Support for PZEM 004T Energy monitor
goldriver
Re: Support for PZEM 004T Energy monitor
#71 Post by goldriver » 15 Jan 2018, 12:38
Hi Alepho
I tried to compile using your directions below but I have error that I can't fgure out, could you help me with this please
First I would like to say that I am new to the ESP world and second I am new to compiling of firmware and ... english is not my primary language so please bare with me...
I'm trying to build a firmware that would include the PZEM004T plugin, I installed the Atom environment together with the PlateformIO and I have been able to build the vanilla ESPeasy bin file, not without issues (I had errors with the some IR that I removed from the build to fix) but I got it to build a firmware.
Then, I dowloaded the PZEM004T.io thast i added in the src directory and I also dowloaded the PZEM004.ZIP (containing the librairies, .h files etc) that I put in the lib directory and also download espsoftwareserial-3.2.3 in wich I modified the library.json as you mentionned and tried building a normal 4096 file and I got the following errors:
.pioenvs\normal_ESP8266_4096\lib298\libespsoftwareserial-3.2.3.a(SoftwareSerial.o): In function `sws_isr_0()':
SoftwareSerial.cpp:(.iram.text+0xd0): multiple definition of `sws_isr_0()'
.pioenvs\normal_ESP8266_4096\lib076\libSoftwareSerial.a(ESPeasySoftwareSerial.o):ESPeasySoftwareSerial.cpp:(.iram.
text+0xd4): first defined here
.pioenvs\normal_ESP8266_4096\lib298\libespsoftwareserial-3.2.3.a(SoftwareSerial.o): In function `sws_isr_1()':
SoftwareSerial.cpp:(.iram.text+0xe8): multiple definition of `sws_isr_1()'
text+0xec): first defined here
.pioenvs\normal_ESP8266_4096\lib298\libespsoftwareserial-3.2.3.a(SoftwareSerial.o): In function `sws_isr_2()':
SoftwareSerial.cpp:(.iram.text+0x100): multiple definition of `sws_isr_2()'
text+0x104): first defined here
*** [.pioenvs\normal_ESP8266_4096\firmware.elf] Error 1
thanks for any help
aleph0 wrote: 08 Nov 2017, 10:03 Hi, and thanks for making this nice plugin !
As I had to do some searching to finally compile and install it, here is a all-in-one summary of what needs to be done :
1/ Install and configure platform.io according to the instructions here :
https://www.letscontrolit.com/wiki/inde ... Platformio
then
https://www.letscontrolit.com/wiki/inde ... platformio
2/ Download the source tree from here :
https://github.com/letscontrolit/ESPEas ... .0.0-dev12 (or later version as there are being developed
3/ Download the plugin source from here and copy it in the main source
https://github.com/papperone/ESPEasyPlu ... M-004T.ino
4/ Download PZEM004T library from here and copy it in the lib subdirectory of the main source
https://github.com/olehs/PZEM004T
5/ Download SofwareSerial library in version 3.2.3 from here and copy it in the lib subdirectory of the main source
https://github.com/plerup/espsoftwarese ... /tag/3.2.3
6/ Update the library.json file that came from the softwareserial library with the following content :
    "name": "EspSoftwareSerial",
    "version": "3.2.3",
    "keywords": [
      "serial", "io", "softwareserial"
    "description": "Implementation of the Arduino software serial for ESP8266.",
    "repository":
        "type": "git",
        "url": "https://github.com/plerup/espsoftwareserial"
    "frameworks": "arduino",
    "platforms": "espressif8266"
(version was missing and platforms mispelled :( )
After that, I was able to compile espeasy with the plugin and send it to the esp via OTA :)
asking
#72 Post by asking » 18 Jan 2018, 02:40
aleph0 wrote: 06 Dec 2017, 13:15
sega2177 wrote: 06 Dec 2017, 04:08 Hello aleph0, could you put the compiled firmware with the plugin PZET-004?
Please find attached the version for 4Gb flash with all the "Testing" plugins enabled, including the PZEM-004T with my last modifications to handle two modules. Use "port" to select the module : port 0 for first module and port 1 for second module. Remember each module will take up to 12s to answer in case there is no voltage on the main terminal, so don't poll faster then 15s*the number of modules
Feedback is welcome !
aleph0 thanks for wonderful work...
But i need to know more about polling. If main line voltage is available ? what's the update rate ? Every second ? can i ?
asking
#73 Post by asking » 19 Jan 2018, 03:03
I have uploaded .bin file to ESP8266 but its not showing any hotspot in wifi search of my laptop.. have anyone tried this Flash ?
aleph0
#74 Post by aleph0 » 19 Jan 2018, 17:14
@asking
When everything goes well, one module answer within 1s. But if you poll faster than 12s/module, your espeasy will crash in case of no measurment voltage.
And, of course I tested the bin file, I uploaded the one I'm using here, it's been up for 50 days now and doing the job fine :-)
asking
#75 Post by asking » 22 Jan 2018, 05:03
aleph0 wrote: 19 Jan 2018, 17:14 @asking
What's your update rate you're testing? 🤔
Because if i poll faster than 5 seconds update frequency is not periodic and updates randomely.
Anyways its working great...i am looking for 1 second update rate if possible
aleph0
#76 Post by aleph0 » 22 Jan 2018, 05:22
Yes, it's not that surprising : once in a while a value is not coming, triggering the timeout (1s each) and the retry (3 times). It's been reported the quality of 5v supply have an influence on this.
If you want to be able to poll faster, you need to edit the source code to shorten the timeout and no retry. In that case I advise you keep the error value transmitted (-1) and to manage reading errors in the host instead of in esp
asking
#77 Post by asking » 22 Jan 2018, 05:31
Okay will try that, thanks for suggesting.
nicofly974
#78 Post by nicofly974 » 24 Jan 2018, 23:16
I'm new in esp easy,
I've a pzem004 with wemos mini pro and domoticz
I've put P171 of playground
I've tension and current in panel control of my ESP, but 0 for Power and Energy
Second problem, in domoticz I've icon pzem with: 0;232,1;0,23;0;0 icon Voltage 232,1 but nothing in the others icons
If you have an idear
Great thanks for this plugin
dcjona
#79 Post by dcjona » 25 Jan 2018, 10:46
aleph0 wrote: 13 Jan 2018, 21:55
dcjona wrote: 12 Jan 2018, 08:19 hello
no chance for me i tried but still 0...
i tried to plug to D5 and D6 on the wemos D& mini and also D3 and D4 but still the same ...
swap RX and TX done too
Voltage (V):233
Current (A): 0
Power (W): 0
Energy (Wh):45
any help please ?
As you get voltage value, it means the module communicates with the ESP. But you don't get current, thus no power : Check your CT
hi, yes i have 233 in voltage but nothing else
#80 Post by TD-er » 25 Jan 2018, 17:03
dcjona wrote: 25 Jan 2018, 10:46 [...]
Can you draw a schematic on how your module is connected?
The current is measured over a shunt resistor, but if no current passes through this shunt, nothing will be measured.
nicofly974
#81 Post by nicofly974 » 26 Jan 2018, 13:40
I've a current charge, in icon pezm1 I've 0.24A
but nothing in Energie and Power
Some idear?
dcjona
#82 Post by dcjona » 27 Jan 2018, 12:55
off course :
just like this but gnd and vcc on the wemos d1 mini
i tried D5-D6 and TX-RX -> same issue
zacaruca1
#83 Post by zacaruca1 » 16 Feb 2018, 20:51
Para los que teneis errores en la lectura, debeis modificar en la libreria espsoftwareserial-3.2.3 , el fichero SoftwareSerial.cpp la siguiente linea:
 unsigned long wait = m_bitTime + m_bitTime/3 - 500;
por esta otra:
 unsigned long wait = m_bitTime + m_bitTime/2 - 500;
For those who have errors in reading, you must modify in the library espsoftwareserial-3.2.3, the SoftwareSerial.cpp file the following line:
unsigned long wait = m_bitTime + m_bitTime / 3 - 500;
for this other:
unsigned long wait = m_bitTime + m_bitTime / 2 - 500;
Raspi_0x00
#84 Post by Raspi_0x00 » 22 Mar 2018, 08:19
Please forgive me but I'm new.
I have ESP12 and PZEM004 that I successfully used for one year sending data to ThingSpeak.
Now I have Demoticz system + ESPEasy. And I woudl like to add this energy meter to my system.
I downloaded bin file from:
download/file.php?id=1760
and uploaded to my ESP12.
Everything is OK beside reading of energy meter values, all are -1.
I think everything is OK from HW side but as I can see I have problem with correct settings of RX, TX lines in ESPeasy SW.
According to the doc I should use GPIO1 and GPIO3. But these lines are inactive in ESPeasy SW.
Could you help me in this case?
Raspi_0x00
#85 Post by Raspi_0x00 » 22 Mar 2018, 21:35
Raspi_0x00
#86 Post by Raspi_0x00 » 27 Mar 2018, 11:24
Problem solved. Works grate!!! The problem was that my PCB was configured for use UART0 (GPIO1..3).
When I changed do 13-15 everything is OK.
But I wonder why the Voltage measurement is such unstalble ( I get -1 in most readings).
Any ideas? Update rate is 1min
drfranky
#87 Post by drfranky » 02 Apr 2018, 14:47
Hello from yesterday I trying to configure PZEM 004 with ESP.
Everything is fine but some of the values are not correct. I mean the power is incorrect.
As you can see from screenshot ESP shows power 22W but should be 236.4 V * 0.18A = 42.55 W.
Can you tell me please how I can solve this issue?
I tried with formulas but without success.
papperone
#88 Post by papperone » 02 Apr 2018, 18:24
drfranky wrote: 02 Apr 2018, 14:47 Hello from yesterday I trying to configure PZEM 004 with ESP.
With this module the ESPEasy plugin does nothing but fetching the numbers from the module and use them as they are.
There's no calculation beside the ones done by the PZEM-004T itselft, so i can only guess the module you have does not work properly...
#89 Post by TD-er » 02 Apr 2018, 22:32
papperone wrote: 02 Apr 2018, 18:24
I'm not (yet) familiar with the module. But is it possible the power in Watt is correct and also the current and voltage, but that there is some cos-phi acting up here?
What kind of load is connected to the sensor? Something with a true resistive load, like a heating element or something with an inductive load like an elektro motor or some switching power supply?
drfranky
#90 Post by drfranky » 03 Apr 2018, 10:15
TD-er wrote: 02 Apr 2018, 22:32
The load is power supply for my laptop. There is no cos-phi variable.
I tried to fix this with formulas in Easyesp but I don't know what is the variable for Voltage and Current in the fields.
papperone
#91 Post by papperone » 03 Apr 2018, 13:17
All the calculations are performed by the module itself, the plugin is simply reading data trough softserial and update the device variables.
As in my 2 modules the data are reported correcly (as in some of the screenshot I posted previously) and not knowing any calibration is possible with those devices, I see as only diagnosys that this module is faulty....
#92 Post by TD-er » 03 Apr 2018, 20:11
The cos phi is the phase shift between voltage and current.
So it is perfectly acceptable when the power in Watt is lower than the power in VA. It simply mean the cos phi is not 1 and thus there is a phase shift.
A switching power supply without power factor correction (essentially eliminating cos phi phase shift) usually has a cos phi of about 0.6, which means that a power of 100 VA results in 0.6*100 = 60 Watt.
Please try the measurement with something with a resistive load, like an oldfashioned glowing light bulb or a heating element and you'll see the power in Watt equals voltage * current.
For inductive loads (that result in a phase shift of current) the cos phi will be less than 1 and thus the power in Watt is lower than V * A.
With a cos phi of 1, the sinus of Voltage and the sinus of current are perfectly in sync. That means the current is 0 when voltage is 0 and max when voltage is max.
With inductive loads, the sinus of the current will shift a little, meaning the peak of the current is not at the moment of the voltage peak.
And with switching power supplies the curve of the current is not even a sinus anymore and its peak is very unlikely to be at the peak of the voltage.
In short:
V * A = VA
V * A * cos phi = Watt.
On electric motors, you often see a cos phi mentioned.
DaveS
#93 Post by DaveS » 03 May 2018, 19:24
Hi All,
Have flashed a wemos D1 mini and a nodemcu module with the firmware build posted on this thread (ESPEasy-2.0.0-dev12_test_4096.bin.zip) with the same results.
All options can be configured with no issues until selecting the PZEM004 as a device and configuring GPIO's and pressing submit radio button the device becomes unresponsive,no reply to ping after this.
A reboot will show all -1 values under devices,pages are very slow to open in browser.
Have powered ESP8266 from PC's USB port as well as a mobile phone charger so do not think 5 volt power is a problem.
PZEM module works perfectly when tested on an arduino and on ESP8266 using enode firmware file after doing R17 resistor mod for 3v3 operation.
Is there a fix for this or a later build of ESPeasy that supports the PZEM-004 module ?
Dave
maluko
#94 Post by maluko » 04 May 2018, 12:31
hi
look at this acessorio to pzem 004t :)
http://www.movimentomaker.pt/t/bh-pzem- ... -wi-fi/234
DaveS
#95 Post by DaveS » 04 May 2018, 17:46
Thank you maluko.
Will compile this and test it.
Only need MQTT functionality !
dio45rus
#96 Post by dio45rus » 11 May 2018, 11:21
Voltage (V):233
Current (A): 0
Power (W): 0
Energy (Wh):45
any help please ?
I suspect that you pull all wires of the cable throught current transformer, but need only one of them.
Sabado
#97 Post by Sabado » 29 May 2018, 20:38
Hello, i am completely new and lost too.
I try to link a Pezm-004t with a wemos D1 R2 board.
my goals are monitoring my energy consumption, diverting the current i don't use at any moment, with some opto couplers relays, and data-log the currrent from my solar panels.
at the very moment :
i link the Pzem-004t to a source with a load. i have 235 volts on the curent input, and the coil on pin 3 4.
RX,Tx from Pzem are connected to TX,RX on Wemos D1R2 pin 8 9.ground to GND, and 5V (Pzem) to 5V (Wemos).
Running the PzemDisplay example(modified with PZEM004T pzem(8 ,9); // (RX,TX) connect to TX,RX of PZEM)
i have allways -1.00V , with RX,TX connected or not.
at this time, i have no idea about what i may try to have results.
Please, do you have any idea?
Best regards
Raspi_0x00
#98 Post by Raspi_0x00 » 07 Jun 2018, 14:09
I wonder how can I use 3 phase measurements.
The best would be to use one ESP module and use address of 3 PZEM modules. But fist thing is to set address to each module for each phase.
As I can see Espeasy FW dosn't support using of 3 modules or using of different address. Do you have any idea how can we find solutuion for 3 phase measurements?
aleph0
#99 Post by aleph0 » 07 Jun 2018, 14:13
Yes... but I stopped at 2 modules because I didn't like the solution I programmed... I need to work again on this subject ;-)
Raspi_0x00
#100 Post by Raspi_0x00 » 21 Jun 2018, 10:28
When do you think, you finish new version of FW to handle 3 PZEM modules?
ut1545
#101 Post by ut1545 » 08 Jul 2018, 18:26
I'm trying to compile last ESPeasy V2.0 release (ESPEasy-2.0-20180510) but I'm getting the same errors as #71 http://www.letscontrolit.com/forum/view ... 585#p22585.
Did anyone solve this issue? How to compile this plug in under the latest releases of ESPeasy software?
Thanks in advance,
asking
#102 Post by asking » 12 Jul 2018, 16:04
Raspi_0x00 wrote: 27 Mar 2018, 11:24 Hi,
i am also getting same error -1 randomely inbetween 1 minute readings... did you solved it ? what was the issue ? can you share ?
aleph0
#103 Post by aleph0 » 13 Jul 2018, 08:55
I have two pzem connected to my wemos ; I've also got this problem on one of them :-( I never understood what was the cause, I simply ignore wrong reading in domoticz. Not very satisfying, but enough for my purpose
asking
#104 Post by asking » 13 Jul 2018, 18:01
aleph0 wrote: 13 Jul 2018, 08:55 I have two pzem connected to my wemos ; I've also got this problem on one of them :-( I never understood what was the cause, I simply ignore wrong reading in domoticz. Not very satisfying, but enough for my purpose
Do you think its related to software library of arduino ? or TTL 5V to 3.3V Converter issue ?
aleph0
#105 Post by aleph0 » 13 Jul 2018, 18:18
asking wrote: 13 Jul 2018, 18:01 Do you think its related to software library of arduino ? or TTL 5V to 3.3V Converter issue ?
I don't think so as the 2 pzem are connected on the same module, so same software library ; I also don't use any converters and connected 5V to GPIO directly. This is not conventional but I wanted to make a test and it's working 24/7 since last november, so I think it's safe enough ;-)
It's something related to either the pzem itselft, or the GPIO used to connect them. But as my setup is now kinda "in production" I cannot make any tests anymore :-(
I plan to buy some more for another equipment, it'll give me another testing possibility. But it'll be in a month or so
miki_tnt
#106 Post by miki_tnt » 14 Aug 2018, 11:37
Dear all,
i have tried to compile the _P171_PZEM-004T.ino plugin (last version 8 months ago) and I get some errors and warnings:
lib/AS_BH1750/AS_BH1750A.cpp: In member function 'bool AS_BH1750A::startMeasurementAsync(TimeFuncPtr)':
lib/AS_BH1750/AS_BH1750A.cpp:518:7: warning: unused variable '_lastResult' [-Wunused-variable]
int _lastResult = -1;
lib/AS_BH1750/AS_BH1750A.cpp: In member function 'bool AS_BH1750A::delayExpired()':
lib/AS_BH1750/AS_BH1750A.cpp:533:19: warning: comparison between signed and unsigned integer expressions [-Ws
ign-compare]
if (timestamp < _lastTimestamp)
lib/AS_BH1750/AS_BH1750A.cpp:536:45: warning: statement has no effect [-Wunused-value]
delayTime = MAX_U_LONG - _lastTimestamp + timestamp;
lib/AS_BH1750/AS_BH1750A.cpp:542:24: warning: comparison between signed and unsigned integer expressions [-Ws
ign-compare]
return (delayTime >= _nextDelay);
ESPEasy-mega-20180809/src/_P171_PZEM-004T.ino: In function 'boolean Plugin_171(byte, Eve
ntStruct*, String&)':
ESPEasy-mega-20180809/src/_P171_PZEM-004T.ino:69:68: error: too many arguments to functi
on 'void addFormNote(const String&)'
addFormNote(string, F("SoftSerial: 1st=RX-Pin, 2nd=TX-Pin"));
ESPEasy-mega-20180809/src/WebServer.ino:2788:6: note: declared here
void addFormNote(const String& text)
Could anybody help me with these issues?
#107 Post by TD-er » 14 Aug 2018, 13:56
The signed/unsigned warning can be ignored.
The errors in WebServer.ino are also quite simple to resolve.
The functions used there in the "PLUGIN_WEBFORM_LOAD" case no longer need the first parameter "string"
So just remove that parameter:
Change it into:
addFormNote(F("SoftSerial: 1st=RX-Pin, 2nd=TX-Pin"));
papperone
#108 Post by papperone » 14 Aug 2018, 18:46
I need to review this plugin in order to move it to the standard repository...
honestly still same issue, lack of time to improve it making it working with multiple devices (e.g. to monitor multiple lines or 3-phase AC).
miki_tnt
#109 Post by miki_tnt » 16 Aug 2018, 19:15
yes, you are right, I already corrected the error regarding addFormNote function, but I am getting more errors after the warning
ESPeasySoftwareSerial.cpp:(.iram.text+0xd4): multiple definition of `sws_isr_0()'
.pioenvs/normal_ESP8266_1024/lib010/SoftwareSerial/SoftwareSerial.cpp.o:SoftwareSerial.cpp:(.iram.text+0xf8):
first defined here
.pioenvs/normal_ESP8266_1024/libc99/ESPEasySoftwareSerial/ESPeasySoftwareSerial.cpp.o: In function `sws_isr_1
ESPeasySoftwareSerial.cpp:(.iram.text+0xec): multiple definition of `sws_isr_1()'
.pioenvs/normal_ESP8266_1024/lib010/SoftwareSerial/SoftwareSerial.cpp.o:SoftwareSerial.cpp:(.iram.text+0x110)
.pioenvs/normal_ESP8266_1024/libc99/ESPEasySoftwareSerial/ESPeasySoftwareSerial.cpp.o: In function `sws_isr_2
ESPeasySoftwareSerial.cpp:(.iram.text+0x104): multiple definition of `sws_isr_2()'
.pioenvs/normal_ESP8266_1024/lib010/SoftwareSerial/SoftwareSerial.cpp.o:SoftwareSerial.cpp:(.iram.text+0x128)
collect2: error: ld returned 1 exit status
*** [.pioenvs/normal_ESP8266_1024/firmware.elf] Error 1
========================== [ERROR] Took 59.91 seconds ==========================
Environment normal_ESP8266_1024 [ERROR]
#110 Post by TD-er » 16 Aug 2018, 21:49
Hmm, that's very strange, I only got those errors when building the latest ESP32 code.
Try to run a "clean" build first before recompiling.
miki_tnt
#111 Post by miki_tnt » 16 Aug 2018, 23:00
Thank you very much.
Yes, it is very strange. I have cleaned the project and compiled it again but no luck... I dont understand what it is going on. I am using last mega release.
Any other suggestion will be appreciated.
kind regards,
Dim33
#112 Post by Dim33 » 29 Aug 2018, 00:16
Hello everybody,
My energy measurement is operationnal by following this post and this one http://www.domoticz.com/forum/viewtopic ... 14&t=20820
I use an ESP8266_4096.
But I have a problem :
- if I boot my ESP connected to the PZEM. My ESP doesn't start (no effect if I push on RESET button),
- If I boot my ESP (not connected to the PZEM), this one start normaly and after i can connect the PZEM to the ESP and the Energy measurement is OK.
This problem is painful because if i have a power cut, my Energy measurement does not restart.
Can you help me ?
Thanks in advance.
#113 Post by TD-er » 29 Aug 2018, 13:28
Maybe you connected the sensor to one of the pins needed to indicate the boot-mode?
For example GPIO0, which is connected to the "Flash" button on NodeMCU boards, will put the ESP into flash mode when pressed.
I can imagine the sensor will do the same when connected to that pin.
Dim33
#114 Post by Dim33 » 30 Aug 2018, 22:56
Dim33 wrote: 29 Aug 2018, 00:16 Hello everybody,
Can you help me ?
Thanks in advance.
I modified the GPIO pin : GPIO-12 and 13 instead of GPIO-14 and 15 and all is OK.
pppp33
#115 Post by pppp33 » 30 Aug 2018, 23:17
Hi there,
I've got a PZEM an tried to compile, but got same "multiple definition" error, as miki_tnt :
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\SoftwareSerial.cpp.o: In function `sws_isr_0()':
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\ESPeasySoftwareSerial.cpp.o:ESPeasySoftwareSerial.cpp:(.iram.text+0xd4): first defined here
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\SoftwareSerial.cpp.o: In function `sws_isr_1()':
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\ESPeasySoftwareSerial.cpp.o:ESPeasySoftwareSerial.cpp:(.iram.text+0xec): first defined here
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\SoftwareSerial.cpp.o: In function `sws_isr_2()':
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\ESPeasySoftwareSerial.cpp.o:ESPeasySoftwareSerial.cpp:(.iram.text+0x104): first defined here
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z21Plugin171_ReadVoltagev+0x8): undefined reference to `PZEM004T::voltage(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o: In function `Plugin171_ReadVoltage()':
ESPEasy.ino.cpp:(.text._Z21Plugin171_ReadVoltagev+0x25): undefined reference to `PZEM004T::voltage(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z21Plugin171_ReadCurrentv+0x0): undefined reference to `PZEM004T::current(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z21Plugin171_ReadCurrentv+0x1d): undefined reference to `PZEM004T::current(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z19Plugin171_ReadPowerv+0x0): undefined reference to `PZEM004T::power(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z19Plugin171_ReadPowerv+0x1d): undefined reference to `PZEM004T::power(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z20Plugin171_ReadEnergyv+0x0): undefined reference to `PZEM004T::energy(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o: In function `Plugin171_ReadEnergy()':
ESPEasy.ino.cpp:(.text._Z20Plugin171_ReadEnergyv+0x1d): undefined reference to `PZEM004T::energy(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z10Plugin_171hP11EventStructR6String+0x1c): undefined reference to `PZEM004T::PZEM004T(unsigned char, unsigned char)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z10Plugin_171hP11EventStructR6String+0x20): undefined reference to `PZEM004T::setAddress(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o: In function `Plugin_171(unsigned char, EventStruct*, String&)':
ESPEasy.ino.cpp:(.text._Z10Plugin_171hP11EventStructR6String+0x14e): undefined reference to `PZEM004T::PZEM004T(unsigned char, unsigned char)'
ESPEasy.ino.cpp:(.text._Z10Plugin_171hP11EventStructR6String+0x15b): undefined reference to `PZEM004T::setAddress(IPAddress con
Is there any suggestion to overcome this issue ?
Perhaps something changed in libraries, etc. in the last months ?
Thanx & Regards
Paolo
GieBek
#116 Post by GieBek » 30 Nov 2018, 23:34
Would it give advice to throw the plugin into the latest software. PZEM has been working very well for me for half a year but I miss some features from the new software.
Greetings.
#117 Post by grovkillen » 30 Nov 2018, 23:38
Please open an issue for it on GitHub and ask the maintainer to add it as a PR.
GieBek
#118 Post by GieBek » 01 Dec 2018, 00:01
Thank you very much for your answer.
I did what you wrote.
Greetings.
GieBek
lyovav
#119 Post by lyovav » 10 Dec 2018, 12:13
hnaeem07
#120 Post by hnaeem07 » 23 Dec 2018, 13:25
I am not getting correct value for Watts when i did the calculation, example as below
Actual reading from meter = 232.20 Volts , 2.89 Amps, 665.00 Watts, 1311707.00 KWH
232.20 x 2.89 = 671.06 Watts, but in the meter it shows 665.00, can i know why its not accurate ?
Thanks in advance. :D
