Hi all,
I am trying to get bh1750 working under deep sleep.
My setup:
NodeMcu V3
BH1750 - I2C Address: 0x23 | Resolution_Low
BME280 - I2C Address: 0x76
YL-38 (Rain Sensor): Analog Input
In normal Mode all sensor elements work fine. I receive data in my moquitto MQTT service on raspberry pi v.3
Changing to deep sleep - all sensor elements work fine as well - as long "sleep delay" is lower/equal 60 (1 Min.).
When changing "sleep delay" to a value higher 60 (e.g.: 900 = 15 Min.) the ESP transmit all sensore data accurate - except BH1750 data.
For this sensor always 0 will be transmitted.
Any assistance/help is welcome
Franz-Josef
bh1750 in deep sleep
Re: bh1750 in deep sleep
Sounds like the sensor may need a reset to operate properly.
This is done in lots of other sensor plugins, perhaps not in this one.
Maybe worth an issue on Github?
I have a BH1750 connected to a Wemos D1 mini, with a deepsleep 0f 5 minutes.
And it is working like a charm.
The wemos also has a BMP280 connected on i2c (0x77, bh1750 is on 0x23).
But i have the resolution set to HIGH.
And have "Send sensor to sleep" not ticked.
Not sure if you have this on you version op ESPEasy, but thought i mention it.
So in my setup the BH1750 works great.
(I have 2 of these setups, both work great)
Users browsing this forum: Bing [Bot] and 139 guests
