Hello friends. Few days ago i get two esp8266-07. I mount them on adapter and also soldier AMS1117-3.3. i choose them because they have posibility to connect external antenna. When i connect them to programmer and flash it with ESP_Easy_v2.0.0-dev13_normal_ESP8266_1024.bin i get problems with right starting device.
I have the same on both modules so im thinking that is not problem with device. Does anyone have solution to run ESP Easy v2 on esp8266-07 ?
ESP8266-07 Flashing problems with ESP Easy 2.0.0.x
- budman1758
Re: ESP8266-07 Flashing problems with ESP Easy 2.0.0.x
I may be wrong but I think ESP-07 modules only have 512k of flash memory. The ESP-07S has 4 megs of flash. The -07 will not work with the newer versions of ESPEasy. I believe the newest version that will work is the R120 firmware. You can find those older releases here.
https://www.letscontrolit.com/wiki/inde ... g_firmware
Users browsing this forum: No registered users and 52 guests
