So I'm just gonna document here..
Got my FTDI232 device and found drivers here:
http://www.ftdichip.com/Drivers/VCP.htm
Then connected the FTDI232 and the esp8266 this way:
http://iot-playground.com/blog/2-uncate ... are-update
And followed the flash instructions here:
http://www.letscontrolit.com/wiki/index ... are_Upload
I had to do it twice, before it worked..
PIR in 3.3V and ESP8266-01
Re: PIR in 3.3V and ESP8266-01
It only runs on standart power, if I connect both the VCC and the CH_PD to 3,3V
Hi Justblair please could you share your PIR Sonoff configuration and rules?
Justblair wrote: ↑22 Feb 2017, 10:04 I am using a PIR module with a Sonoff wireless smart switch.
https://www.itead.cc/sonoff-wifi-wireless-switch.html
I modified the PIR module to bypass its 3.3v power regulator and then connected the PIR sensor to the 3.3v power header in the Sonoff switch.
Works very reliably in my kitchen switching my under unit and other spotlights. Love it. The sonoff is very reasonably priced, and basically gives you everything that you need to complete the project.
espeasy.items
espeasy.rules
On the Sonoff:
rule
Task 1: System Uptime (not needed really)
Task 2:
Task 3:
Switch kitchenPIR "Kitchen Motion Sensor" <kitchen> (Sensor) { mqtt="<[broker:/KitchenMood/pir/Switch:command:ON:1],<[broker:/KitchenMood/pir/Switch:command:OFF:0]" }
Switch kitchenDownlights "Kitchen Lights" <light> (lights,downstairs_lights,backroom_lights) [ "Switchable" ] { mqtt=">[broker:/KitchenMood/gpio/12:command:ON:1],>[broker:/KitchenMood/gpio/12:command:OFF:0]" }
var Number counter = 0
var Number lastCheck = 0
rule "kitchenLightOn"
when
Item kitchenPIR changed from OFF to ON
then
counter = counter + 1
//sendCommand(br_x10_lamp, ON)
sendCommand(kitchenDownlights, ON)
end
rule "kitchenLightOff"
when
Time cron "0 0/3 * * * ?"
then
if(lastCheck == counter) {
counter = 0
lastCheck = -1;
//sendCommand(br_x10_lamp, OFF)
sendCommand(kitchenPIR, OFF)
sendCommand(kitchenDownlights, OFF)
} else {
lastCheck = counter
end
rule
on pir#Switch do
if [pir#Switch]=0
gpio,13,1
gpio,13,0
Task 2:
Device: Switch input
Delay: 0 (Optional for this device)
IDX / Var: 1
1st GPIO: GPIO-12
Pull UP: false
Inversed: false
Switch Type: switch
Switch Button Type: Normal Swtch
Send Boot state: false
Send Data: true
Global Sync: false
Optional Settings Value
Value Name 1: Switch
IDX / Var: 5
1st GPIO: GPIO-12
Pull UP: false
Inversed: false
Switch Type: Switch
Switch Button Type: Normal Switch
Send Data: true
Global Sync: false
Users browsing this forum: No registered users and 117 guests
