No connection ESP01 and Relay
Re: No connection ESP01 and Relay
Image attached
- IMG_20171203_173419.jpg (2.25 MiB) Viewed 38343 times
Really want to get this to work. But im on the verge of giving up. A lot of information online is different from one page to another.
You sure it's 1MB? Have you removed it from the back relay board and booted it?
Do you get Wifi from the ESP if it is connected to the programmer?
I sure do.
Not sure if it is 1mb. And no I haven't booted away from the relay. As I don't have a 3.3 psugrovkillen wrote: ↑03 Dec 2017, 20:28 You sure it's 1MB? Have you removed it from the back relay board and booted it?
Try to get 3.3V and boot before giving up. Also double check the memory size.
I'll try powering from my arudino.
If Wifi is OK with the programmer the ESP is working and should have 1 MB.
Something does not work when the ESP is plugged into the relay board.
As the board should work with it's own software deleiverd with the board
something is stopping the ESPEasy firmware on the board.
Sadly i don't have a schematic or a sample of the board so it's difficult to say what's going on.
Just a question. Why does it work from the programmer without the link out? Why is it then needed?
The programmer board connected these two pins via the board. You can test if they do using a multimeter.
This may answer your question.
I suspiced some needed pull-up resistors are missing on the board so i just checked the pictures of the board on AliExpress.
Beware - i'm judging only by the photos and may be wrong.
This is an interesting relay board.....
- Relay connected to GPIO0 - no pull-up resistor on the board
- GPIO2 floating - no pull-up resistor on the board
- ch-pd floating - no pull-up resistor on the board
- Reset just connected to the button - no pull-up resistor on the board
seeing this I checked ESP-01 and ESP-01S from my shelf:
The older ESP-01 (the one you used juding by your photos) has a internal pull-up on reset only.
The newer ESP-01S has internal pull-ups on reset, ch-pd (enable) and GPIO0 (I see 9..12 KOhm with multimeter) but
not on GPIO2 (I see some MOhms).
There may be other ESP-01 types differing from this.
It might be worth a try to solder the missing resistors to the board for a test.
Possibly it would work with the newer ESP01S, but not with your older ESP-01 types.
If you have a multimeter or voltmeter try the following:
- put the ESP-01 into the board
- power up the board (it needs 5V)
- check the voltage from GND to GPIO0, GPIO2, CH-PD (enable) and reset.
If possible give the results here.
Balls! Powered from arud and it's booted.
Great! You can get a DC-DC step down to 3.3V.
Possible. However I wanted to use this relay due to the size. Which sucks!
You probably can by modifying it a bit...
I can does reading tomorrow. It has esp01s printed on the rear of the relay if that helps
See photo.
- IMG_20171203_214800.jpg (1.95 MiB) Viewed 38906 times
Yep, i think that's the reason - some pull up resistors are missing.
If you check the pictures on AliExpress et al you will see they all use a ESP-01S type.
Look at this picture:
In the upper left marked area there are some more parts on the ESP-01S.
In the lower area are two resistors that are missing on the ESP-01.
As said check the voltage on the four pins as described some might have too low voltage to start up.
As i can see from the photos you're using an ESP-01, not an ESP-01S (misstyped that on first run, sorry).
All boards i've seen on the marked use ESP-01S.
So I need to get some.esp01s WiFi boards to use my relays?
If you have a multimeter or voltmeter at hand try to check out the voltage on the four "middle" pins, GPIO 0 & 2, CH-PD (enable) and reset when the ESP-01 is plugged into the board.
I suspice the voltage on some pins is too low to boot up correctly due to the missing resistors.
The easiest way to get it working is getting ESP-01s, yes.
If you can check which pins have too low voltage it should be possible to use some 10KOhm resistors and pull the voltage up.
I'll test it tomorrow. I might just grab some esp01s units. However most sellers.are not in the UK.
Sadly they are not in Germany either..... and those which are sold here are not really affordable.
Will get an esp01s WiFi module from the UK. If it works I'll bulk buy for the project. Can't thank you enough for the help. I'll test the voltage tomorrow
Hey
So I've replaced the esp01 for esp01s and it works flawlessly. Thanks for your help. Just need to find a use for the old units now.
i have connected VCC to CH_PD and put a 10K ohm resistor on VCC and GPO0 on the esp01.
The board seems to start up now and GPO0 can operate the onboard relais.
So don't throw away your old esp's yet.
BTW the shematic of this relay baby is there:
https://github.com/IOT-MCU/ESP-01S-Rela ... ematic.pdf
as well as some others documents (look like the manufacturer repo)
HTH
HTH
Soif
Want to update ALL your ESP babies OverTheAir, or backup their settings in ONE simple command, + many other cool features.... Adopt EspBuddy
Hi there, everything is about which relay module you have. ESP-01 relay V1.0 there you have to do to changes first wire connect VCC pin and CH_PD pin picture1 step two is take out R2 picture 2.
ESP-01 relay V4.0 only first step connect VCC and CH_PD.
- E71CCEB0-339D-4FE3-A7F6-E99129BDF681.jpeg (104.56 KiB) Viewed 4396 times
- 890B3C30-70E7-40D3-9EC8-D69B89C6CB47.jpeg (85.47 KiB) Viewed 4396 times
- dynamicdave
Only just seen this thread.
I spent a couple days (a month or so ago) trying to sort out why the ESP-01 didn't work after I used the programmer, shown above, to flash it.
Discovered like a few people that a pull-up is missing on SOME of the ESP-01 boards.
I had a mixture of boards, so some worked and some didn't - which just added to my confusion.
The miniature 'programmer' does have pull-ups so when the ESP-01 is mounted on the programmer it will work correctly.
Solution is a 10K pull-up resistor from the CHPD pin to +3v3 if you want to operate the ESP-01 in standalone mode.
Cheers from David.
Cheers from David.
Users browsing this forum: Ahrefs [Bot] and 134 guests
