So, I was able to flash this anonymous dimmer, only to discover the default ESPEasy does not work. Flashing
did work however.
I had to make the connections to the ESP manually "by hand", as you can see in the photo's.
- IMG_20180622_111910.jpg (647.23 KiB) Viewed 640889 times
- IMG_20180622_111901.jpg (862.59 KiB) Viewed 640889 times
Not easy and you have to keep your hand really steady, but it worked. You can't really see, but I'm holding two pins (RX and TX). The yellow wire holds GPIO0 down.
Sorry for using similar colors, they don't come out right in the photo. Wiring is as follows:
- Brown = GDN
- Bright yellow = VCC 3.3V (next to brown)
- Darker yellow = GPIO0, attached to GND
- Red - TXD
- Green - RXD
I flashed the standard ESPEasy_R120_4096.bin, which did not work and ESPEasy_Mega_P165_4M_1MS_lwip20 from
this discussion. Neither caused the ESP_-access point to show.
Reattaching the board to the rest of the device make all LEDs light up - it knows somethings wrong
Will try more later.
