viewtopic.php?f=5&t=5195#p27307
https://github.com/letscontrolit/ESPEasy/releases
Sonoff 4CH with ESPEasy
- Methuselah
Re: Sonoff 4CH with ESPEasy
N00b to the world of ESPEasy, but I've been programming since the days of punch cards and paper tape
Sorry for the thread hijack, but I am also trying to connect a Sonoff 4ch Pro to that same Harbor Freight winch in order to automate a grain dryer. Any chance you can share your wiring schematic so I can see what wires on the winch are hooked to the Sonoff and where? I've figured out how to unspool the winch, but I can not figure out how I need to wire it to spool-in the winch. Any guidance you can give me would be VERY appreciated.Methuselah wrote: ↑20 Feb 2018, 18:39
The bottom sonoff is used to control a winch to automatically raise and lower the tower fixture (a TX-455 crank up, retrofitted with a KF9P hoist plate and harbor freight 2000 lb hoist (see https://www.youtube.com/watch?time_cont ... TQiq-WGNFE). One relay is used to power on and off the hoist w/ 120vac (switching the hot wire), and two relays are used to select up or down motion (by directing current to one of two wires).
Here's more info on what I'm working on.
https://community.home-assistant.io/t/n ... t/65100/28
Users browsing this forum: Bing [Bot] and 111 guests
