The neighboring project uses 1M firmware with no SPIFFS, and esptool with "dout" mode, i suppose you did not.zedd wrote: ↑22 Jun 2018, 11:34 I flashed the standard ESPEasy_R120_4096.bin, which did not work and ESPEasy_Mega_P165_4M_1MS_lwip20 from this discussion. Neither caused the ESP_-access point to show.
Reattaching the board to the rest of the device make all LEDs light up - it knows somethings wrong !
Will try more later.
Yewelink/Tuya WiFi Touch wall light switch
Re: Yewelink/Tuya WiFi Touch wall light switch
I never heard this brand. But I like it
Smart home will finally come in our future living.
Knowing how to run a smart home device is sufficient and necessary.
I got this similar device today but unfortunately I cannot get it into reset mode to pair with phone app. So I decided, if I can flash it with different firmware and found this post.enesbcs wrote: ↑28 Jun 2018, 07:12The neighboring project uses 1M firmware with no SPIFFS, and esptool with "dout" mode, i suppose you did not.zedd wrote: ↑22 Jun 2018, 11:34 I flashed the standard ESPEasy_R120_4096.bin, which did not work and ESPEasy_Mega_P165_4M_1MS_lwip20 from this discussion. Neither caused the ESP_-access point to show.
Did you guys able to flash it and get it worked? If so, how.
By the way, the
is a capacitaive touch ICCR302 B751T004BG
Hello All, Need help regarding Tuya 4 gang Wifi Touch Wall light switch.
It has TYWE3S with esp8266 wifi chip. It also has MCU. I want to reprogram it and want to use it in home assistant. I also attaching its board view. Does anybody have its schematic or GPIO function list or some helpful material?
Also what is the IC number of MCU?
- 4 gang wifi switch pcb_4.jpg (289.51 KiB) Viewed 630778 times
Users browsing this forum: Google [Bot] and 110 guests
