Connecting a TM1637 4-Digit Display
Re: Connecting a TM1637 4-Digit Display
I will make a wiki that is a simplified version of the development wiki.
You are all GREAT people !
Thanks !
Thanks !
If you need this plugin only you can find the BIN of 2.0.0dev12 with P073 attached in one of my previous posts.freijn wrote: ↑17 Oct 2017, 12:19 Hey Papperone
First, many thanks for your great work here!!
Do you know, is there a wiki or good place to start to get a plugin compiled in EspEasy ?
I have seen the developers wiki , but nothing on Plugin's
Somehow I can't get started.
Again, many thanks for your work here
Frank
About how to complie plugins, if you are familiar with Arduino IDE or PlatformIO it's just a matter to copy the file into the main folder of ESPEasy source files and open it from there in order to complie (assumign you have all the libraries with the right version installed of course )
I just added a section to the official Platformio wiki.
https://www.letscontrolit.com/wiki/inde ... ed_plugins
Not alot but essentially its not that much different from compiling the official FW.
cheers!!!!
Will try this tomorrow.
Frank
Frank
I'm trying to get the temperature from a sensor that's on the same ESP.
I have never used rules before, just don't know how to get them working.
Anyway, I tried and did this:
- Switch the TM1637 to manual mode
- The Temparature sensor is called 'TempPres'
- I switched on rules and created this rule: on TempPres#Temperature do 7dt,[TempPres#Temperature]
- Does nothing....
When I send a http command it works fine, so obviously there is something wrong. But what? Who can tell me how to do it. And can it be done anyway?
I could send the value I get from Domoticz back to the esp, but I hope to get it done with rules this time.
- Does nothing....
Send screenshots.
Here are pictures of the screens I use:
https://ibb.co/m0cfTR
https://ibb.co/imwJF6
https://ibb.co/cGgUNm
Seems correct. What does the log look like? Does it trigger at all?
No, nothing happens. The display stays dark. When I send a command by http it works.
Try this rule:
Your code should work but just as a test.
And please send a log file screenshot for us to see.
On TempPres#Temperature do
EndOn
It works!!!
The EndOn must have been the problem.
Or maybe the style of coding.
Anyway, it works now and I'm very glad it does.
Thank you for your help!
I updated the wiki accordingly. Thanks for feedback!
Great Job grovkillen!grovkillen wrote: ↑02 Dec 2017, 23:33 https://www.letscontrolit.com/wiki/inde ... nt_display
wiki updated with this plugin.
As far as I've one running since more than a month without issue I woudl consider to move this to NORMAL instead of TESTING but I'd like to have at least some confirmation of stability from other users who maybe using it permanently on their devices...
Papperone, thanks!!
I've been using it for a day now
I do miss some log output though. And as I asked on GitHub, is the 4 digit display with dots also supported or is it only the "clock" version?
Let me know which LOG and I'll add them and will evaluate to move to NORMAL plugins...grovkillen wrote: ↑03 Dec 2017, 00:03 Papperone, thanks!!
As per GitHub discussion I will add more displays support to the next release of the plugin (once they will arrive from China )
When I add numbers manually the log is not populated with this. Commands 7don, 7doff and 7db,<value> are not reported. Just that stuffpapperone wrote: ↑03 Dec 2017, 09:27Let me know which LOG and I'll add them and will evaluate to move to NORMAL plugins...grovkillen wrote: ↑03 Dec 2017, 00:03 Papperone, thanks!!
Ah ok, that's simple... I normally use logs only during developping/testing then I remove them to optimize but you are right, you can always change logs level/reporting from the advanced settingsgrovkillen wrote: ↑03 Dec 2017, 10:58When I add numbers manually the log is not populated with this. Commands 7don, 7doff and 7db,<value> are not reported. Just that stuffpapperone wrote: ↑03 Dec 2017, 09:27Let me know which LOG and I'll add them and will evaluate to move to NORMAL plugins...grovkillen wrote: ↑03 Dec 2017, 00:03 Papperone, thanks!!
I will add it soon and submit a PR
Great!
Is it possible to have the plugin handle multipel devices (four maybe) add the rotary encoder plugin for example?
not sure I understood... you want the plugin to control like 4 displays and change the contents using a rotary encoder?grovkillen wrote: ↑03 Dec 2017, 15:35Is it possible to have the plugin handle multipel devices (four maybe) add the rotary encoder plugin for example?
can you clarify?
No, I want to be able to use more than one display together with one esp. The rotary we just used as an example, sorry for not being clear.
ok you are right, I still need to figure it out why multiple istances of same plugin make the ESP unstable; while adding the LOG will try to understand it...grovkillen wrote: ↑03 Dec 2017, 17:43 No, I want to be able to use more than one display together with one esp. The rotary we just used as an example, sorry for not being clear.
Thanks, and yes, it's an overall problem with ESP Easy. We need to try to find the root cause of the instability.papperone wrote: ↑03 Dec 2017, 17:48ok you are right, I still need to figure it out why multiple istances of same plugin make the ESP unstable; while adding the LOG will try to understand it...grovkillen wrote: ↑03 Dec 2017, 17:43 No, I want to be able to use more than one display together with one esp. The rotary we just used as an example, sorry for not being clear.
Hi guys,
I am fairly new to EspEasy. I was also looking for a way to use a TM1637 display, so I wanted to thank Papperone for the work!
Happy New Year to all!
Thanks and Happy New Year!!!
PS: my new displays to expand this plugin are still "in transit" from China; hope to getit soon and be able to release new version of plugin!
I have added a timer on the rules. When the module boots, I get the following:
5236 : WIFI : Connected! IP: <IP> (<name>)
5331 : EVENT: System#Boot
5336 : ACT : timerSet,1,5
5402 : FS : Error while reading/writing config.dat in 926
5502 : WD : Uptime 0 ConnectFailures 0 FreeMem 22808
5518 : EVENT: Clock#Time=Thu,15:39
7339 : DS : Temperature: 41.50 (28-ff-37-e2-0-17-3-b3)
7339 : EVENT: DSTemp#Temperature=41.50
7404 : ACT : 7dt,41.5
17976 : EVENT: Clock#Time=Thu,15:40
And the timer never expires. Can this error be related to your code?
My Rules are:
IP_2 is the address of another module.
My Rules are:
On System#Boot do
timerSet,1,5
On DSTemp#Temperature do
7dt,[DSTemp#Temperature]
On Rules#Timer=1 do
SendToHTTP <IP_2>,80,/control?cmd=lcd,1,1,test123
timerSet,1,5
This is a bug: https://github.com/letscontrolit/ESPEasy/issues/588
It is fixed in current code but no "dev release" yet. You can compile current code if you know how to or wait for it to be released.
thanks for the quick response! (I'll check the list of issues next time)
Hello.
I want to thank the developer for his work!
I wanted to find out if there was some way to switch the plugin's operating mode ("clock" or "manually") by commands from the rules or by a http request, rather than on the device page in ESPEasy?
If not, is it possible to implement?
@Papperone,
thanks for this plug-in.
Is it possible to combine this plug-in with a PCF8574 I/O expander ?
A quick test of the mega release ESPEasy_mega-20180119 showed only the regular GPIO's and not the PCFGPIO's from PCF8574.
Thanks for your response.
Domosapiens
Domosapiens
Hi, I am waiting some new displays models in order to implent them in the next release of this plugin.Domosapiens wrote: ↑19 Jan 2018, 23:59 @Papperone,
Domosapiens
I think I shoudl have somewhere such expander PCF8574; if I will find it I will have a look if it can be easily implemented your request
I can send you 1 or 3 if you don't have some at home.
@Papperone,
hope you can do it.
It would be a major break-trough: using PCFGPIO's as generic GPIO's.
(f.i. also for HC-SR04 distance measurement, IR Transmit etc.)
Thanks in advance !
hope you can do it.
Thanks in advance !
Same, have several PCF8574 DIP-housing in the shelf.
Let me know.
Don't worry I've just found PCF8574 so I can start experimenting with that!
I already opened a generic Issue/Enhancement request on github as I do believe we shoudl add expanders in the ESPEasy core code, this will allow *any* plugin to access both internal or external GPIOs seamlessly https://github.com/letscontrolit/ESPEasy/issues/749
BTW: There are many expanders similar to PCF8574, even with 16 GPIOs (MCP23017) so will be tricky to implement them all, so let's park it here and think about it...
hello, I have seen this plugin, thanks a lot for his developpement. I am interested in, found the source and would like to implement on an ESP-01.
However I don't succeed to compile, many errors found ( using ESPeasy R120 due to memory limitations).
Is it possible to have it working on this ESPeasy release ???
regards
regards
hello,
Nobody to respond ?
I precise the compilation error is with the function AddFormNote in PLUGIN_WEBFORM_LOAD.
_P073_7DGT:90: error: 'addFormNote' was not declared in this scope
addFormNote(string, F("TM1637: 1st=CLK-Pin, 2nd=DIO-Pin"));
I am using Arduino 1.8.5 and ESPcore 2.30
regards
Nobody to respond ?
regards
I would suggest switching over to one of the newer branches (v2.0 or Mega), since all active development is done there.
What are the memory restrictions you have?
ESP-01 has only 512k memory, so we cannot install v2.00 or mega version
Hi papperone,
I have posted a problem I have with SendToHTTP in this thread. I am informing you as well, in case it relates to your build.
Nope.
The old version (Usually on a blue PCB) has 512K
Newer versions (Black PCB) have 1MB and can be used with the 1024-Binaries of ESPEasy 2.0.0/Mega.
Please beware:
At this time there are some ESP-01 with a PUYA flash chip.
These flash chips do not work with ESPEasy atm, they have a problem with SPIFFS memory.
This problem is under investigation, but that will take a while.
There is solution, but we still have to implement it.
Nice! Good job.
But still no solution that is ready to use
I received finally the new 7digit modules with M1637 and new config (6 digits and with decimal dots).
I will try to find some spare time to update the plugin to have support for them, about the SendtoHTTP bug I don't this can be connected but I'll have a look.
Great news Papper! Just a reminder, I got them displays myself in case you need me to test something
Either I'm not lucky at all (and I got 4 DOA brand new displays from Robodin) or something is weird here...
None of the brand new 4 displays I've got, despite I bought branded ones, seems to work
@Grovkillen: can you connect one of the new type of displays you got as well and see if they react with old plugin? they are pin to pin compatible so at least the digits shoudl be shown...
Will try it tomorrow.papperone wrote: ↑13 Feb 2018, 18:38 Either I'm not lucky at all (and I got 4 DOA brand new displays from Robodin) or something is weird here...
Meanwhile I've found last night a differen library for Arduino (not working on ESP8266) which can drive both old and new type of displays...
That's weird as they both uses TM1637 and I build the plugin from scratch using the info taken from the IC datasheet, but... obviously I overlook something or the new display have something different which I cannot still spot.
Anyhow I think it will take longer than expected as I will need to reverse engineer the new lib I've found to understand how it is driving the IC and to implement the same changes in my plugin (which does not uses any library).
I do apologize for the delay
Users browsing this forum: No registered users and 55 guests
