New Itead based Wall Switch
Re: New Itead based Wall Switch
nice, no i waited for 3 weeks and it said it didn't even shipped. They gave me the money back but I couldn't read much. it was hard enough to login with the forced 2fa. i mean dont get me wrong i love 2fa but if i have the option to enable it and i can read the website.../ texts they send (which I cant)
It may be done with a plugin. Are there any information about used serial commands? Similar to Sonoff Dual?
hi drbrains,
I've flashed espurna on it,
I can turn on/off the touch from espurna webpage, but the switch status is not updated if I manually turned the the switches off/on.
Can you share how you configured it?
Are you still talking about the discontinued "Touch" 2 channel switch?
I saw ITEAD has deployed a new line of switch, called "Sonoff T1" which are available in 1, 2 and 3 channel configuration.
Anyone got any? Would be great to understand the hardware and if ESPEasy pluing can be then written...
No, it's the same tantech switch that drbrains posted beforepapperone wrote: ↑10 Jul 2017, 17:59Are you still talking about the discontinued "Touch" 2 channel switch?
I actually a have few other wifi switch that are also ESP8285 based (using PSFB85 https://www.itead.cc/psf-b85.html)
https://goo.gl/photos/xzGnCyVKFUs284H89
https://goo.gl/photos/Q7zgtRbWN1BeszJw8
Those work right away after I flashed sonoff 4ch of the espurna firmware.
But it's not really working properly with this tantech
I think the newer Sonoff T1 might be using the PSFB85 chipset
PCB tracks for AC are ridiculous on those units you just posted pictures; I won't install them in my house!!
My philosophy si different and my system is designed to work differently, surely it requires more rewiring and is more exepnsive but I truly believe is safer.
I'll post some pictures / info as beside the hardware (which is custom made) I am working to have all nodes rurring ESPEasy!
Sonoff Touch T1 is based on the same PSF-B04 chip so to get into flash mode you have to ground GPIO0 as usual. I successfully uploaded Tasmota firmware into 2 gang version of T1.
If you use +/-10watt led lights, you're talking about 0.05Ampspapperone wrote: ↑11 Jul 2017, 07:21 PCB tracks for AC are ridiculous on those units you just posted pictures; I won't install them in my house!!
A 0.2mm tick cable can handle that amperage, looks safe to me.
Of course if one is using higher power lamps, then that's a different story
Even those 0,05A circuits might produce a short circuit.
Users browsing this forum: No registered users and 41 guests
