Sonoff basic with wall switch
Re: Sonoff basic with wall switch
OK, let me rephrase my question, what version of the sourcecode did you use.
There have been some changes in the switch plugin code. So I need to make sure you're running on the latest version of the source code.
And did you open the page with the switch settings, set the switch type to "switch" (other selection is "dimmer") and save the settings? (or even try to set it to dimmer and then set it again to switch and save in between)
I used the Arduino IDE (1.8.5) to flash my Sonoff. ReleaseNotes of my ESP-software:
// Rxxx 02-12-2016 EasyMega build (experimental)
// Native SPIFFS support, old custom flash routines removed
// Support OTA up to 1.5MB sketch size (change to 1M SPIFFS model) on 4M modules
// Fallback Wifi AP support
// Supports multiple active controllers
// Supports notification plugins (basic email _N001.ino provided)
// Native SD card support and system logging to SD card
// Taskvalues are preserved during reboot (not after power loss!)
// Multiple rule sets, max 4 sets, each 2k in size
// Several device plugins reworked and added to the main branch:
// P036 Framed OLED
// P037 MQTT import
// P038 NeoPixel
// P039 Thermocouple
// P040 ID12/RDM6300 RFID
// P041 NeoPixel WordClock
// P042 NeoPixel Candle
// P043 Timer Clock
// P044 P1 gateway
// Removed savesettings/savecustomsettings from candle plugin, check this later...
// UDP broadcast option prep
// Flash write protection mechanism (aded command 'resetFlashWriteCounter')
// IDX/var no longer mandatory and only requested when the selected controller needs it
// Clock#Time supports 'Wrk' for workdays and 'Wkd' for weekends as wildcards
// R148 02-12-2016
// Fixed a bug in ADS1115 plugin (contributed by Shardan)
// R147 27-11-2016
// Fixed a situation where a large message delay uses background processing without UPD handling, causing network issues.
// R146 20-11-2016
// Fixed a bug in PLUGIN_SERIAL/UDP calls where eventstruct data was not prepared
// Ser2Net plugin RXWait would only work as expected on task 1
// R145 13-11-2016
// Removed controller specific code from the framework (Domoticz test routines)
// Fixed device table display
// R144 12-11-2016
// Fixed PCA Plugin init (contributed by thexperiments)
// R143 02-11-2016
// Added nodeType for future use
// R142 26-10-2016
// Fixed some more missing I2C scanner devices. Changed 'known' into 'supported'
// Changed help items to www.letscontrolit.com/wiki
// Added a retry mechanisme on NTP response failures, to minimize booting with time set to zero...
// R141 21-10-2016
// Fixed pulsecounter value display style elements
// Fixed some missing I2C scanner 'known devices'
// R140 16-10-2016
// Added PCF8574A at default address as known device
// R139 14-10-2016
// Fixed a bug with Domoticz MQTT protocol. Broken as of R109, due to the new pubsub library
// It also needs a patched pubsub library!
// Also fixed a specific crash situation on invalid data
// R138 10-10-2016
// Fixed publish command
// Fixed boot event, triggered after getting the system time
// R137 09-10-2016
// Added formula option for pow calculations like 2^3 in (contributed by pm-cz)
// R136 07-10-2016
// Added NodeMCU/Wemos pin numbers (contributed by nonflammable)
// Added Pressure altitude adjustment to pressure sensors (contributed by adrianmihalko/pm-cz)
// R135 05-10-2016
// Added build and unit name to the node list
// R134 04-10-2016
// Corrected Typo and password field type change
// Added %eventvalue% that can substitute the event value in actions
// Added total to the pulse counter as single value (not persistent counter!) (contributed by fvdpol)
// Added authentication to http controller (contributed by marcfon)
// Added SPI support in hardware tab (contributed by moelski)
// Added NodeMCU/Wemos pin numbering to GPIO list (contributed by moelski)
// R133 26-09-2016
// Added rule events to SerialServer and SerialSend command
// Changed 'wrap on' to 'wrap off' in rules editor
// R132 24-09-2016
// Moved ISR handlers for Pulse, RFID and HCSR04 plugins to iram cache
// R131 11-09-2016
// Added flash write counter (count since boot), displayed in webgui
// Update plugin BME280 for calibration data on multiple sensors (contributed by maxx333)
// R130 10-09-2016
// Fixed some code when using SPIFFS (not recommended!)
// Support DS1825 (contributed by maxx333)
// R129 08-09-2016
// Update plugin BH1750, support multiple sensors (contributed by guslinux & pm-cz)
// Update plugin BME/BMP280, (contributed by pm-cz)
// R128 06-09-2016
// Update FHEM plugin (contributed by ddtlabs)
// Change for decimals on SI7021 humidity (contributed by pm-cz)
// R127 04-09-2016
// Fixed the situation where using the old style MQTT gpio/pwm commands left event-Par3 uninitialized.
// causing an 'endless' delay using pwm command
// R126 28-08-2016
// Added JSON support on FHEM controller plugin (contributed by ddtlabs)
// R125 27-08-2016
// Update OLED plugin, support for smaller displays (contributed by ToniA)
// R124 20-08-2016
// Corrected minor issue on plugin_027
// Adjustable serial RX Receive timeout in Ser2Net plugin. To collect entire message and send it as one TCP packet.
// Added generic UDP controller, C010
// Added SENSOR_TYPE_QUAD, mainly for dummy device
// Code optimization for controllers C004, C005, C006, C008
// Added default template to C008
// Added IR TX plugin from the playground as P035, (contributed by cherowley)
// R123 19-08-2016
// Added support for the DHT12 sensor, successor of the famous DHT11. (contributed by pm-cz)
// It can be used as single wire or I2C.
// R122 16-08-2016
// Check on unit number < UNIT_MAX before adding self to the nodelist. This would corrupt the nodelist data structure for units > 31
// Fixed another potential buffer overflow when logging ser2net data. And changed the fix from R119. Extended Ser2Net logging.
// Increased the syslog buffer size to 256 bytes.
// R121 11-08-2016
// Added option for MQTT retain flag. Can be configured in /tools/advanced
// Added internal TaskRun <tasknr> command
// R120 10-08-2016
// Removed formula fields from the Dummy Device. This will not work anyway. Use a formula in TaskValueSet command instead.
// R119 09-08-2016
// Fixed calculation for DS1820 DS18S20 with extended precision for negative temperatures (contributed by saschaludwig)
// Bugfixes for uninitialized variable and potential buffer overflow (contributed by bertrik)
// Bugfix pulse commands for PCF8574 plugin
// Main webpage shows sketch size / free size
// R118 03-08-2016
// Added the Dummy Device to production (used in the testlab in the past, but can also be useful for production purposes)
// You can use "TaskValueSet <task nr>,<variable nr>,<value>" in the rules section to set values
// Sending and retrieving values works just like any other sensor, using the template [<name>#<valuename>]
// Prepared framework for SENSOR_TYPE_DUAL
// R117 01-08-2016
// Added support for FHEM using HTTP protocol (contributed by ddtlabs)
// R116 01-08-2016
// Counter plugin can be set to "Delta" (original and default setting for Domoticz incremental counter) or "Delta/Total/Time" for other controllers that can handle this counter type
// R115 31-07-2016
// Provided controller plugin calls CPLUGIN_WEBFORM_SAVE and CPLUGIN_WEBFORM_LOAD to support custom controller configurations stored in flash.
// R114 22-07-2016
// Cleanup code, conditional core 2.0.0/2.1.0 support removed, changed to core 2.3.0
// The web gui now shows the core version used to build the release.
// R113 21-07-2016
// Bugfix in rules processing with multiple value devices, only the first value would work as expected
// R112 19-07-2016
// Bugfix for timezones other than whole hours offset. It is now set in +/- minutes
// R111 18-07-2016
// Bugfix parsing rfid (SENSOR_TYPE_LONG) values in parseTemplate function
// R110 16-07-2016
// Improved Serial Server plugin, reconnect handling
// Improved thingspeak and emoncms plugins (contributed by pm-cz)
// R109 12-07-2016
// Fix HTU21d timing
// Support internal pullup for SHT1X plugin
// Moved to pubsubclient 2.6 library (source no longer compatible with 1.9 library, so use the 2.6 version!)
// R108 07-06-2016
// Support for MS5611 temp/baro sensor (contributed by Battika)
// Support PWM fade (contributed by qubeck).
// Use only for small fade times as it's a blocking function!
// R107 21-05-2016
// Support to include VCC reading at compile time, defaults to disabled. (contributed by Battika)
// R106 10-05-2016
// Added support for DS1820/DS18S20 sensor types
// Option to change connection failure threshold, set to 0 to disable.
// R105 26-04-2016
// Bugfix for event names ending with "on "
// Added support for SHT1X sensors like the SHT10 Soil Moisture sensor (contributed by MarkBergsma)
// R104 25-04-2016
// Added a few lowlevel networking commands, to be used in the rules section:
// SendToUDP <ip>,<port>,<message> sample: SendToUDP 192.168.0.123,65500,Hello
// SendToHTTP <ip>,<port>,<path> sample: SendToHTTP 192.168.0.8,8080,/json.htm
// Reduced flash load size to 2048 in rules engine and use static pointer to save memory on recursive calls
// Max nesting level on rules is 3 levels deep
// R103 19-04-2016
// Upon request, added option for factory default static IP settings.
// R102 19-04-2016
// Added support for BMP280 (contributed by PM-CZ)
// R101 17-04-2016
// bugfix P020, the savetasksettings was obsolete, the loadtasksettings was not...
// Use hostname in C008 protocol if the controller hostname is configured (instead of IP)
// R100 13-04-2016
// Moved UDP handling from background tasks as it could lead to recursive function call issues on globalsync receive
// Some more experimental features:
// - Added option to send rule events using http control page: /control?cmd=event,<event> (single event buffer limitation applies!)
// - Added option to send rule events using openhab MQTT protocol: publish event,<event> to <template>/cmd (single event buffer limitation applies!)
// - Added 'SendTo <unit>,<command>' command for remote unit control commands (uses the internal peer to peer UDP messaging)
// - Added 'Publish <topic>,<value>' command to send remote commands to other ESP using MQTT broker
// R99 11-04-2016
// Moved PLUGIN_INIT call from webserver form post request after savesettings
// Device table no longer displayed when task is in edit mode, to reduce page size.
// Removed obsolete taskload/save from P020
// Removed obsolete taskload from P004
// R98 10-04-2016
// Fixed boot state send for GPIO for state=1
// Added send state at boot stage for MCP and PCF plugins
// Added option to periodically send input switch states (set timer value to >0)
// R97 09-04-2016
// Bugfix, unable to deselect LED pin when I2C is not configured on any pin.
// R96 07-04-2016
// Bugfix in caching of ExtraTaskSettings
// R95 31-03-2016
// Removed AP config within WifiApMode function, not needed as it is already set at WifiAPConfig
// Added logging to AP mode change
// Added periodic Wifi reconnect check when Wifi connection is lost, AP will be active during this stage
// Set status led pin to -1 on factory reset
// Removed some obsolete debug commands
// R94 30-03-2016
// Fix for clock event rules and added size counter for rules interface (currently 2048 byte max)
// R93 27-03-2016
// Enabled senddata for remote feed sensors and suppressed additional config settings on remote feed tasks.
// Settings save bug, sends 32 sectors instead of only 8 needed. Also the offset 2048 was wrong in the second client.write
// Added Name, Unit number, Build and datestamp to the config file name, sample: Config_DemoESP_U12_R93_2016_3_27.txt
// R92 26-03-2016
// Fixed rounding bug, it seems that String() has a bug with 0 decimals, adding a leading white space. Fixed with toString wrapper.
// R91 20-03-2016
// Added globalsync option to Dallas plugin config
// R90 20-03-2016
// Changed DHT plugin timing, start pulse delay wait was 80/40, should be 80/80. It could result in reading 'half' values.
// R89 20-03-2016
// Added simple load indicator by counting and comparing idle loop counts during initial delay and working mode.
// Moved custom value display of SENSOR_TYPE_LONG from plugins to webserver.ino
// Changed <Base64.h> to <base64.h>, case sensitivity issue on Linux
// R88 19-03-2016
// Option to set decimals for sensor values reported to controller and display. (internal precision remains unchanged)
// Changed DHT plugin timing, 40 -> 20 uSec
// Increased taskname and valuename fieldsize from 25->40
// IMPORTANT NOTE: Stored settings to file will become invalid, need to resave after upgrade to R88!
// R87 18-03-2016
// Remote sensors also create event for rules
// Fixed IR sensor type, should be SENSOR_TYPE_LONG as it is a unsigned long value.
// Note: the resulting value will change because it was rounded to a limited precision float before!
// R86 18-03-2016
// Commmand output on tools/command into readonly textarea
// Print "Ok" or "Unknown command" for commands. Most commands report back to source (serial,http,mqtt)
// Enabled experimental globalsync feature (could display values from remote sensors on local OLED...)
// Enabled experimental rules feature (used for testing but may also serve other purposes...)
// R85 13-03-2016
// Preparations for Arduino Core 2.1.0
// Fixed and tested HTTP authentication in C001
// Servo library seems to have issues in Core 2.1.0. Using the servo library from 2.0.0.
// I2C clockstretchlimit can be set using tools/advanced.
// Preparations for global pinstate maintenance and status requests
// Redesign on plugin write output reporting as it was still focussed on HTTP only.
// R84 08-03-2016
// base64 encoding for HTTP authentication in C001
// ConfigSerial casting in ser2net plugin
// Wire.setClockStretchLimit(2000) for better PN532 support
// Bugfix command handling for openhab MQTT protocol using a non default subscribe
// Added standard logging mechanisme to plugin writes
// R83 03-03-2016
// Bugfix for ExtraTaskSettings.TaskIndex that was not stored in flash
// Optimized parseTemplate performance.
// R82 26-02-2016
// Experimental support for Domoticz MQTT protocol using actuator devices
// currently limited to On/Off switches and one channel Dimmers and only build-in GPIO's
// Use parseCommandString in Webserver handle_control
// Added option to use plugin commands in tools/commands
// Display flash size in kB.
// Restructured main loop
// Changed sensor timer scheduling, adjust with message delay to spread readings, prevent bursts
// Removed protocol.name from global memory struct to save RAM
// Added global system timers
// Added "LongPulse" commands for build-in GPIO, MCP23017, PCF8574 and PME, using non blocking system timers (inspired by chunter1)
// R81 23-02-2016
// Added SSDP custom version that uses much less RAM than default library, disabled by default, can be enabled in tools/advanced (contributed by mneuron)
// R80 17-02-2016
// Added logging controller TCP port
// Bugfix, set default task timer to main delay if no value entered.
// Added support for all commands on OpenHAB MQTT, using "<system name>/cmd" topic and the message contains the entire command.
// Added Wifi signal strength reporting using the System Info device
// Added network traffic indication to Wifi status led
// R79 16-02-2016
// Bugfix: I2C Scanner mentions PCA9685 as possible device for address 0x40
// Added missing pulse feature for PCF8574
// Added Wifi status LED
// Added option to send boot state on Switch Input device
// Added option to use GPIO-1 and GPIO-3 for other purposes than Serial (must disable serial in tools/advanced!)
// Added individual timers per task
// R78 06-02-2016
// Bugfix for PCF8574 plugin, could not address PCF8574A chip types
// R77 04-02-2016
// Bugfix PN532, code cleanup
// The PN532 will not work properly with the current ESP Arduino Core 2.0.0. (!)
// Connect the PN532 RSTPDN pin to a GPIO port and configure this in the device settings as reset pin
// It will likely reset the PN532 several times a day.
// Best we can get so far. May be fixed in Arduino ESP core 2.1.0
// R76 31-01-2016
// Added retry to PN532 init step
// R75 31-01-2016
// Fixed a bug for generic http url request variables that needed URLEncoding
// Fixed too aggresive reset action, PN532 now only resets after three consecutive read errors.
// R74 30-01-2016
// Fixed a bug where using both controller IP and (DNS) hostname leads to unwanted behavior
// more specifically if there is confusion between ESP hostname and controller hostname
// now you have to select location by IP or DNS and can't enter both fields simultaniously
// Fixed a bug for RFID plugins that provide long values to the controller plugin, did not work for the generic http controller plugin
// R73 28-01-2016
// Removed flashcheck (did not prove much) and many other debug commands
// Update PN532 plugin, should work better now. And added optional reset GPIO pin.
// R72 23-01-2016
// Added flashcheck <start>,<end> command (simple read check)
// R71 23-01-2016
// Changed DHT nul reading logic
// Added connect failure check in MQTT protocol
// Added more info on 'flashdump' serial command
// Factory reset erases entire flash except the sketch and zero fills 64k SPIFFS block
// System halts with error message if no SPIFFS area set.
// R70 22-01-2016
// Avoid reporting DHT nul readings.
// Changed timing SI7021 (contributed by Hallard)
// R69 20-01-2016
// Cosmetic: removed last empty table row in device edit screen
// Added help button to firmware upload
// Added delay to DHT sensor
// Removed interrupt blocking from DHT sensor to avoid Wifi/Network handling issues in the ESP core
// Removed interrupt blocking from Dallas sensor to avoid Wifi/Network handling issues in the ESP core
// Moved UDP check from main loop to background routine
// Webgui now reports ESP.getFlashChipRealSize()
// Added detection of missing BMP085 sensor during init
// Added option to reset target device when the Ser2Net plugin has initialized.
// R68 17-01-2016
// Changed UDP logging
// Added OTA update using bin file upload through the ESP Easy webgui (NOT from arduino IDE!)
// THIS WILL ONLY WORK ON MODULES WITH MORE THAN 512K FLASH, like the ESP12E modules!
// R67 16-01-2016
// Added plugin for BME280 Temperature/Humidity/Barometric pressure sensor
// R66 16-01-2016
// Added plugin for INA219 voltage & current sensor
// Fixed LCD/OLED padding and now it should actually work in all cases...
// R65 15-01-2016
// Changed UDP transmit delays
// Fixed padding feature that broke the option to skip empty lines for local display
// Added system info plugin (single value device type)
// Added some system info to http json request output
// R64 14-01-2016
// Experimental: Added simple json interface to retrieve sensor data using http
// Experimental: Prepare tasks for remote data feed (Work in progress...)
// Added %uptime% as variable for display
// Added padding to LCD/OLED display
// Added support for local button to turn on LCD/OLED display with configurable timeout
// Changed: no system time displayed when NTP is disabled
// Added protocol option "Standalone" for units without a controller
// Fixed UNIT_MAX in node list
// Added boot config for GPIO pin states
// R63 10-01-2016
// Added Wifi connect setup 'wizard' using captive portal
// Enabled formula for PME plugin
// R62 09-01-2016
// Changed Pro Mini Expander plugin to read 10 bit analog values
// Pro Mini sketch is also updated, so reprogram your Pro Mini too!
// R61 08-01-2016
// Fix SI7021 plugin for compatibility with HTU21D (contributed by Hallard)
// added a few more mSec to each settings, because my SI7021 sample still had read errors...
// Added boot cause info for external watchdog
// R60 05-01-2016
// Prepared for plugin numbers ranging between 1-255 (maximum active is still limited to 64!)
// Changed hardcoded page limit 4 to TASK_MAX/4
// Added support for MLX90614 IIR Temperature sensor (contributed by lindeger)
// Added support for ADS1115 ADC (contributed by lindeger)
// R59 02-01-2016
// Replaced delay(10) with yield in backgroundtasks()
// Changed PN532 plugin init stage en reduced sample frequency
// Restored original I2C Watchdog feed for further development
// Fixed bug in HCSR04 and other plugins where buffersize was too short
// R58 28-12-2015
// Fixed bug with right align on LCD 4x20
// Time feature can be disabled with #define at compile time
// No longer using time library, moved relevant parts to Misc tab
// Set system name as DHCP hostname
// Fixed bug with levelcontrol for other values in taskvalue dropdown list
// R57 23-12-2015
// Moved display template handling to generic function parseTemplate() to avoid a lot of similar code in both plugins.
// Added some variable features to LCD/OLED template, you can use %sysname%, %systime% and %ip%
// NTP time can be enabled through advanced settings and defaults to disabled
// Added clear command to LCD/OLED plugins
// R56 22-12-2015
// Added DNS static config option
// Added NTP host name config (optional, defaults to pool.ntp.org)
// Added TimeZone config
// Added Controller Hostname config (optional, use instead of IP)
// Added System time to main info page
// Added switch case to ThingSpeak controller
// R55 21-12-2015
// Experimental development: Added time lib and NTP support
// Bugfix for LCD plugin display size
// R54 20-12-2015
// LCD I2C address and display size can be configured in the webgui
// OLED I2C address and display rotation can be configured in the webgui
// OLEDCMD and LCDCMD commands added to turn the display on or off
// Removed the +15 offset in BH1750 plugin
// R53 19-12-2015
// Added some serial debug commands:
// "load" to load settings from flash while running
// "flashdump <start>, <end>" to show flash contents
// Changed WifiConnect, added retry and changed delays, set static ip before connecting
// Wifi config is no longer persistent in SDK controlled flash memory
// R52 17-12-2015
// Changed send delay routine
// Added feature "Send data" enable/disable to all tasks
// Removed "send data" setting from Level Control plugin since this is now standard
// Check on build changes to fix some changes in tasks
// Removed all urlDecode() since this is handled in the ESP Core as of stable 2.0.0
// R51 13-12-2015
// Changed UDP handling back to a single socket for RX/TX
// Moved LCD init from main tab to LCD plugin
// Added pulse support on MCP23017 (contributed by fgmx85)
// R50 10-12-2015
// First attempt on having a generic HTTP controller interface
// R49 08-12-2015
// Changes to urldecode and WPAKey handling (contributed by ixtrader)
// Added MQTT authentication (contributed by Chrille)
// Changing protocol sets default TCP port
// R48 01-12-2015
// Code cleanup, candidate for Arduino ESP Core 2.0.0.
// R47 29-11-2015
// Support for using http commands to control OLED en LCD displays
// R46 28-11-2015
// Added Wiki help button to Protocol dropdown
// Added basic text message support for I2C OLED SSD1306 display
// R45 22-11-2015
// Bugfix: PCA9685 plugin needs to be listed in the dropdown list
// else counting/sorting will have issues. But it currently has no real purpose
// R44 22-11-2015
// Added basic support for PCA9685, simple pwm output using control web page
// R43 15-11-2015
// UDP calls to plugins
// Bugfix for TSL2561 plugin
// R42 08-11-2015
// Added support for serial to WiFi bridge applications (very experimental state!)
// Added limited support for local level control like thermostat function (questionable development for a sensor!)
// Device dropdown list is alphabetically ordered
// R41 01-11-2015
// Added support for Sharp GP2Y10 dust sensor
// Added support for PCF8574 IO Expander
// R40 25-10-2015
// Added support to read classic Mifare tags with PN532 NFC module
// Fixed sending of Tag values as a real 32 bit long value (no rounding, no decimal fraction)
// R39 17-10-2015
// Added support for IR signal reception (needs a third party library!)
// R38 13-10-2015
// Added support for I2C TSL2561 Luminosity Sensor (contributed by Hallard)
// R37 12-10-2015
// Added support for I2C SI7021 Temperature Humidity sensor (contributed by Hallard)
// R36 11-10-2015
// Added support to control (max 2) Servo motors using http control commands
// R35 11-10-2015
// Finally finished the LCD plugin with some basic functionality
// Preliminary controller support for EmonCMS
// R34 10-10-2015
// Changed controller password length from 25 to 63 chars.
// If you have set a system password, it will be cleared with this update
// R33 10-10-2015
// Limit flash reset cycle to 3 attempts after cold boot. It will then enter rescue mode.
// R32 09-10-2015
// Fixed a bug in negative values on Dallas DS18b20 and added CRC check
// R31 08-10-2015
// Added more information on dallas plugin and set value to NaN on read errors.
// Changed all serial.print() commands to addlog() where they could conflict with future serial plugins
// R30 06-10-2015
// Moved all controller specific code to CPlugin mechanism (similar to device plugins)
// Added debounce feature to pulsecounter plugin
// R29 03-10-2015
// Fixed bug with idx values > 255. Bug was introduced in R22
// R28 03-10-2015
// Merged Pro Mini extender plugins into one single plugin
// R27 02-10-2015
// Changed MCP23017 plugin to scan inputs realtime instead of using the system timer mechanism
// Changed MCP23017 default pullup resistors on input pins
// Moved MCP23017 output and generic GPIO and PWM to device plugins
// Added simple pulse option for GPIO outputs (only for small pulses less than a few seconds).
// R26 01-10-2015
// Changed internal stylesheet to new skin
// Save configuration settings into SPIFFS reserved area without using SPIFFS
// Reduced code size by disabling SPIFFS to make it work in the latest staging release
// R25 27-09-2015
// Switch plugin supports push button (toggle) switch, selectable for active low or high
// R24 27-09-2015
// Right-aligned device values in device table
// Added periodic MQTT connection check
// Fixed issue with the AP WPA Key configuration
// R23 26-09-2015
// Fix device table layout for some browsers
// Added link to stylesheet "esp.css" located on SPIFFS
// Removed style attibutes from individual tags so it can be arranged with css
// Added delete button in SPIFFS file list
// R22 25-09-2015
// Using Spiffs filesystem support for configuration settings
// All configuration settings are now stored into the ESP filesystem.
// Task string fields are now dynamically loaded from spiffs when needed. Saving RAM...
// Optimize RAM usage by changing device structure array and handling of device strings
// Added option to load and save ESP configuration settings from/to file
// Cleanup all fields when a task is cleared or device is changed
// Moved keys and passwords to a separate file
// Added option to change valuenames (mainly MQTT purpose)
// MQTT publish & subscribe settings can be changed using a template
// Moved some advanced settings to tools/system/advanced button
// Dallas plugin now supports multiple devices on the same bus
// R21 21-09-2015
// Added more logging to MQTT
// Added mcpgpio to valid list of control commands
// Fixed hardcoded MQTT broker port
// R20 13-09-2015
// Changed factory reset, first wipe entire eeprom size to zeros
// Added option to do a factory reset by connecting RX and TX pins during boot
// Added a help button on the device page that leads to the device specific page on our Wiki
// Preliminary support for deep_sleep
// R019 13-09-2015
// Added support for the HC-SR04 Ultrasonic distance sensor
// Input switch can now be set to send switch state or dimvalue
// Other minor internal changes
// R018 09-09-2015
// Fixed issues with special characters (#,% etc) in text fields like SSID, WPA key etc
// R017 08-09-2015
// Fixed factory reset formula settings.
// Preliminary support for PiDome MQTT protocol
// Total rework of all sensor devices, moved code to plugin files for easier maintenance and extensibility
// Plugins can extend the device webform with custom settings
// Changed EEPROM size to 2048
// System no longers needs a reboot after adding/changing specific (IRQ) devices like pulsecounters
// Changed Device table, shows valuenames for devices
// Prevent input switches from firing at boot time, first read current state during init
// Added option to inverse input switch logic
// Changed WPA key limit to 63
// Some code cleanup, removing old debug commands
// R016 29-08-2015
// Preliminary support for IO extender based on Arduino Pro Mini through I2C
// Added GPIO-9 and GPIO-10 for boards equipped with an ESP12E module (NodeMCU V1.0)
// Finished support for PCF8591 4 channel Analog to Digital converter.
// Added support for MCP23017 input ports
// Unit Name is shown in html title
// Show 'well known' devices in the I2C scanner based on their I2C address
// Added option to use simple formulas on device values like "%value%/1000"
// Fixed char string handling that should be 25 chars max
// Added option to turn on/off internal pullup for switch input pins
// Added option to set a name for each task (also used for OpenHAB MQTT publishing)
// Preliminary support for OpenHAB MQTT protocol
// R015 22-08-2015
// Fixed a bug in DHT22 device
// Fixed a bug in setting for default delay
// Changed debug info
// Changed device tab, added more pin info and cancel button
// Fixed syslog loop bug
// R014 20-08-2015
// Redesigned device configuration mechanisme
// Changed password timeout to 5 minutes
// Added direct GPIO output control without password request
// R013 15-08-2015
// Added configurable message delay in ms (delay between messages to controller)
// Changed login password field to type 'password'
// Fixed io pin settings for Dallas/DHT for inconsecutive pin configuration (ESP-01)
// Support for ThingsSpeak "controller" (webservice)
// R012 07-08-2015
// IMPORTANT NOTICE: this release needs ESP Package version 1.6.5-947-g39819f0, built on Jul 23, 2015)
// If udp port = 0 no actions!
// Used sprintf_P to save more RAM
// Added login page and admin password
// Added hardware custom gpio pin selection
// Added sanity check on BMP085 pressure values
// R011 12-07-2015
// Changed javascript link buttons into CSS button styled href links
// Fixed Main button, only worked on IE.
// Changed connectionFailures counting
// Reboot from main loop instead of web event callback
// Changed logging configuration
// BaudRate can be configured through webgui, defaults to 115200
// Added Serial.setDebugOutput(true) if serial loglevel = 4 (debug_more level)
// Added telnet protocol to send variable data to a Nodo Mega controller
// Added webgui I2C scanner
// Added webgui Wifi scanner
// Fixed bug in settingssave on devices
// Added delay(1) in Domoticz_sendData, while available loop
// R010 30-06-2015
// Changed freemem request in root web page
// Some memory reduced by eliminating globals
// Init MQTT at boot only if protocol is set to MQTT
// Added syslog level for detailed logging
// Added menu buttons in webgui and stuctured data as HTML tables
// R009 26-06-2015
// Changed switch pin from GPIO-0 to wired input pin 1
// Added config options for static IP/gateway/subnet
// Using LCD library instead of local functions
// Added MQTT library
// Added JSON parse library
// Needs Domoticz 2560 and Mosquitto 3.1.1 or higher
// Reduced EEPROM from 4096->1024 (needs a RAM buffer from same size!)
// Added basic logging to web interface
// R008 06-06-2015
// UDP listening port web configurable
// If UDP port enabled, also send IDX events to this UDP port
// Added Domotics lightswitch option, input on GPIO-0 pin.
// R007 01-06-2015
// use custom counter for WD instead of millis() (millis does not reset on ESP.Reset)
// Changed BAUDrate to 9600
// DomoticzGet <type>, <idx> test command (via serial)
// R006 23-05-2015
// Stored many constant strings to progmem
// delay(1) into http 'while' client check
// delay(10) in main loop instead of yield()
// DomoticzSend <type>,<idx>,<value> test command (via serial)
// Disabled analogRead, seems broken in g8cd3697 (use millis()/1000 as demo value!)
// R005 21-05-2015
// Some fixes to be compabtible with Arduino 1.6.4 using ESP board addon 1.6.4.-628-g545ffde
// R004 18-05-2015
// Fixed setting ip_octet to 0 on reset
// Fixed missing ; in domoticz send case 3:
// Fixed: Serial Pulse settings command did not work.
// Very experimental stuff for Nodo events on I2C (Nodo 3.8, R818)
// Some code optimization in string/char-array handling within webserver functions
// Replaced 'reboot function call' with ESP.reset
// Added hardware config web page to change io pins on ESP-01 boards
// Added basic stuff for UDP communications and syslog function
// Listens on UDP port 65500 for commands.
// Added connectionFailure counter
// Sends "WD <uptime in seconds> CF <connection failures>" every 30 seconds on serial to reset external watchdog
// Sends "WD <uptime in seconds> CF <connection failures>" to syslog if configured
// Delayed reboot on empty IP adress (in case of DHCP issue)
// Delayed reboot after 30 connection failures
// R003 06-05-2015
// Start AP mode if no connection, leave AP mode 30 seconds after succesfull connection
// Added option to set a fixed last octet of the ESP IP address (remaining config is still done with DHCP)
// This is the easiest way. You can still change subnet,gw,dns with DHCP but have a fixed IP
// This is convenient to control ESP with Domoticz http requests (relais, io expander, etc)
// Support for Domoticz multiple value sensor types (temp/hum/baro)
// Added support for pulsecounter
// R002 02-05-2015
// Added configuration webinterface
// Start AP mode is ssid is not configured
// R001 01-05-2015
// First 'stable' edition (meaning that it does not crash during boot of within one minute...)
OK, that's quite an old version.
The year 2016 is not even mentioned anymore in the current release notes. https://github.com/letscontrolit/ESPEas ... _notes.txt
I think it is best if you test a newer version. In 14 months a lot has been fixed.
You can try the pre built versions. See: https://github.com/letscontrolit/ESPEasy/releases
Perhaps also make a backup of your settings first in case you want to go back to the previous version.
Or right. It takes me the hole morning tot update the sonoff with the newest espsoftware and no succes. All the different versions maks me crazy. I used
Aduino IDE 1.8.4 (also tried 1.8.5)
ESP Release v2.0-20180218 (latest)
A Sonoff Basic (recent)
Board: ESP8266 version 2.3.0 (when I update this to latest 2.4.0. I get a message that only 2.3.0 is supported)
Are these the correct latest version which are compatible?
I coppied the content of the libfolder from ESP-folder to the Arduino IDE librariesfolder.
I use a Macbook to flash the sonoff with a USBtoUART.
Now I get some failures in IDE:
Arduino: 1.8.4 (Mac OS X), Board:"Generic ESP8266 Module, 80 MHz, 40MHz, DOUT, 115200, 1M (128K SPIFFS), ck, Disabled, None"
WAARSCHUWING: Categorie 'LED' in bibliotheek CHT16K33 LED Matrix Library is niet geldig. Wordt gewijzigd naar 'Uncategorized'
WAARSCHUWING: Categorie 'Input' in bibliotheek MechInputs is niet geldig. Wordt gewijzigd naar 'Uncategorized'
WAARSCHUWING: Categorie 'Input' in bibliotheek SerialSensors is niet geldig. Wordt gewijzigd naar 'Uncategorized'
WAARSCHUWING: bibliotheek LiquidCrystal_I2C beweert te werken onder architectuur (avr) en kan incompatible zijn met uw huidige board dat werkt onder architectuur (esp8266).
In file included from /Users/remko/Documents/Arduino/libraries/SD/src/utility/Sd2Card.h:26:0,
from /Users/remko/Documents/Arduino/libraries/SD/src/utility/SdFat.h:29,
from /Users/remko/Documents/Arduino/libraries/SD/src/SD.h:20,
from /Users/remko/Downloads/Sonoff/ESPEasy_v2-3/Source/ESPEasy/ESPEasy.ino:383:
/Users/remko/Documents/Arduino/libraries/SD/src/utility/Sd2PinMap.h:510:2: error: #error Architecture or board not supported.
Meerdere bibliotheken gevonden voor "Servo.h"
Gebruikt: /Users/remko/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/libraries/Servo
Niet gebruikt: /private/var/folders/1y/18pq4k_55ng7dqc1cstw4wz00000gn/T/AppTranslocation/7FB2D785-D998-4B65-AE90-DFB9D0DE1272/d/Arduino.app/Contents/Java/libraries/Servo
Meerdere bibliotheken gevonden voor "SD.h"
Gebruikt: /Users/remko/Documents/Arduino/libraries/SD
Niet gebruikt: /Users/remko/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/libraries/SD
Niet gebruikt: /private/var/folders/1y/18pq4k_55ng7dqc1cstw4wz00000gn/T/AppTranslocation/7FB2D785-D998-4B65-AE90-DFB9D0DE1272/d/Arduino.app/Contents/Java/libraries/SD
Meerdere bibliotheken gevonden voor "ArduinoJson.h"
Gebruikt: /Users/remko/Documents/Arduino/libraries/ArduinoJson
Niet gebruikt: /private/var/folders/1y/18pq4k_55ng7dqc1cstw4wz00000gn/T/AppTranslocation/7FB2D785-D998-4B65-AE90-DFB9D0DE1272/d/Arduino.app/Contents/Java/libraries/ArduinoJson
Meerdere bibliotheken gevonden voor "IRremoteESP8266.h"
Gebruikt: /Users/remko/Documents/Arduino/libraries/IRremoteESP8266
Niet gebruikt: /private/var/folders/1y/18pq4k_55ng7dqc1cstw4wz00000gn/T/AppTranslocation/7FB2D785-D998-4B65-AE90-DFB9D0DE1272/d/Arduino.app/Contents/Java/libraries/IRremoteESP8266
Meerdere bibliotheken gevonden voor "Adafruit_NeoPixel.h"
Gebruikt: /Users/remko/Documents/Arduino/libraries/Adafruit_NeoPixel
Niet gebruikt: /private/var/folders/1y/18pq4k_55ng7dqc1cstw4wz00000gn/T/AppTranslocation/7FB2D785-D998-4B65-AE90-DFB9D0DE1272/d/Arduino.app/Contents/Java/libraries/Adafruit_NeoPixel
exit status 1
Fout bij het compileren voor board Generic ESP8266 Module
Dit rapport zou meer informatie bevatten met
"Uitgebreide uitvoer weergeven tijden compilatie"
optie aan in Bestand -> Voorkeuren.
Why not simply testing with a pre-built binary first to see if the problems you had were actually fixed?
Then you don't have to change a lot to your dev environment.
I tried this with my terminal:
The flash has succeeded but no esp_0.
Because I have previously experienced this I read a tip that I can solve this by flashing with the Arduino IDE. But this now also causes problems. Do I not do flashing via the terminal properly? Is there another simple way to easily flash with a mac without problems with no esp_0 on a sonoff?
sudo python esptool.py --baud 115200 --port /dev/tty.SLAB_USBtoUART write_flash -fm dout 0x00000 ~/Downloads/ESP_Easy_v2.0-20180218_dev_ESP8266_1024.bin
Are you sure the Sonoff has an ESP8266 and not an ESP8285?
There is a pre-built version for that chip too.
No I think it is a normal 8266 chip, my terminal says:
when I try to flash it with a prebuild 8285 version.
Chip is ESP8266EX
n
You must set correct switch mode in ESPeasy.
"Switch Button Type: Normal Switch or Push Button
It depends on your mechanical switch type.
If you have got push button, select Push Button and then each press of switch changes relay state.
If You have got ON/OFF switch, select normal switch and then each change of state this switch will change state of relay.
And on ESPeasy uncheck "send to controller" on relay device.
Do not write IDX there, its not needed, you send command via http request.
And on Domoticz side: If you have god checked send to controller, there will be some message pingpong between Domoticz and ESPEasy.
With my setup, if you switch relay in Domoticz, ESPeasy will set GPIO and do nothing.
If you press switch on ESPeasy ( sonoff ), ESPeasy sets GPIO and sends relay state to Domoticz.
And Domoticz in this moment sends back relay state to ESPeasy, but it is previously set to the same value, so it is not too wrong.
I have finally been able to flash the latest build (v2.0-20180220) on my sonoff basic.
Now I can continue with the actual problem.
If I want to switch my sonoff the signal seems to be pingpong so the sonoff switches on and off several times.
What have I done now:
I have 1 virtual switch in domoticz with on-off action:
-http://10.0.1.39/control?cmd=event,lamp_on
-http://10.0.1.39/control?cmd=event,lamp_off
In the ESP software I added two devices for my sonoff. 1 for GPIO-12 (called 'rele') and 1 for GPIO-14 (called ' SW01).
On the GPIO12 I connected a light.
On the GPIO14 I connected a normal wall switch (to my light) to ground and GPIO12 of my sonoff.
As a rule I added:
What I'm trying to achieve is that I can operate my light with the wall switch, but also from domoticz.
My gueass is that the rule isn't right and that's wy the signal pingpong but I can not figure it out. Can please someone help me?
As a rule I added:
on lamp_on do
gpio,12,1
gpio,13,0
on lamp_off do
gpio,12,0
gpio,13,1
on lamp_change do
if [rele#Switch]=1
event,lamp_off
SendToHTTP 10.0.1.32,8080,/json.htm?type=command¶m=switchlight&idx=1266&switchcmd=Off
event,lamp_on
SendToHTTP 10.0.1.32,8080,/json.htm?type=command¶m=switchlight&idx=1266&switchcmd=On
on SW01#Switch do
event,lamp_change
After some googling, I found out that a 10K resistance between GPIO14 and 3.3V could help. I have tried this and indeed it works perfectly now. Code is also correct. I can switch my lamp both with my wall switch and via domiticz and the status is perefect kept in domoticz.
Or enable internal pullup on SW01 device tab.
Users browsing this forum: No registered users and 124 guests
