appears to be solved
So everything is working as expected. I made a factory reset. After this reset new learned fingers get id 2001 2002 2003 etc.
The button i meant was the status led button, it has red / blue led and a switch. Haven't figured out what that's good for.
Thanks for the suggestion, i really like this device, although i have my doubts about the weather, i don't think its gonna last very long outside. For some reason i thought it was water resistant, but as far as i can see, it's not.
This are the rules i use to trigger my lock:
This way, your problem with lost tags is resolved, just remove the item from the rules list.
on RFID#Tag=1003 do
Pulse,5,1,5000
on RFID#Tag=1001 do
Pulse,5,1,5000
on RFID#Tag=1002 do
Pulse,5,1,5000
on RFID#Tag=1003 do
Pulse,5,1,5000
on RFID#Tag=1004 do
Pulse,5,1,5000
on RFID#Tag=1005 do
Pulse,5,1,5000
on RFID#Tag=12345 do
Pulse,5,1,5000
yeah, cool idea with rules.
in my personal stetting, i send the ID allways from the reader direct to my homeserver. either way if finger or key.
on the homeserver, i check if the ID has a valid timeslot for opening.
so i limit the parcel-and-post-service-keys to workdays from 09:00-18:00 as valid time for openings.
feels only more secure...
if you take the id from the list, surely no key-open anymore.
but i was wondering, how the chinese inventor thought to solve the problem, to remove a key which is lost and therefore cannot be presented to the reader anymore for removal..
timeslots could be done with rules also, thats a good direction to go...
maybe a plugin with web-input-forms would be the best option for any future-plans with key-system...
simplified my setup,
as i found that one can risk to give 5V on the GPIO of the ESP module,
i left out the level-shifter. It is working!
i addtitionally hooked up a modern NFC-Reader-Breakoutboard (ISO/IEC 14443)
http://www.elechouse.com/elechouse/inde ... ts_id=2242
to have both frequencies on NFC/RFID.
i mounted it outside, see what the winter brings to (me and) the reader
ps: i found the blue button in the lower half, underneath the finger-area.
if you hold him, the color gets red... hmmmm
- wiegand3.png (60.97 KiB) Viewed 44724 times
the fingerprint-area is constantly glowin in green.
on my other fingerprint, this was only happen, if one approaches the reader, or the finger went to the area.
now i have a green-glow on my frontdoor.
did someone recognized, if one can turn this off?
maybe the security-level (whats this?) can change it?
glad, if someone can give me a hint, and its easy (no soldering)...
the button underneath the green-glowing fingerprint-area,
which has blue-/red-light for normal-mode/programming-mode,
can be pressed. my small doku-sheet has a picture, which calls this button
"Activation-Key".
What is is good for? if i press it, the light goes RED..hhhmmm
for deletion of lost keys/fingers: one can save all IDs to an SD-Card,
edit/delete some Keys, and Upload it again ..
"Activation-Key".
- HTB1HXFwKVXXXXbCXpXXq6xXFXXXb.jpg (28.49 KiB) Viewed 44694 times
ACTIVATION key...
i am now using the fingerprint.
and sometimes it does not sense a finger lying onto the reader-area.
if i then press this Activation-buttion, the reader starts reading.
maybe thats what it is meant for ...
I have the same problem.tozett wrote:the fingerprint-area is constantly glowin in green.
It's green all the time. It's not reading my finger however after a few minutes.
I'm thinking it might have something to do with the level shifting. I will try to disconnect the data wires and see of that's helping.
The button doesn't seem to work / do anything, but its switching according to my multimeter.
my reader is mounted on the frontdoor. outside.
now as it getting colder, it takes some minutes with the finger strongly pressed onto the reader, that after sometime the reading starts.
i here the beeps, if the reader has done its work.
seems somehow less with espeasy,
more with the reader itself.
i assume that the reader senses for the finger/body temperature, than starts reading.
now as it is colder outside, the finger has to warm up the reader-plate. after 1-2 minutes of warming up, the reader starts normal reading..
it my assumption is true, you could check with warming up the reader plate or warming up the finger with warm breathing against the finger (and strong pushing against the plate). than reading seems as in summer ...
maybe there can be found an electronic enhancement? you had it once open....
Good afternoon,
i'm working on a similar project in which i'm considering 250 tags to allow to power on a switch to open a door.
Can you explain (please the easy way) what to do to allow a sort of "allowed list?" to use in events?
Thank you very much.
Luca
Luca
In this Reader you can allow Tags directly by the Reader.
But i did not wire the Reader with the Lock!!
I personally allow all Tags, than get the tag-id from the Reader to the espeasy, and from there forward it to my allow list in My Homeserver. I don't use Events for this.
Any other question?
Any other question?
for maybe 10 to 15 tags that might be possible with ESPEasy directly by using rules.
But 250 tags is far beyond the capacity of ESPEasy together with ESP8266 memory.
Second, it will be a hassle to keep that list up to date with ESPEasy.
You would have to edit the rules manually everytime a tag changes.
There are two ways to work around this:
Use an ESP with 4 MB Memory and write your own software for it. Might work.
Or use a small computer like a Raspberry and a software like FHEM, Domoticz, OpenHAB or similiar.
As even a Raspberry can handle a (small) database, it would be much more comfortable this way.
The ESP just reads the tag, sends data and receives the "Open" command when the tag is valid.
Hello again and thanks. From your answer i understand how poor my post was.
Scenario is:
- domoticz on raspberry pi
- esp8266 sending to idx XX the tag when read.
I work in a tennis club with 250 users and i need to create zones allowed to a part of them and park for all. I've done a test making all up for 1 tag and using events (i'm not a programmer so i use skratch ) and it works perfectly.
Problem is that i can't do it for 250 users. So what i need to do is to create a sort of user profiling (that is present in domoticz) and let this working with events (and this seems not possible in skretch unfortunetely).
The list should be editable (let me say a sort of csv somewhere to change in case of expiring for example).
Sorry again for the SMS i've sent before and I hope this new task is more clear.
Tnx to all.
Luca
Scenario is:
Tnx to all.
Luca
You have the hardware you need in place. Working. Fine.
You only have to find a system on domoticz or rasperry (python/bash-script) to handle the 250 keys....
There are certain many ways to do this...hmmm
This is maybe at least not the best thread for this certain programming task on domoticz/raspberry/linux ...
Anyway every tag/id is only around 15 characters, so 250 could be handled. Maybe takes longer to search through a list of 250tags, until door finally opens.
No impossible, but domoticz/raspberry is a cheap and powerful enough plattform to build up a control system for this 250 tags. But...it has to be build up somehow, i guess..
The ESP has only some KB of RAM.
Most of it is taken by ESPEasy already, so even if you flash a list of 250 tags to keep it out of memory, working off the list will be difficult with the left RAM.
Remember, at the actual state there is not enough ram for compiling all modules so the developer had to take off some modules already.
A rule set will work for some tags. with 250 tags the rule list is too long for memory and it might be too slow.
Yeap. I use spiff (Filesystem) to store static htm files. If i call them with Browser, it (sometimes) takes a bit, but it is always working. So 250 tags could go onto spiffs-filesystem in a text-file. This could easy be edited in Browser. There a some examples for this here in the forum. And example code parts on github for a Solutions like this.
But the full Solutions still needs to be sort of coded from this snippets...
But at least still doable on the espeasy, i believe..
For more Speed i would consider going on the rasperry/linux track...and still code there something...
From the "ESPEasy MEGA Forum Thread:
Surely it will be possible if you create a kind of "downgraded" or "naked" ESPEasy for a new plugin.
I agree it makes more sense to do that on a Raspberry-like device.
Regards and Happy Easter Ddays
I assume that a quasi-database function will take more memory then availlable.it wasn't actually a bug. with the new IR library we just hit our IRAM limit it seems. (and there is only 2-3k of IRAM to start with)
I created an overview of the different plugin sizes: https://github.com/letscontrolit/ESPEas ... _sizes.txt
I'm currently trying to reduce memory usage of the various plugins, but we might have to disable some plugins by default in the next versions.
I'm trying to connect a HID Miniprox to an esp8266-07 running esp easy mega. When I had it 'working' it wouldn't read everytime and would also return different values when it did.
Any tips?
Any tips?
hmmm, a HID-Device gives the Wiegand numbers or tag-ID as you would type it with a keyboard.
a HID-Device could also work as a mouse.
see: https://en.wikipedia.org/wiki/Human_interface_device
i think espeasy can control other device types, but not HID without modifications.
my you check again here: https://www.letscontrolit.com/wiki/index.php/Wiegand-26
My stepper motor website:skysmotor.com/- Machinery Design ? - ? Stepper Moter Development
"Necessity is the mother of invention." - Author unknown.
which reader? link?
what is your question?
Hello, I'd like to return to this reader (x660) but I've lost instructions with pinholes combination ( I remember something like 1881 etc.) Could I ask a picture of the manual? I couldn't find it anywhere.
I think I got it, found this video: https://youtu.be/Dg_3PBV6ZOE
Thank you,
Piotr
Thank you,
Piotr
Users browsing this forum: No registered users and 105 guests
