MH-Z19B - MHZ19: Unknown response: 0 0 0 0 0 0 0 0 0
Re: MH-Z19B - MHZ19: Unknown response: 0 0 0 0 0 0 0 0 0
Does the red light inside the sensor light up every so many seconds?
I never used the version with the external white connector.
Have you also tried to switch Rx and Tx?
Yes, the red light is there. Under Arduino I get valid data. I switched rx and tx.
What voltage do to use as Vin?
I have only used the older (pre B) version on 3.3V, but maybe the newer versions are a bit more specific on the input voltage.
I use 5V - do you think I shall try 3.3V DC?
Nope, the datasheet mentions 3.6 - 5.5V, which starts at >3.3V
So I guess its results will be less accurate for 3.3V
Right, Mine is on D5 for the Tx and D6 for the Rx. 5v powered and it is working alsoTD-er wrote: ↑12 Dec 2017, 22:24 I have both sensors here (MHZ19 and -B version).
In one system I use these pins:
D5 GPIO14
D6 GPIO12
And in the other system:
D3 GPIO0
D4 GPIO2 (BUILTIN_LED on Wemos D1 mini)
I think you could try D5 and D6.
Are there other plugins active? Perhaps try to disable them, just for debugging.
Strange. And you are both on "ESPeasy 2.0 dev 12"?
I use the precompiled image "ESPEasy_v2.0.0-dev12_dev_4096".
Well, I compiled myself the core of version 2.0 dev 12 with the plugin of the branch "2.0" because my sensor is the B version and it's only supported by this plugin. I compiled a 1024 bin but this is not that important.
But I though about that today, I recently wasted my time in having a lot of issue on a project. I just solved them in changing my power supply : as this sensor is quite hungry during peak, check with a good power supply and a good cable
Hello all !
I am new on this forum so at the beginning I am sorry form simple questions. I am user of Nodemcu V3 and MH-Z19B. I have loaded ESPEasy_v2.0.0-dev12_dev_4096.bin into Nodemcu. I have connected D6-Tx, D7-Rx power supply is from nodemcu(5VIN,GND) and configured MH-Z19B sensor as:
CO2 MH-Z19 [TESTING]
1st GPIO GPIO-12(D6)
2nd GPIO GPIO-13(D7)
ABC Disabled
Delay 60[sec]
And in logs I see messages: “MHZ19: Unstable reading, ignoring! PPM value: 1470 Temp/S/U values: 28/0/0.00”. Values are only visible in logs, I can’t read them
Sensor seems to work fine? From time to time blinking read but I can’t display values on LCD connected to nodemcu. I gues that problem is in incorrect software loaded into nodemcu. And here is my question – which software version for nodemcu v3 is correctly working with MH-Z19B and where can I download compiled (*.bin) version? I am a newbie not familiar with Arduino IDE, compiling modules etc. Maybe somebody have already compiled and working version with MH-Z19B.
Thank you for help!
ABC Disabled
Delay 60[sec]
Thank you for help!
The MH-Z19 plugin is active in the "test" bin file so you can flash that instead just to try. As of next release the plugin is part of the "normal" build. Just for information.
Thx for reply. I have loaded test file into nodemcu v3 and there is no change. Still can't read sensor values. Only in logs I see messages “MHZ19: Unstable reading, ignoring! PPM value: 776 ...." PPM and Temp in logs are changing but each read of sensor values report "Unstable reading....". Sensor red leds are blinking from time to time so it looks like sensor is OK. Any ideas?
Thank you for help!
Thank you for help!
I already had this issue and T-Der answered me. That's because you have the B version of the sensor. Like medgcracker wrote: ↑19 Dec 2017, 16:25 Thx for reply. I have loaded test file into nodemcu v3 and there is no change. Still can't read sensor values. Only in logs I see messages “MHZ19: Unstable reading, ignoring! PPM value: 776 ...." PPM and Temp in logs are changing but each read of sensor values report "Unstable reading....". Sensor red leds are blinking from time to time so it looks like sensor is OK. Any ideas?
Thank you for help!
You have to get the MH-Z19 plugin from the "2.0" branch of the Espeasy github
You seem to have the "B" version of the sensor, which gives a "0" as S-value.
Starting version dev-13, this will be supported, but you can also compile a version for yourself if you need it faster.
I don't think the new dev-13 release will take long, since the last 2 days, a lot of pull requests were merged and I think it is only testing for a (short) while with these new versions before the new release will be created.
Thx for reply and help. Exactly I have "B" version. So I have to wait for dev-13 or in the meantime compile it myself
Ah, timbiker. Cool. I just changed the power supply and now I have the same state as dgcracker, because I own the same B version. But it works.
Thanks TD-er and timbiker!
Just for information. The old power supply was rated at 5VDC/2A and the measurement was stable. The new one has the exact same values but works.
Did already tested someone the dev-13 release and the "B" version? At the moment I have no access.You seem to have the "B" version of the sensor, which gives a "0" as S-value.
Ehh I don't understand your post (maybe lack of coffee, or sleep, or both )dmq wrote: ↑10 Jan 2018, 20:08Did already tested someone the dev-13 release and the "B" version? At the moment I have no access.You seem to have the "B" version of the sensor, which gives a "0" as S-value.
Is your question about whether someone tested the latest builds? (both v2.0 and Mega have nightly builds now)
Or did you test it and it still doesn't work?
Nope, you were perfectly ok. I think I had too much coffeeEhh I don't understand your post (maybe lack of coffee, or sleep, or both )
Yes, exactly. You wrote in another post:Is your question about whether someone tested the latest builds? (both v2.0 and Mega have nightly builds now)
Question is, if someone with this version of the sensor now can see the correct values in the interface and not only in the logs.You seem to have the "B" version of the sensor, which gives a "0" as S-value.
With the latest builds, the B version of the sensor is fully supported.
I run one here for a while now.
Very good. Thanks.
Users browsing this forum: No registered users and 133 guests
