FLASH Wifi Relay
Re: FLASH Wifi Relay
Thank you for this explanation.
For Tasmota it's only in DOUT so I thank this could fix the thing but with espeasy how can I do that ?
in the released binaries is one with dout in the name. (there should be one)
Not sure to understand... For 1024 their is
ESP_Easy_mega-20180302_dev_ESP8266_1024.bin
ESP_Easy_mega-20180302_dev_ESP8266PUYA_1024.bin
ESP_Easy_mega-20180302_dev_ESP8266PUYA_1024_VCC.bin
ESP_Easy_mega-20180302_dev_ESP8285_1024.bin
ESP_Easy_mega-20180302_normal_ESP8266_1024.bin
ESP_Easy_mega-20180302_normal_ESP8285_1024.bin
ESP_Easy_mega-20180302_test_ESP8266_1024.bin
ESP_Easy_mega-20180302_test_ESP8285_1024.bin
So wich one ? because I can not see DOUT... Help please...
You could try my Flasher and force DOUT checked.
@grovkillen Thank you for your tool, I tried and I ahve an error :
Any help please...
######2018-03-03######
#######0.00.021#######
######FLASH INFO######
BIN file: ESP_Easy_mega-20180302_normal_ESP8266_1024.bin
COM port: (COM3) USB Serial Port
Baud rate: 115200
! FORCED DOUT ENABLED !
######POST FLASH######
No post flash information entered...
######FLASH LOG######
[esptool.exe -vv -bm dout -cd nodemcu -cb 115200 -cp COM3 -ca 0x00000 -cf "P:\Domotique\NEW\BIN\ESP_Easy_mega-20180302_normal_ESP8266_1024.bin"]
[03/03/2018 15:26:20] esptool v0.4.12 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
[03/03/2018 15:26:20] setting flash mode from qio to dout
[03/03/2018 15:26:20] setting board to nodemcu
[03/03/2018 15:26:20] setting baudrate from 115200 to 115200
[03/03/2018 15:26:20] setting port from to COM3
[03/03/2018 15:26:20] setting address from 0x00000000 to 0x00000000
[03/03/2018 15:26:20] espcomm_upload_file
[03/03/2018 15:26:20] espcomm_upload_mem
[03/03/2018 15:26:20] setting serial port timeouts to 1000 ms
[03/03/2018 15:26:20] opening bootloader
[03/03/2018 15:26:20] resetting board
[03/03/2018 15:26:20] trying to connect
[03/03/2018 15:26:20] flush start
[03/03/2018 15:26:20] setting serial port timeouts to 1 ms
[03/03/2018 15:26:20] flush complete
[03/03/2018 15:26:20] espcomm_send_command: sending command header
[03/03/2018 15:26:20] espcomm_send_command: sending command payload
[03/03/2018 15:26:20] read 0, requested 1
[03/03/2018 15:26:20] espcomm_send_command: receiving 2 bytes of data
[03/03/2018 15:26:20] Uploading 608112 bytes from P:\Domotique\NEW\BIN\ESP_Easy_mega-20180302_normal_ESP8266_1024.bin to flash at 0x00000000
[03/03/2018 15:26:20] erasing flash
[03/03/2018 15:26:20] size: 094770 address: 000000
[03/03/2018 15:26:20] first_sector_index: 0
[03/03/2018 15:26:20] total_sector_count: 149
[03/03/2018 15:26:20] head_sector_count: 16
[03/03/2018 15:26:20] adjusted_sector_count: 133
[03/03/2018 15:26:20] erase_size: 085000
[03/03/2018 15:26:20] setting serial port timeouts to 15000 ms
[03/03/2018 15:26:20] writing flash
[03/03/2018 15:26:29] ................................................................................ [ 13% ]
[03/03/2018 15:26:39] ........................................................................... read 0, requested 1
[03/03/2018 15:26:39] warning: espcomm_send_command: didn't receive command response
[03/03/2018 15:26:39] warning: espcomm_send_command(FLASH_DOWNLOAD_DATA) failed
[03/03/2018 15:26:39] read 0, requested 1
[03/03/2018 15:26:39] closing bootloader
[03/03/2018 15:26:39] flush start
[03/03/2018 15:26:39] setting serial port timeouts to 1 ms
[03/03/2018 15:26:39] setting serial port timeouts to 1000 ms
[03/03/2018 15:26:39] flush complete
[03/03/2018 15:26:39] error: espcomm_upload_mem failed
[2018-03-03 15:26:39] DONE! BUT WITH (1) ERRORS!
[2018-03-03 15:26:39] JOB COMPLETED, over and out!
Tried more than once?
OK I tried few times and now no more errors on flash but my sonoff never boot, no led on, no wifi hotspot... I will try all *1024.bin files just in case...
Did you post flash with dhcp or just a plain flash?
Not sure to understand what you mean but if your question is to know if I fill in the "Post Flash Action" of your tool the answer is no.
First I just want my sonoff to boot to be sure everything is OK and I need its MAC adress to add it to my network.
Aha, sorry but I thought you did the programming with the tool since the AP might take some minute to get active in worst case.
@Grovkillen: The firmware itself should also be compiled with DOUT.
Could you try one of these, I compiled this morning for someone else: https://www.dropbox.com/s/w71xizrdgv0jx ... r.rar?dl=0
It's branch v2.0 of this morning.
I did it !!! after the first try of this french tuto : http://www.compu-tek.fr/blog/1325-2/ and using the tools on this website with this firmware : ESP_Easy_mega-20180302_normal_ESP8266_1024.bin
So I don't know what was wrong before but now my garage door is connected with my sonoff sv powered by the garage door opener battery backup !!!
Thank you for your help
I may have missed it looking through the comments, but is the relay on this on the same GPIO port as the standard sonoff modules? GPIO 12? I see GPIO 14, 4 and 5 on the headers, but not sure what the relay is.
Users browsing this forum: No registered users and 112 guests
