Sonoff Basic + wall push button with pilot light
Re: Sonoff Basic + wall push button with pilot light
Use the internal pull-up for GPIO14 ?
Or
Use a pull-up resistor of 100K for GPIO14 to 3V3?
Or
I enabled internal pull-up, it won't help, however without it things are much worse, switch goes off randomly even when wires are not connected to led and I touch them with bare hand.Domosapiens wrote: ↑04 Mar 2018, 20:28 Use the internal pull-up for GPIO14 ?
Or
Would you elaborate on connecting resistor? Where exactly should I put it?
I really think it's a bad idea to drive the LED via the same GPIO that you are trying to use as input. Just don't and you dont have a problem.kirkokuev wrote: ↑05 Mar 2018, 12:54I enabled internal pull-up, it won't help, however without it things are much worse, switch goes off randomly even when wires are not connected to led and I touch them with bare hand.Domosapiens wrote: ↑04 Mar 2018, 20:28 Use the internal pull-up for GPIO14 ?
Or
Try some serial resistor with LED.
LED will light less, but log 1 on GPIO will be better defined.
Will be good measure voltage on GPIO and compare with specification for log1 on ESP2866.
Something is wrong with the forum today.
Ok, I think I should revert to first suggestion and connect led separately, will try to do this on a weekend.
Reporting progress, I connected led separately as per toffel969 suggestion, good news that interference is gone. But led now is very bright, like two or three times brighter than on other switches, even those connected to 220v. I will see how well it works in the night, but I am not sure if it is appropriate for bedroom. Also is there any way to control 3.3v output on sonoff?
Either put a resistor in series or drive it of the other gpio, then you can set b rightness by means of pwmkirkokuev wrote: ↑08 Mar 2018, 12:28 Reporting progress, I connected led separately as per toffel969 suggestion, good news that interference is gone. But led now is very bright, like two or three times brighter than on other switches, even those connected to 220v. I will see how well it works in the night, but I am not sure if it is appropriate for bedroom. Also is there any way to control 3.3v output on sonoff?
So I reconnected led to the pin next to 3.3v, I can see that led is glowing, but much less than on 3.3v, it glows as much as on gpio14, but without interference. So far so good.
I disabled serial port and tried to control it via GPIO1 but with no effect ,it won't turn off or on, just stays glowing all the time.
OK, I tinkered a little bit more, so this is not a GPIO1, but GPIO3, and I am actually able to control it via commands. Seems like problem is solved, thank you all for help.
This setup was done on a Sonoff Basic Rev 1, isn't it? I need to run a similar setup on some Sonoffs Basic R2 but since GPIO14 was removed, I was wondering if I can hook up a Pulse Switch to GPIO0 without having any problems. In hand with a small short cord it works, but I was wondering if I use long cables if it causes any problems relating to high resistance.
Sonoff units always have their button (or at least one button for those with more than one) connected to GPIO-0.
By default it is pulled up and closing the button will pull it to GND.
This way you can use the button to enter flash mode during boot.
So if you plan to add something to GPIO-0, make sure it is not pulled down for a long enough time during boot.
e.g. a sensor which may send data is enough to make a reboot randomly fail when connected to GPIO-0.
Yes exactly. It will only be a return back pulse switch so it will give me the option to leave Basics on all the time while anyone else at home can use the wall switches as normal use. PS I have a Gewiss Playbus Pulse switching system at home. Eventually, I will remove the relays and use the switches as a Simple Rocker Switch. But my main concern is the protection of the CPU since probably ELV switching will run in parallel with 220v cables in the same piping. Any ideas, please??
Never assume these Sonoff units will be galvanic isolated.
The ones with power meters are obviously not isolated but the 'basic' ones are IMHO also not safe.
For example the older versions had a big trace on the PCB to carry the mains voltage to the connected appliance, but to handle more current, those were made thicker with tin and thus not isolated at all.
Also the distance between traces is not according to European safety rules so in humid environments you may still get sparks and/or shocks.
When switching something, please use optocouplers and make sure to use wires with proper isolation as thin wires should also not be placed near high voltage wiring with the kind of mediocre isolation you often see in these modules.
Users browsing this forum: No registered users and 119 guests
