Sonoff Basic - AP not apearing on first boot with pre-built BIN
Re: Sonoff Basic - AP not apearing on first boot with pre-built BIN
i read somewhere in the INet should used the DOUT mode for programming.
i do this with the ESP Flash Download Tool V2.3 and now one Sonoff is working !!!!
later i will check the other sonoff's
Edit: other modules now also working after flshing in DOUT mode. it's crazy the radio Button SPI Mode jumps back to QIO Mode after start programming.
It would be good if someone would add this info to the Wiki. I'd do it myself, but I don't believe I have the access to it?
Andrew
Andrew
Serial output?shanekuz wrote: ↑13 Aug 2017, 06:19LisaM wrote: ↑12 Aug 2017, 11:12Fix for what? You're telling exactly... nothing.shanekuz wrote: ↑11 Aug 2017, 23:57 Hi is there any fix for this yet? I have two SONOFF units and they worked fine until i flashed them with the same settings as above and now they dont seem to do anything.
If i boot them with the button pressed they still go into upload mode as if i dont press the button the upload tool errors so i know they are not dead. When they boot after the firmware update there is no led activity on the unit and it does not appear as a wifi AP.
Any help would be great.
"When they boot after the firmware update there is no led activity on the unit and it does not appear as a wifi AP." others seem to follow.
Flash method?
Unfortunately, i'm not telepatic. You need to tell us as much details as possible. For you it's clear, but your environment is unclear to us...
I have tried both with the Arduino IDE and ESPtool.exe im pushing the 1024.bin image using a USB - TTL board using the 3.3V pin. If i dont boot the SONOFF with the button pressed then both applications fail to upload so the unit seems to be able to still be programmed.
If i boot the unit with the button pressed i cant telnet to it to run TTL commands which was a test i found so i cant run AT commands serial to the unit so it may be dead im not sure.
Which command did you use in Andruino IDE? And which FTDI chip did you use?seikan wrote: ↑08 Aug 2017, 17:33 It seems like the new Sonoff Basic are shipped with new chip.
Flashing using the Flash tool was done without error, but the AP will never get discovered.
I have to use the Andruino IDE to compile the latest firmware and flash it with DOUT mode to finally get it working.
Because I have the same problem .
Same problems using the flashtool from letscontrolit.
Got this working on my devices (china, last week) : By using the other tool from:
http://espressif.com/en/support/download/other-tools
Download: Flash Download Tools V3.4.9.2 (ESP8266 & ESP32)
http://espressif.com/sites/default/file ... .9.2_0.zip
Download latest ESPEasy 2.0 (dev 11) and unzip from
https://github.com/letscontrolit/ESPEasy/releases
I used: ESPEasy_v2.0.0-dev11.zip
https://github.com/letscontrolit/ESPEas ... -dev11.zip
Unzip the "Flash Download Tools" and run ESPFlashDownloadTool_v3.4.9.2.exe
Choose ESP8266 DownloadTool:
Select: ESPEasy_v2.0.0-dev11_normal_1024.bin in the tool (pressing ... button)
Type adres after @ 0x00000
Checkbox before the pathname checked.
Settings, CrystalFreq: 26M
SPI SPEED: 26.7 MHz
SPI MODE: DOUT
FLASH SIZE: 8MBit
Select your COM port (in my case COM3)
BAUD: 115200
Hit button Start.
After a while, the proces is finished.
Unplug and Replug the USB UART, de devices reboots (Picture shows Putty output)
Wifi AP SSID: ESP_EASY_0 appears.
Cheers.
SPI SPEED: 26.7 MHz
SPI MODE: DOUT
FLASH SIZE: 8MBit
BAUD: 115200
Hit button Start.
Cheers.
Same problem here with brand new Sonoff 4CH ! I can flash it without problem but Wifi sugnal never shows up I tried also in DIO mode for flash but not much more success !
USB-TTL adapter: CP2102
If you have any ideas what to test, I'm ready for it
Vincèn
Here is result of flash process:
Vincèn
vincen@Fixe-Ubuntu:~/Bureau$ esptool.py --port /dev/ttyUSB0 write_flash 0x00000 ESPEasy_v2.0.0-dev11_normal_1024.bin
esptool.py v2.0
Connecting....
Detecting chip type... ESP8266
Chip is ESP8266
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 1MB
Compressed 558896 bytes to 368923...
Wrote 558896 bytes (368923 compressed) at 0x00000000 in 32.6 seconds (effective 137.2 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting...
Hello vincen,
did you consider that the 4ch Sonoff does not use a ESP-8266? It is an ESP8285, a slightly different processor.
ESPEasy runs on the 4CH sonoff, but you have to compile a version for the other processor.
Thanks for the notice but I have read that with build of version 2 now the firmware works with both no ??
Completely lost here as I thought it was included by default in 2.0 version so I don't see the point to recompile it to get support for it ! In all matters if it needs to be recompiled I have to give up (never succeeded to follow all steps to setup environnment for that Or perhaps someone has the file avalaible for test ?LisaM wrote: ↑15 Aug 2017, 13:56Yes, but you cannot use the pre-compiled ESP8266 version...
You need to compile it yourself with Arduino IDE using the ESP8285 board.
Use the bin file ending with "8285". This is something that will be changed in the future since it is a bit confusing having the name that way. See this request: https://github.com/letscontrolit/ESPEasy/issues/444vincen wrote: ↑15 Aug 2017, 14:13Completely lost here as I thought it was included by default in 2.0 version so I don't see the point to recompile it to get support for it ! In all matters if it needs to be recompiled I have to give up (never succeeded to follow all steps to setup environnment for that Or perhaps someone has the file avalaible for test ?
Sorry LisaM but I confirm you that standard bin file of ESP2 works well as is on Sonoff 4CH I have Problem was with parameters of flash and here is correct command with bin file downloaded from github Once flashed, I just removed few seconds power supply from FTDI adapter to the Sonoff then plugged it back and after few seconds my favorite ESP wifi signal popped up Unhappy I can't go further When I succeed to access the captive web portal and setup my Wifi, I get the notification to wait 20s but at the end it comes back as ESP_Easy instead of connecting to Wifi. I have already few ESP modules connected to Wifi so this one should not be a problem !grovkillen wrote: ↑15 Aug 2017, 14:20Use the bin file ending with "8285". This is something that will be changed in the future since it is a bit confusing having the name that way. See this request: https://github.com/letscontrolit/ESPEasy/issues/444
Some ideas about something to investigate for that ?
Update: Redid the flash with version 2 and with 8285 file and it works like a charm now same flash command line with the 8285 file and it's all setup ( I have 4 of these and they are now operationnal with my Home Assistant system through MQTT ;) Might be nice to update Wiki with instructions no ??
Thanks for help
vincen@Fixe-Ubuntu:~/Bureau$ esptool.py --port /dev/ttyUSB0 write_flash -fm dout 0x00000 ESPEasy_v2.0.0-dev11_normal_1024.bin
esptool.py v2.0
Connecting....
Chip is ESP8266
Uploading stub...
Running stub...
Stub running...
Flash params set to 0x0320
Wrote 558896 bytes (368923 compressed) at 0x00000000 in 32.5 seconds (effective 137.5 kbit/s)...
Leaving...
Hard resetting...
Even the older R1xx versions can be used with Sonoff 4ch, i'm running a R148 on it.
But the standard binaries are compiled for the ESP-8266, not for ESP-8285!
As the two CPUS handle the memory slightly different you must compile a binary suitable for the CPU.
If the source is compiled correctly it runs on both.
We will add this once it's released with "correct" nomenclature.
Well it might already help lot of users to get in Wiki no ? I'm ok to do it if you want ? (I filled the request account on Wikigrovkillen wrote: ↑15 Aug 2017, 15:24We will add this once it's released with "correct" nomenclature.
Sure you can add the information but it will be changed in a short while since with the next dev-release it will obey the suggested nomenclature.
Will make a note in explanations, and will try not to forget to update it when new dev-release is avalaiblegrovkillen wrote: ↑15 Aug 2017, 15:42 Sure you can add the information but it will be changed in a short while since with the next dev-release it will obey the suggested nomenclature.
Good!vincen wrote: ↑15 Aug 2017, 15:48Will make a note in explanations, and will try not to forget to update it when new dev-release is avalaiblegrovkillen wrote: ↑15 Aug 2017, 15:42 Sure you can add the information but it will be changed in a short while since with the next dev-release it will obey the suggested nomenclature.
Waititng to get news of my credential request on Wiki to start prepare the tutorial Might take few days as it's long time I have not used Wiki editor
It should arrive in a couple of seconds/minutes... check your spam folder.
Still nothing in spam or inboxgrovkillen wrote: ↑15 Aug 2017, 16:03It should arrive in a couple of seconds/minutes... check your spam folder.
Thank you alphons your post works fine and my units are now working again.
I had the same issue. I solved it but I am not sure if what I have done to solve it is going to cause me any additional issues if the memory size has not changed.
I solved the issue by flashing the 8285 version of the firmware instead of the 1024 size. I now have 4 working devices using this. I was just assuming that the company has upgraded the memory on the new units.
If this is something that is going to cause me issues I would sure like to know it ASAP.
Nope it's the correct firmware in fact 8285 is fos chip reference not memory size so you are all ok thereawclem wrote: ↑20 Aug 2017, 17:34 I had the same issue. I solved it but I am not sure if what I have done to solve it is going to cause me any additional issues if the memory size has not changed.
I think we already have a precompiled ESP8285 version, that should work right?
https://github.com/letscontrolit/ESPEas ... y-releases
I have the same problem but i can solve it with your instructions!! Best regards and thanks!
I have a few brand new Sonoff Basic devices - the ones with the new chip that required DOUT rather than DIO, apparently, though I am having trouble flashing ESPEasy binary images on these devices with it set to DOUT or DIO.
I have successfully flashed these devices with a blink sketch using the Arduino IDE, so I know my USB-> serial is working ok. I'm pretty sure the Arduino IDE is using DIO though, as '-bm' is not specified on the command line (see example further down this post).
Here is one of my attempts at flashing an ESPEasy binary image, with console out (I'm on a Mac):
$ esptool -vv -bz 1M -bm dout -cd ck -cb 115200 -cp /dev/cu.wchusbserial1410 -ca 0x00000 -cf ESPEasy_v2.0.0-dev12_normal_1024.bin
esptool v0.4.9 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting flash size from 512K to 1M
setting flash mode from qio to dout
setting board to ck
setting baudrate from 115200 to 115200
setting port from /dev/tty.usbserial to /dev/cu.wchusbserial1410
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
opening port /dev/cu.wchusbserial1410 at 115200
tcgetattr
tcsetattr
serial open
opening bootloader
resetting board
trying to connect
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
trying to connect
espcomm_send_command: receiving 2 bytes of data
Uploading 566528 bytes from ESPEasy_v2.0.0-dev12_normal_1024.bin to flash at 0x00000000
erasing flash
size: 08a500 address: 000000
first_sector_index: 0
total_sector_count: 139
head_sector_count: 16
adjusted_sector_count: 123
erase_size: 07b000
setting timeout 15000
setting timeout 100
writing flash
................................................................................ [ 14% ]
................................................................................ [ 28% ]
................................................................................ [ 43% ]
................................................................................ [ 57% ]
................................................................................ [ 72% ]
................................................................................ [ 86% ]
.......................................................................... [ 100% ]
starting app without reboot
closing bootloader
The above appears to flash ok but the AP never turns up and serial is silent. I have tried the same with the R120 release of ESPEasy and also specifying -bm DIO with no difference in behaviour.
Here's what a successful upload of the blink sketch looks like, performed by the Arduino IDE (I am using the same esptool for the command line and the IDE):
/Users/user/Library/Arduino15/packages/esp8266/tools/esptool/0.4.9/esptool -vv -cd ck -cb 115200 -cp /dev/cu.wchusbserial1410 -ca 0x00000 -cf /var/folders/_b/z_ylfsdx2pxfj41qtwgfx0sw0000gn/T/arduino_build_846813/sketch_oct28a.ino.bin
setting board to ck
espcomm_upload_file
espcomm_upload_mem
tcgetattr
tcsetattr
serial open
opening bootloader
resetting board
trying to connect
trying to connect
Uploading 228336 bytes from /var/folders/_b/z_ylfsdx2pxfj41qtwgfx0sw0000gn/T/arduino_build_846813/sketch_oct28a.ino.bin to flash at 0x00000000
erasing flash
size: 037bf0 address: 000000
total_sector_count: 56
adjusted_sector_count: 40
erase_size: 028000
setting timeout 100
writing flash
................................................................................ [ 35% ]
................................................................................ [ 71% ]
closing bootloader
Immediately after uploading this the Sonoff blinks away happily.
As a side note, I HAVE successfully flashed an AdaFruit Huzzah with the R120 binary image specifying -bm DIO, so the image is also fine.... It's just these Sonoffs that I'm struggling with.
Any advice would be gratefully received.
setting board to ck
espcomm_upload_file
espcomm_upload_mem
tcgetattr
tcsetattr
serial open
opening bootloader
resetting board
trying to connect
trying to connect
erasing flash
erase_size: 07b000
setting timeout 100
writing flash
closing bootloader
setting board to ck
espcomm_upload_file
espcomm_upload_mem
tcgetattr
tcsetattr
serial open
opening bootloader
resetting board
trying to connect
trying to connect
erasing flash
erase_size: 028000
setting timeout 100
writing flash
closing bootloader
Hello all
I have a Sonoff S20 which I've read is almost identical to the Sonoff basic. I'm able to upload espeasy but as with others.. there's no AP. There's a twist to this story though... As I did manage to get it up before..
This is what happend:
Tested the original unit with EWelink - all was ok
Soldered header and used Adruino IDE to flash espEasy R120 - all went well
ESP_0 AP came up and I started to configure the unit....whilst going through the config I thought I could load up a config from another Sonoff Basic I have, then update the parameters like IP address, name etc.. but the config wasn't showing up So i rebooted the unit..... It went downhill from there..i Iost connectivity . I turned off my WiFi ap in the hope of seeing esp_0 on the unit but that didn't happen either. Ive tried to flash espEasy on again.. which seems to go on successfully... But no Esp_0 ap. I get no output over serial nor can I send any commands (using putty)
Flashing Tasimota works fine..
I have a feeling that config data is persistent and that is what's causing the problem. I may need to do some work of memory wipe, and start again.
I anyone out there able to help?
- Disconnect the S20
- shorten Tx--Rx with a jumper cable
- power on and wait some seconds
- power off, remove jumper.
This erases the chip memory.
Thanks Shardan
I'll give this a go when I get home. Incidentally...Do you have any idea what kind of response I should get from the on board LEDs when doing this?
Honestly i don't know.
My S20's are still on the way from china
Hopefully the customs won't reject them.
Just an update.
Shorting tx/Rx didn't work for me.. I had to use the espTool from
Espressif. There is an option to clear the chip which worked. I then used Arduino IDE to load EspEasy on again.
Phew!
Oh and my unit also came from China... Took about 3weeks to deliver to my home in the UK.
Phew!
Just flashed a new Sonoff S20 (V1.3) with the Arduino IDE and ESPEasy v2.0.0-dev12 and flashmout 'DOUT'. Flashed and ran in first 'go'.
I do still get "Error while reading/writing config.dat in 926" with this new device
Is there much of a difference between R120 and 147?.....
@alphons
I received the NEW sonoff basic from itead today.
I followed your instruction to flash the Espeasy normal v2.0 with the flashing tools from Espressif per your instruction.
I was successful and reboot the sonoff and on the Wifi ssid, I see ESP_Easy_0, but I cannot logon because it requires an 8 digit password.
Please advise the password.
Thanks all,
I was able to log onto the sonoff and change ip address of my desire and proceed to configure this for domoticz.
When I reach the "HARDWARE" section, as usual, since I had many sonoff, I change the wifi status led to GPIO 13(D7), as soon as I did that, the led on sonoff goes on and I was disconnected from the router and no longer able to log on. What gives?
OK OK,
Here is what I found, the GPIO13 on the sonoff is no longer and I do not know what it is. I configured the device without Hardware wifi led set as GPIO13 and it works. However, I can no longer turn on/off the switch with the black push button on the switch. I have to rely on software to control the sonoff.
Until I can find, this will do for now.
Here is my rules for Domoticz, I guess gpio 13 in the rule did nothing.
"on lamp_on do
gpio,12,1
gpio,13,0
on lamp_off do
gpio,12,0
gpio,13,1
on SW_1#Switch do
if [SW_1#Switch]=1
gpio,12,1
gpio,13,0
gpio,12,0
gpio,13,1
endon"
"on lamp_on do
gpio,12,1
gpio,13,0
on lamp_off do
gpio,12,0
gpio,13,1
on SW_1#Switch do
if [SW_1#Switch]=1
gpio,12,1
gpio,13,0
gpio,12,0
gpio,13,1
endon"
Has anyone figured out which gpio controls the led ?
I bought month ago Sonoff wifi switches. I do not flash these first time but with these ...i do not know what. Esp chip is 8266. Flashing goes norm but after reboot i do not see ESP_0 wifi. I use Os X and esptool. What and how i need ? I try ESPEasy_v2.0.0-dev11_normal_1024.bin and after this R120 512 and 1024. Not works.
- Screen Shot 2018-01-25 at 21.21.34.png (58 KiB) Viewed 17725 times
Some Raspeberry Pi's, Arduinos, Esp8266, solar panels 1500w, 2 lakes,6 ha fields, German shepherd and more
i also bought a SONOFF basic , but i cannot flash i with this tool
what am i doing wrong ???
- error programmer.jpg (332.68 KiB) Viewed 17696 times
I do not know it is working but i flash it with image for 8285. Working. I use os x and esptool. I do not have no one comp with windows.
Just got a few of these Sonoff basics, boards say Dec/2017 is that helps anyone, and they are all ESP8266, I had heard they switched to another chip but I got out my magnifier to confirm. Grabbed the latest ESPEasy_v2.0-20180228.zip and used the DOUT normal bin, all flashed and create the ESP wifi network on boot.
esptool.exe -vv -cd nodemcu -cb 115200 -cp COM5 -ca 0x00000 -cf ESP_Easy_v2.0-20180228_normal_ESP8266_1024_DOUT.bin
I was a little concerned with all the mixed results I'd read but no issues here
I first bought a Sonoff TH16 last year (2017) and was able to flash it with the ESP120 build and use it without any problems, I am using it as a temperature sensor.
I bought another two TH16's recently (May 2018) and was unable to flash them until I read this thread. The new TH16s have v2.1 on the circuit board - after using the correct flash tool I was able to flash them with the latest ESP git build, they boot and connect to WiFi OK however I cannot get the temperature sensor to work. I even downgraded the 2018 TH16's to the 120 build and set them up exactly the same as the 2017 unit but the temperature sensor device (set as a Temperature - DS18b20) does not work on the 2018 models. I am using the Sonoff sensor cable and GPIO14 but I do not get any ROM port/device numbers showing and cannot get any temp reading.
Am I doing something wrong? Or is the newer model TH16 temperature sensor not compatible with the ESP firmware anymore?
UPDATE
For anyone stumbling across this post - the problem was that the case on the new TH16's was preventing the DS18b20 sensor from connecting properly, it needs to click home and the casing hole was preventing that. I increased the size of the casing hole so that the sensor connected properly and everything worked as expected!
UPDATE
Users browsing this forum: No registered users and 60 guests
