On TempPres#Temperature do
7dt,[TempPres#Temperature]
EndOn
And please send a log file screenshot for us to see.
EndOn
Great Job grovkillen!grovkillen wrote: ↑02 Dec 2017, 23:33 https://www.letscontrolit.com/wiki/inde ... nt_display
wiki updated with this plugin.
Let me know which LOG and I'll add them and will evaluate to move to NORMAL plugins...grovkillen wrote: ↑03 Dec 2017, 00:03 Papperone, thanks!!
I've been using it for a day now
I do miss some log output though. And as I asked on GitHub, is the 4 digit display with dots also supported or is it only the "clock" version?
When I add numbers manually the log is not populated with this. Commands 7don, 7doff and 7db,<value> are not reported. Just that stuffpapperone wrote: ↑03 Dec 2017, 09:27Let me know which LOG and I'll add them and will evaluate to move to NORMAL plugins...grovkillen wrote: ↑03 Dec 2017, 00:03 Papperone, thanks!!
As per GitHub discussion I will add more displays support to the next release of the plugin (once they will arrive from China )
Ah ok, that's simple... I normally use logs only during developping/testing then I remove them to optimize but you are right, you can always change logs level/reporting from the advanced settingsgrovkillen wrote: ↑03 Dec 2017, 10:58When I add numbers manually the log is not populated with this. Commands 7don, 7doff and 7db,<value> are not reported. Just that stuffpapperone wrote: ↑03 Dec 2017, 09:27Let me know which LOG and I'll add them and will evaluate to move to NORMAL plugins...grovkillen wrote: ↑03 Dec 2017, 00:03 Papperone, thanks!!
Is it possible to have the plugin handle multipel devices (four maybe) add the rotary encoder plugin for example?
not sure I understood... you want the plugin to control like 4 displays and change the contents using a rotary encoder?grovkillen wrote: ↑03 Dec 2017, 15:35Is it possible to have the plugin handle multipel devices (four maybe) add the rotary encoder plugin for example?
ok you are right, I still need to figure it out why multiple istances of same plugin make the ESP unstable; while adding the LOG will try to understand it...grovkillen wrote: ↑03 Dec 2017, 17:43 No, I want to be able to use more than one display together with one esp. The rotary we just used as an example, sorry for not being clear.
Thanks, and yes, it's an overall problem with ESP Easy. We need to try to find the root cause of the instability.papperone wrote: ↑03 Dec 2017, 17:48ok you are right, I still need to figure it out why multiple istances of same plugin make the ESP unstable; while adding the LOG will try to understand it...grovkillen wrote: ↑03 Dec 2017, 17:43 No, I want to be able to use more than one display together with one esp. The rotary we just used as an example, sorry for not being clear.
Thanks and Happy New Year!!!
On System#Boot do
timerSet,1,5
On DSTemp#Temperature do
7dt,[DSTemp#Temperature]
On Rules#Timer=1 do
SendToHTTP <IP_2>,80,/control?cmd=lcd,1,1,test123
timerSet,1,5
Hi, I am waiting some new displays models in order to implent them in the next release of this plugin.Domosapiens wrote: ↑19 Jan 2018, 23:59 @Papperone,
thanks for this plug-in.
Is it possible to combine this plug-in with a PCF8574 I/O expander ?
A quick test of the mega release ESPEasy_mega-20180119 showed only the regular GPIO's and not the PCFGPIO's from PCF8574.
Thanks for your response.
Domosapiens
Same, have several PCF8574 DIP-housing in the shelf.
Nope.
There is solution, but we still have to implement it.
Nice! Good job.
Great news Papper! Just a reminder, I got them displays myself in case you need me to test something
Will try it tomorrow.papperone wrote: ↑13 Feb 2018, 18:38 Either I'm not lucky at all (and I got 4 DOA brand new displays from Robodin) or something is weird here...
None of the brand new 4 displays I've got, despite I bought branded ones, seems to work
@Grovkillen: can you connect one of the new type of displays you got as well and see if they react with old plugin? they are pin to pin compatible so at least the digits shoudl be shown...
As you probably already knew, I cannot get mine to shine neither.papperone wrote: ↑14 Feb 2018, 10:40 Meanwhile I've found last night a differen library for Arduino (not working on ESP8266) which can drive both old and new type of displays...
That's weird as they both uses TM1637 and I build the plugin from scratch using the info taken from the IC datasheet, but... obviously I overlook something or the new display have something different which I cannot still spot.
Anyhow I think it will take longer than expected as I will need to reverse engineer the new lib I've found to understand how it is driving the IC and to implement the same changes in my plugin (which does not uses any library).
I do apologize for the delay
Hallo,papperone wrote: ↑14 Oct 2017, 00:31it's in my "to-do" list but probably as a separate plugin as this matrix led can be more flexible and customizablegrovkillen wrote: ↑13 Oct 2017, 23:52 Will dot matrix displays powered by MAX7216 be supported? Just curious.
Yes it is! Right now I need to rework the TM1637 interface to enable compatibility with newer modules, then I'll work on implementing dot matrix displays!The-Holgi wrote: ↑14 Feb 2018, 21:54Hallo,papperone wrote: ↑14 Oct 2017, 00:31it's in my "to-do" list but probably as a separate plugin as this matrix led can be more flexible and customizablegrovkillen wrote: ↑13 Oct 2017, 23:52 Will dot matrix displays powered by MAX7216 be supported? Just curious.
is this still on your to-do list?
I think it‘s a good idea. The Dot Matrix looks very good.
With best regards Holgi
Yes I have all new modules that does not work with my plugin while the modules I've boughy few months ago works perfectly.38domo wrote: ↑17 Feb 2018, 16:19 hello,
on my side I have made supplemental tests. I have 2 displays available
First test: connect on arduino Uno with a small prog to display random data --> OK on the 2 displays
2nd test : connect on Wemos with espeasy v2 : No. don't work- no display
3d test : connect on ESP12E with espeasy V2: NO- don't work- no display
espeasy works fine on wemos and esp12 with gpio tests ( leds connected)
As there is a level potential issue on the displays (5V on arduino, 3V3 on ESP) I have ordered level shifters to check.
regards
It is already merged and there should be a new build tomorrow morning.victorclaessen wrote: ↑03 Mar 2018, 21:43 Thanks for the proposed fix. Would it be alright to trouble you for the compiled firmware; i.e. would you be willing to post that somewhere? Preferably for a 4M-version ESP8266?
