On MPRSx8 Home automation board you have:Dylantje wrote:Mmmm looks great
I see some PINS on the board (flashing)
Are there perhaps more PINS avaleble fit Just like a pir or dht sensor
- I2C / nEXT Bus compatible connector - you can add your own extension modules - light sensors, gas, motion, etc. They are already a lot available all over the place.
- Compatible with any I2C compatible MCU/Board: Arduino, ARM, PIC, ATMEGA, ESP8266, ESP32, RaspberryPI, etc
- ESP8266 friendly design: can add your ESP8266 module directly onboard for a full WIFI MAINS Power switchboard solution
- Full access to ESP8266 pins thru 2 headers gives you even more flexibility in developing your projects!
- Full programming header (Tx, Rx, GPIO0 and Reset)
That I think means a LOT of options and flexibility in terms of extension boards, sensors, etc, that you can use with.
You can add even a MPDMv4 Universal Dimmer Board for a full dimmable light channel for example.
Details about MPDMv4 Universal AC Dimmer board ESPEasy and Domoticz implementation can be found here: viewtopic.php?f=2&t=2362&hilit=mpdmv4
