SonOff POW R2 support
Prutsium
Re: SonOff POW R2 support
#11 Post by Prutsium » 11 Jun 2018, 08:21
larduino wrote: 06 Jun 2018, 18:15 I received my POW yesterday . I believe it must be version 1 since I don't see any mention on box that it is version 2 .
I just soldered in 4 pin header and flashed it using ESP_Easy_mega-20180606_hard_SONOFF_POW.bin and it all went well.
It is now wired up to 110v and I put an outlet on output to test it.
I have it set up as seen in attached screenshot. The voltage shows up but I have not figured out yet how to turn the relay on so I can have a load on it to see if current is working.
Thanks for any advice.
Yesterday installed the mega-20180606 (DEV) version on two POW R2's and all works great. See power, Watt, Amp & Count so totally no issues.
Although some questions:
1: Anybody experiance to send the value(s) to Domoticz and be able to see them? I created as usual a Dummy but since all is going over a single IDX a device is required in Domoticz that would be able to handle the 4 values.
2: I send the Pulses also to Grafana and figured out that 12530 pulses would mean 1KW (Right?) I would need an example for the Grafana part to see usage per day / year / total. I tried already a few settings but not sure if i do it right.
#12 Post by TD-er » 14 Jun 2018, 19:03
At this moment, if you want to split values from one plugin over multiple IDX, you have to use rules to do so.
For example, I use this on my node with SDS011 to upload to Domoticz:
On System#Boot do //This will happen at boot ESP8266
   timerSet,1,30  //Set and start timer 1 at 30 seconds
On Rules#Timer=1 do   //When the timer 1 is up:
  SendToHTTP 192.168.1.28,8080,/json.htm?type=command&param=udevice&idx=105&nvalue=0&svalue=[SDS011#PM25] //Send the PM2,5 data to Domoticz
  SendToHTTP 192.168.1.28,8080,/json.htm?type=command&param=udevice&idx=108&nvalue=0&svalue=[SDS011#PM10] ////Send the PM10 data to Domoticz
  timerSet,1,120                //Set the next cycle at 120 seconds
projectsun
#13 Post by projectsun » 15 Jun 2018, 00:26
Hello. Sorry, but where do I get this file: ESP_Easy_mega-20180524_hard_SONOFF_POW.bin
larduino
#14 Post by larduino » 15 Jun 2018, 02:00
projectsun wrote: 15 Jun 2018, 00:26 Hello. Sorry, but where do I get this file: ESP_Easy_mega-20180524_hard_SONOFF_POW.bin
It is included in the latest Mega development
https://github.com/letscontrolit/ESPEasy/releases
Prutsium
#15 Post by Prutsium » 15 Jun 2018, 10:26
Or use the latest version of the normal mega but the DEV version if you have the R2.
At least then you also have all the other options for additional sensors (although it requires then soldering as the internal serial port is used for the POW sensor and cant be switched to GPIO)
Prutsium
#16 Post by Prutsium » 15 Jun 2018, 10:32
TD-er wrote: 14 Jun 2018, 19:03 At this moment, if you want to split values from one plugin over multiple IDX, you have to use rules to do so.
Stupid of me as i had something simular but more simple for calculating DeltaT already on the ESP:
On Living_Radiator_In#Temp_3 do
TaskValueSet 7,1,[Living_Radiator_In#Temp_3]-[Living_Radiator_Out#Temp_4]
So now for the POW (R2) will be just a matter of creating 4 dummies and assign each one of them to a IDX.
And no timer is required in that case as it will update the value when the originating device has also a new value.
Will post the result later today.
Prutsium
#17 Post by Prutsium » 15 Jun 2018, 11:32
Prutsium wrote: 15 Jun 2018, 10:32
Ok noticed making dummies is more work so the result:
On POW_2_Sensors#POW_2_Voltage do
SendToHTTP 192.168.99.5,8080,/json.htm?type=command&param=udevice&idx=93&nvalue=0&svalue=[POW_2_Sensors#POW_2_Voltage] //Send the Voltage data to Domoticz
SendToHTTP 192.168.99.5,8080,/json.htm?type=command&param=udevice&idx=94&nvalue=0&svalue=[POW_2_Sensors#POW_2_Power] //Send the Watt data to Domoticz
SendToHTTP 192.168.99.5,8080,/json.htm?type=command&param=udevice&idx=95&nvalue=0&svalue=[POW_2_Sensors#POW_2_Current] //Send the Amp data to Domoticz
SendToHTTP 192.168.99.5,8080,/json.htm?type=command&param=udevice&idx=96&nvalue=0&svalue=[POW_2_Sensors#POW_2_Pulses] //Send the Usage data to Domoticz
Where the On POW_2_Sensors#POW_2_Voltage triggers the sending of the data instead of a timer.
All values come now in at Domoticz but have some issues with the Pulse sensor as it does not send an actual pulse but an incremental counter that resets itself after number xxx seems Domotics has some issues with it. Trying now in ESPEasy to divide the value by /1253 so Domoticz get the count as more handlable value. Not sure if it's the right thing to do will hook up the Aircon of 1KW for an hour to see if numbers are right.
That did not work correctly :( As its a looping counter it goes to 65355 and back to zero afterwards ....
Resulting in first stage nice increment but after it jumped back to 0 and so on ....
projectsun
#18 Post by projectsun » 15 Jun 2018, 22:37
Prutsium wrote: 15 Jun 2018, 10:26
But when I flash this hard_POW bin to my POW ver 2.0 (not R2), after flash complete nothing happens... no webif, no ping, no ESPEasy_0. After flashing a normal or dev bin, ping is there again.
What did I do wrong?
(Tested with 20180524_hard_SONOFF_POW, 20180606_hard_SONOFF_POW, 20180615_hard_SONOFF_POW) all the same. CSE7759 is present.
pa3gmi
#19 Post by pa3gmi » 18 Jun 2018, 14:42
I have the sonoff Pow and did a flasch with ESP_Easy_mega-20180524_hard_SONOFF_POW.bin. I can see the values on the device direct, but only the voltage in Domoticz, I do not understand the way to see all the values, here mentioned by Prutsium, please will You tell me more about that. I am not a programmer 70 years old but I want to learn always something.
#20 Post by TD-er » 18 Jun 2018, 21:19
Domoticz is a bit strange in processing data.
You have to deliver the data in the right format and order to match the pre-defined types.
If you want to graph them in separate charts, you have to split the values using rules.
Prutsium
#21 Post by Prutsium » 18 Jun 2018, 21:34
TD-er wrote: 18 Jun 2018, 21:19 Domoticz is a bit strange in processing data.
Like this rule:
Then you have to create the 4 Dummy's (dont forget to use the right IDX)
Only 1 problem stays: Domoticz cant working with an rotating counter (it sends pulses 0-65535 and returns to 0)
Still working on that one to figure out somehow ...... would be great if ESPEasy could handle that by dividing the pulses by 12530 (means 1KW) and stores this on the ESP so we can read out an actual value.
#22 Post by TD-er » 18 Jun 2018, 21:36
Support for the POW devices is still very beta (if not alpha), so all suggestions to improve are more than welcome.
Prutsium
#23 Post by Prutsium » 18 Jun 2018, 21:37
pa3gmi wrote: 18 Jun 2018, 14:42 Hi,
See my post above here.
Just make sure rules are active on the ESP and create the rule mentioned in the code above.
Change the IP and IDX to the right ones for your Domoticz.
In Domoticz create 4 Dummy sensors. The first 3 will work flawless the 4th (usage) i am still trying to figure out to get that one right.
Prutsium
#24 Post by Prutsium » 18 Jun 2018, 21:39
TD-er wrote: 18 Jun 2018, 21:36 Support for the POW devices is still very beta (if not alpha), so all suggestions to improve are more than welcome.
Then my suggestion: Store the real usage on the ESP memory somehow (i know writing in the flash sucks .....)
Not sure what other type of data Domoticz is accepting but other way could be not store every pulse but only the divided ones (12530)
#25 Post by TD-er » 18 Jun 2018, 21:57
I have these modules myself too, so I will install them in the next coming days I hope.
Then I can really see what's going on and I will think of some way to make them work fine.
The Sonoff POW build was meant to be the first build that's actually "plug-and-play", so there is a lot of the new build options used in that one and I plan to make some flexible complex default settings to try on that build.
The whole idea is to make builds for those Sonoff units that have a proper default setup.
But we're not there yet.
projectsun
#26 Post by projectsun » 18 Jun 2018, 23:04
Can somebody help me with this question?
#27 Post by TD-er » 18 Jun 2018, 23:56
Sounds like your model is one with an ESP8266 and maybe the one you tried to flash is an ESP8285?
pa3gmi
#28 Post by pa3gmi » 19 Jun 2018, 18:56
Thanks for answer, I have done as you say, but until now I can get only the Voltage readout. Is this script also sensitive for the name of the unit or somewhat else?
I have fill in my Domoticz IP and port address and made 3 virtual sensors note the IDX and fill in on the right place, what else can or must I do. Has the Device self an IDX?
Thanks for your patience
Prutsium
#29 Post by Prutsium » 19 Jun 2018, 20:59
pa3gmi wrote: 19 Jun 2018, 18:56 Thanks for answer, I have done as you say, but until now I can get only the Voltage readout. Is this script also sensitive for the name of the unit or somewhat else?
I assume you have connected it to 220V and there is some load connected to it?
(And the relay is switched on .....)
What version of ESPEasy are you using the POW one or the DEV that i mentioned before?
Did you also change the names from my example to yours? Please share a screenshot of the device tab like this:
In my case the RED and Blue are corresponding to the names in the script under rules.
pa3gmi
#30 Post by pa3gmi » 20 Jun 2018, 09:13
I have found some things that where wrong (the blue circle helps)and make them ok, now I see in Domoticz that there is contact to the ESP device my sensors are updated. But still only the voltage is coming in here.
This is the software version I have: The POW print is ver 2
Build 20102 - Mega
Libraries ESP82xx Core 2_4_1, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3
GIT version mega-20180615
Plugins 6 [Normal]
Build Md5 82bc2e38ccca02be1ce841c18b0b5
Md5 check passed.
Build time Jun 15 2018 02:17:36
Binary filename ESP_Easy_mega-20180615_hard_SONOFF_POW.bin
I see difference in the Device name, mine is : Energy (AC) - HLW8012 [TESTING]
Don’t know how to put a screenshot on this site.
In the mean time I have load the build from 19-Jun, but no difference.
This is the log output:
688892: EVENT: POW_2_Sensors#POW_2_Current =0.00
688911: EVENT: POW_2_Sensors#POW_2_Active Power=0.00
688931: EVENT: POW_2_Sensors#POW_2_Power Factor=0.00
694139: HLW8012: Read values - V=223 - A=0.00 - W=0 - Pf%=0
694143: EVENT: POW_2_Sensors#POW_2_Voltage=223.00
694152: ACT : SendToHTTP 192.168.178.49,8080,/json.htm?type=command¶m=udevice&idx=95&nvalue=0&svalue=223.00
694160: Command: sendtohttp
694205: ACT : SendToHTTP 192.168.178.49,8080,/json.htm?type=command¶m=udevice&idx=96&nvalue=0&svalue=
694213: Command: sendtohttp
694249: ACT : SendToHTTP 192.168.178.49,8080,/json.htm?type=command¶m=udevice&idx=97&nvalue=0&svalue=
694256: Command: sendtohttp
694318: EVENT: POW_2_Sensors#POW_2_Current =0.00
694338: EVENT: POW_2_Sensors#POW_2_Active Power=0.00
694359: EVENT: POW_2_Sensors#POW_2_Power Factor=0.00
698842: WD : Uptime 12 ConnectFailures 0 FreeMem 21696
Vastleggen in volledig scherm 20062018 85542.jpg (23.85 KiB) Viewed 57200 times
Thanks, Rien
#31 Post by grovkillen » 20 Jun 2018, 10:21
For screenshots, just add them using the attachments tab below the editing box. (To the right of the options tab)
Prutsium
#32 Post by Prutsium » 20 Jun 2018, 10:58
pa3gmi wrote: 20 Jun 2018, 09:13 This is the software version I have: The POW print is ver 2
Build 20102 - Mega
Rien,
Try the DEV version so not the POW i run the DEV version with the CSE and all works ok for me.
Prutsium
#33 Post by Prutsium » 20 Jun 2018, 11:03
Prutsium wrote: 20 Jun 2018, 10:58
Build 20102 - Mega
Rien,
( run actually this one: ESP_Easy_mega-20180606_dev_ESP8266_1024.bin )
pa3gmi
#34 Post by pa3gmi » 20 Jun 2018, 11:47
What do you mean with "the CSE"
Thanks anyway for the fast response.
Prutsium
#35 Post by Prutsium » 20 Jun 2018, 12:52
pa3gmi wrote: 20 Jun 2018, 11:47 What do you mean with "the CSE"
CSE7766 is the plugin designed for the POW R2 & S31 (Correct me if i am wrong)
pa3gmi
#36 Post by pa3gmi » 20 Jun 2018, 13:08
Hi is it possible that i have not the right POW version on the print is Ver 2.0 the measuring chip is HLW8012
With your configuration I have now no readings at all, so the measuring circuit seems not working.
Rien
Prutsium
#37 Post by Prutsium » 20 Jun 2018, 13:32
pa3gmi wrote: 20 Jun 2018, 13:08 Hi is it possible that i have not the right POW version on the print is Ver 2.0 the measuring chip is HLW8012
Rien
Looks like you have the POW V2,0 where i have the new POW R2: https://www.itead.cc/sonoff-pow-r2.html
As this topic was about the R2 i assumed you had the R2 and not the V2.0
pa3gmi
#38 Post by pa3gmi » 20 Jun 2018, 13:51
I have put theESP_Easy_mega-20180615_hard_SONOFF_POW.bin in the device and now it works, no idea what was the problem.
Thanks for all the help, I keep an eye on this site the teller is of course most interesting.
I see that the voltage measuring is about 10 volt to low, is there a way to correct this?
Rien.
Prutsium
#39 Post by Prutsium » 21 Jun 2018, 15:48
Btw ... this is how Domoticz handles right now the incoming data from the POW (R2)
Keep in mind i did not set any divider yet but its clear to see its not adding but just restarting the counter.
Would say this rather might be something to fix in Domoticz wil post same graph in Domoticz forum as maybe someone has a bright idea there.
( http://www.domoticz.com/forum/viewtopic ... 14&t=23878 )
Prutsium
#40 Post by Prutsium » 26 Jun 2018, 12:09
Update:
I Went to Tasmota for now as this does exactly what is required. It counts the usage internal and sends 2 values: Current Watt, Total Watt.
Might be an idea to look how its handled in Tasmota and implement similar in ESPEasy
The actual MQT message: 11:08:17 MQT: domoticz/in = {"idx":103,"nvalue":0,"svalue":"48;25.1","Battery":58,"RSSI":6}
sincze
#41 Post by sincze » 18 Aug 2018, 13:15
The following rules will allow the POW2 to report the data to domoticz. you create a Voltage, Amp, Watt, and Electric Counter (calculated) in domoticz as virtual devices. In addition you can add a virtual switch to toggle the relais_switch.
https://www.domoticz.com/forum/viewtopi ... 78#p187554
Devices 1: Energy (AC) - CSE7766 [TESTING] Energy
Devices 2: Switch input - Switch SW_1 GPIO-0
Devices 3: Switch input - Switch relais (idx 599) GPIO-12
Devices 4: Generic - System Info POW2_RSSI (idx 601)
Devices 5: Generic - Dummy Device Calculation
On System#Boot do
	TaskValueSet 5,1,0
	TaskValueSet 5,2,0
	TaskValueSet 5,3,0
EndOn
// LAMP CONTROLLING INCLUDING LED LIGHT
on lamp_on do
	gpio,12,1
	gpio,13,0
on lamp_off do
	gpio,12,0
	gpio,13,1
on SW_1#Switch do
	if [SW_1#Switch]=1
		gpio,12,1
		gpio,13,0
		gpio,12,0
		gpio,13,1
on Energy#Voltage do
	if Clock#Time=All,**:*0 do
		SendToHTTP 192.168.1.10,8080,/json.htm?type=command&param=udevice&idx=600&nvalue=0&svalue=[Energy#Voltage]
		SendToHTTP 192.168.1.10,8080,/json.htm?type=command&param=udevice&idx=608&nvalue=0&svalue=[Energy#Power]
		SendToHTTP 192.168.1.10,8080,/json.htm?type=command&param=udevice&idx=603&nvalue=0&svalue=[Energy#Power]
		SendToHTTP 192.168.1.10,8080,/json.htm?type=command&param=udevice&idx=604&nvalue=0&svalue=[Energy#Current]
	if [Energy#Voltage]!=[Calculation#Voltage]
		SendToHTTP 192.168.1.10,8080,/json.htm?type=command&param=udevice&idx=600&nvalue=0&svalue=[Energy#Voltage] // Voltage
		TaskValueSet 5,1,[Energy#Voltage]
	if [Energy#Power]!=[Calculation#Power]
		SendToHTTP 192.168.1.10,8080,/json.htm?type=command&param=udevice&idx=603&nvalue=0&svalue=[Energy#Power] // Calculated KwH.
		SendToHTTP 192.168.1.10,8080,/json.htm?type=command&param=udevice&idx=608&nvalue=0&svalue=[Energy#Power] // Watt only
		TaskValueSet 5,2,[Energy#Power]
	if [Energy#Current]!=[Calculation#Current]
		SendToHTTP 192.168.1.10,8080,/json.htm?type=command&param=udevice&idx=604&nvalue=0&svalue=[Energy#Current] // Amp
		TaskValueSet 5,3,[Energy#Current]
		TaskValueSet 5,4,[Energy#Pulses]
#42 Post by TD-er » 18 Aug 2018, 13:23
sincze wrote: 18 Aug 2018, 13:15 The following rules will allow the POW2 to report the data to domoticz. [...]
This should be at the wiki I guess.
sincze
#43 Post by sincze » 18 Aug 2018, 13:31
If it is good enough for the Wiki I can add it :lol:
#44 Post by TD-er » 18 Aug 2018, 16:45
sincze wrote: 18 Aug 2018, 13:31 If it is good enough for the Wiki I can add it :lol:
Well it is clear enough for me, so if I install my own, I know where to look for instructions, but since I am not that well organized I am sure it will take forever to find again :)
So please do add it to the wiki.
Djoe
#45 Post by Djoe » 27 Aug 2018, 09:35
@sincze which version of mega do you use?
I have try mega_20180826 and mega_20180719, both correctly show values from CSE7759, but http push from rules doesn't work...
This rules work fine:
On WIFI#RSSI do
SendToHTTP x.x.x.x,8080,/json.htm?type=command&param=udevice&idx=88&nvalue=0&svalue=[POW#Voltage]
Confirmed by logs:
Aug 26 21:32:56 POW EspEasy: SYS : -77.00
Aug 26 21:32:56 POW EspEasy: EVENT: WIFI#RSSI=-77.00
Aug 26 21:32:56 POW EspEasy: ACT : SendToHTTP x.x.x.x,8080,/json.htm?type=command&param=udevice&idx=88&nvalue=0&svalue=235.07
Aug 26 21:32:56 POW EspEasy: Command: sendtohttp
But this one is never triggered:
On POW#Current do
SendToHTTP x.x.x.x,8080,/json.htm?type=command&param=udevice&idx=89&nvalue=0&svalue=[POW#Power];[POW#Pulses]
SendToHTTP x.x.x.x,8080,/json.htm?type=command&param=udevice&idx=90&nvalue=0&svalue=[POW#Current]
Greetings from Tahiti!
sincze
#46 Post by sincze » 27 Aug 2018, 10:32
Djoe wrote: 27 Aug 2018, 09:35 Hi,
On WIFI#RSSI do
Confirmed by logs:
On POW#Current do
mmm strange indeed. ntp was enabled?? to have the timer work for you?
On System#Boot do
	TaskValueSet 5,1,0
	TaskValueSet 5,2,0
	TaskValueSet 5,3,0
EndOn
on lamp_on do
	gpio,12,1
	gpio,13,0
on lamp_off do
	gpio,12,0
	gpio,13,1
on SW_1#Switch do
	if [SW_1#Switch]=1
		gpio,12,1
		gpio,13,0
		gpio,12,0
		gpio,13,1
on Energy#Power do
		SendToHTTP x.x.x.x,8080,/json.htm?type=command&param=udevice&idx=11&nvalue=0&svalue=[Energy#Voltage]
		SendToHTTP x.x.x.x,8080,/json.htm?type=command&param=udevice&idx=18&nvalue=0&svalue=[Energy#Power]
		SendToHTTP x.x.x.x,8080,/json.htm?type=command&param=udevice&idx=13&nvalue=0&svalue=[Energy#Power]
		SendToHTTP x.x.x.x,8080,/json.htm?type=command&param=udevice&idx=14&nvalue=0&svalue=[Energy#Current]
		SendToHTTP x.x.x.x,8080,/json.htm?type=command&param=udevice&idx=1&nvalue=0&svalue=[Energy#Voltage] // Voltage
		SendToHTTP x.x.x.x,8080,/json.htm?type=command&param=udevice&idx=13&nvalue=0&svalue=[Energy#Power] // Calculated KwH.
		SendToHTTP x.x.x.x,8080,/json.htm?type=command&param=udevice&idx=18&nvalue=0&svalue=[Energy#Power] // Watt only
		SendToHTTP x.x.x.x,8080,/json.htm?type=command&param=udevice&idx=14&nvalue=0&svalue=[Energy#Current] // Amp
If you modify it like this??
it will now be triggered if the Power value changes.. not the voltage.
Should be okay to get the data into domoticz.
Please let me know.
Djoe
#47 Post by Djoe » 28 Aug 2018, 08:59
Thank you for your reply,
I don't use NTP (long time ago it was not stable and all is automated from domoticz).
But if you really want me to test with NTP I can do it (is there a link between NTP and a triggered property?)
I have tested again all properties as "trigger", here below the complete rules:
On Button#State do
 if [Relay#State]=1
  gpio,12,0
  gpio,12,1
On System#Boot do
 gpio,12,1
On WIFI#RSSI do
 SendToHTTP xxx,8080,/json.htm?type=command&param=udevice&idx=88&nvalue=0&svalue=[POW#Voltage]
On POW#Power do
 SendToHTTP xxx,8080,/json.htm?type=command&param=udevice&idx=89&nvalue=0&svalue=[POW#Power];[POW#Pulses]
 SendToHTTP xxx,8080,/json.htm?type=command&param=udevice&idx=90&nvalue=0&svalue=[POW#Current]
On POW#Current do
On POW#Voltage do
 SendToHTTP xxx,8080,/json.htm?type=command&param=udevice&idx=99&nvalue=0&svalue=test_vol
On POW#Pulses do
 SendToHTTP xxx,8080,/json.htm?type=command&param=udevice&idx=99&nvalue=0&svalue=test_pul
For information the "Pulses" property is configured with the formula : %value%/12530
There is no external sensor connected to this POW.
Here below the log (through syslog with "Info" level) :
Aug 27 20:46:09 POW EspEasy: SYS : -77.00
Aug 27 20:46:09 POW EspEasy: EVENT: WIFI#RSSI=-77.00
Aug 27 20:46:09 POW EspEasy: ACT : SendToHTTP 10.0.0.4,8080,/json.htm?type=command&param=udevice&idx=88&nvalue=0&svalue=232.76
Aug 27 20:46:09 POW EspEasy: Command: sendtohttp
Aug 27 20:46:09 POW EspEasy: SYS : 484.00
Aug 27 20:46:09 POW EspEasy: EVENT: SONOFF#Uptime=484.00
Aug 27 20:46:10 POW EspEasy: Domoticz: Sensortype: 1 idx: 83 values: 484.00
Aug 27 20:46:10 POW EspEasy: WD : Uptime 485 ConnectFailures 0 FreeMem 14560
Aug 27 20:46:39 POW EspEasy: WD : Uptime 485 ConnectFailures 0 FreeMem 14584
Aug 27 20:47:09 POW EspEasy: WD : Uptime 486 ConnectFailures 0 FreeMem 14512
Aug 27 20:47:39 POW EspEasy: WD : Uptime 486 ConnectFailures 0 FreeMem 14512
Aug 27 20:48:09 POW EspEasy: WD : Uptime 487 ConnectFailures 0 FreeMem 14512
Aug 27 20:48:39 POW EspEasy: WD : Uptime 487 ConnectFailures 0 FreeMem 14512
Aug 27 20:49:09 POW EspEasy: WD : Uptime 488 ConnectFailures 0 FreeMem 14512
I have switch on and off 3 times the light connected to the POW... The value are correctly shown on the POW:
Voltage: 232.76
Power: 18.11
Current: 0.13
Pulses: 9949.00
Have you compile your own binary for your POW or are you using a binary delivered by a release?
My POW R2 is written V1.0 on the PCB...
Thank you gain,
Mc/
sincze
#48 Post by sincze » 28 Aug 2018, 10:00
I use the following: mega-20180723. (Development)
Regarding NTP usage I once read somewhere it is needed to have the timer function trigger correctly.
However since then I enable it on all my devices. So not sure what happens if I disable it.
ManS-H
#49 Post by ManS-H » 28 Aug 2018, 11:32
I like the rules, but my question. Can i also used them for my first generation Sonoff Pow with the HLW8012? And if it's yes what must i change in the rules.
Djoe
#50 Post by Djoe » 28 Aug 2018, 11:46
I have upgraded the POW to mega-20180723 (dev), and it's not working better...
Very strange...
I'm going to continue to push CSE7759 data through the wifi#rssi trigger, but it's not a "realtime" push, so not very good for the appliance I would like to run....
I have another POW in a box, I will get it out tomorrow and I will try with this one...
I also use timer (without NTP) on a sonoff basic, like this :
On Rules#Timer=1 do
 timerSet,2,21600
It work:
Aug 26 16:00:02 Piscine EspEasy: Command: timerset
Aug 26 16:00:04 Piscine EspEasy: EVENT: Rules#Timer=1
Aug 26 16:00:04 Piscine EspEasy: ACT : timerSet,2,21600
Aug 26 16:00:04 Piscine EspEasy: Command: timerset
Aug 26 22:00:05 Piscine EspEasy: EVENT: Rules#Timer=2
Aug 26 22:00:05 Piscine EspEasy: ACT : timerSet,3,21600
Aug 26 22:00:05 Piscine EspEasy: Command: timerset
But if the number of second is to high (I don't remember the limit), I notice some strange behavior (next timer not triggered, or triggered in a shorter time).
Since I use "small" number, it's work perfectly...
sincze
#51 Post by sincze » 28 Aug 2018, 15:54
ManS-H wrote: 28 Aug 2018, 11:32 I like the rules, but my question. Can i also used them for my first generation Sonoff Pow with the HLW8012? And if it's yes what must i change in the rules.
I don't know for certain, could be if the data is populated in the same way,
The rules are in that way quite universal to use.
However as we can see in the forum. For some people they seem to work for others they don''t. Pretty strange.
Same goes for the timer. It can be used without ntp.
I use a similar setup for my NPN watermeter where I got the idea. That one also works flawless.
Djoe
#52 Post by Djoe » 29 Aug 2018, 10:10
I have try a second POW R2 I had.
I have exactly the same behavior : no SYS or EVENT log when a CSE7766 properties is changing (for instance Voltage).
I have activated NTP to be sure it's not due to this config.
And... always the same...
My first and second POW R2 have a similar behavior..
I really don't understand why, with your POW, you can trigger CSE7766 properties !
With mega-20180714 I have a new line in the syslog:
Aug 28 22:07:47 POW2 EspEasy: LoopStats: shortestLoop: 49 longestLoop: 891267 avgLoopDuration: 103.29 systemTimerDuration: 23.94 systemTimerCalls: 31 loopCounterMax: 612244 loopCounterLast: 286060 countFindPluginId: 0
Next time I will activate more debug level to try to understand a little bit better what is happening...
sincze
#53 Post by sincze » 29 Aug 2018, 11:15
Djoe wrote: 29 Aug 2018, 10:10 I have try a second POW R2 I had.
Let's sync both our debug settings to find out what happens okay?
Djoe
#54 Post by Djoe » 31 Aug 2018, 11:23
I think I have understood.
My gold was to work as a "push" system.
In my CSE settings, I have put 0 (zero) in "Interval" field.
I was thinking than a trigger was coming when a value is changing (like the "Generic system info" with the RSSI or UPTIME).
It was a mistake.
When I put for instance 10 (seconds) in this "Interval" field, I receive the events:
Aug 30 22:42:33 POW EspEasy: EVENT: POW#Voltage=233.91
Aug 30 22:42:33 POW EspEasy: EVENT: POW#Power=0.00
Aug 30 22:42:33 POW EspEasy: EVENT: POW#Current=0.00
Aug 30 22:42:33 POW EspEasy: EVENT: POW#Pulses=1.79
Aug 30 22:42:49 POW EspEasy: WD   : Uptime 80 ConnectFailures 0 FreeMem 14672
Aug 30 22:43:17 POW EspEasy: SYS  : -72.00
Aug 30 22:43:17 POW EspEasy: EVENT: WIFI#RSSI=-72.00
Aug 30 22:43:17 POW EspEasy: SYS  : 80.00
Aug 30 22:43:17 POW EspEasy: EVENT: SONOFF#Uptime=80.00
Aug 30 22:43:17 POW EspEasy:  Domoticz: Sensortype: 1 idx: 83 values: 80.00
Aug 30 22:43:19 POW EspEasy: WD   : Uptime 80 ConnectFailures 0 FreeMem 14672
Aug 30 22:43:33 POW EspEasy: EVENT: POW#Voltage=234.20
Aug 30 22:43:33 POW EspEasy: EVENT: POW#Power=0.00
Aug 30 22:43:33 POW EspEasy: EVENT: POW#Current=0.00
Aug 30 22:43:33 POW EspEasy: EVENT: POW#Pulses=1.79
It work like a "pull" system.
Every 10 second, I request the CSE chip to refresh all values.
So now I understand why you are using dummy device in your POW.
The goal is to store in the ESP the last value, to only send HTTP when a value is changing.
So you recreate a "push" system through a "pull" config in the ESP...
sincze
#55 Post by sincze » 01 Sep 2018, 15:44
Indeed I use Dummy devices to only send data to domoticz if something was changed
Could you try the following: DIVIDE AND CONQUER
Rules 1:
On System#Boot do
	TaskValueSet 5,1,0
	TaskValueSet 5,2,0
	TaskValueSet 5,3,0
	TaskValueSet 5,4,0
	TimerSet,1,30
EndOn
on Rules#Timer=1 do
	if [Calculation#Voltage]!=[Energy#Voltage]
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=600&nvalue=0&svalue=[Energy#Voltage] // Voltage
	if [Calculation#Power]!=[Energy#Power]
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=603&nvalue=0&svalue=[Energy#Power] // KwH.
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=608&nvalue=0&svalue=[Energy#Power] // Watt
	if [Calculation#Current]!=[Energy#Current]
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=604&nvalue=0&svalue=[Energy#Current] // Amp
	TimerSet,1,30
Rules 2
on lamp_on do
	gpio,12,1
	gpio,13,0
on lamp_off do
	gpio,12,0
	gpio,13,1
on SW_1#Switch do
	if [SW_1#Switch]=1
		gpio,12,1
		gpio,13,0
		gpio,12,0
		gpio,13,1
Rules 3
on Clock#Time=All,**:*0 do
That should give you the result you want. :D and leave the interval at 10 as you discovered.
Djoe
#56 Post by Djoe » 02 Sep 2018, 06:17
Yes now it's working, I have simplify the rules like this :
On Button#State do // To have the local button working for ON OFF
 if [Relay#State]=1
  gpio,12,0
  gpio,12,1
On System#Boot do // To have the relay ON after reboot
 gpio,12,1
On WIFI#RSSI do // To send voltage every 5 minutes
 SendToHTTP ip,8080,/json.htm?type=command&param=udevice&idx=88&nvalue=0&svalue=[POW#Voltage]
On POW#Current do // To send power and current only when the current change
 if [POW#Current]!=[LAST#Current]
  SendToHTTP ip,8080,/json.htm?type=command&param=udevice&idx=89&nvalue=0&svalue=[POW#Power]
  SendToHTTP ip,8080,/json.htm?type=command&param=udevice&idx=90&nvalue=0&svalue=[POW#Current]
  TaskValueSet 6,1,[POW#Power]
  TaskValueSet 6,2,[POW#Current]
I trigger the Current only and not the Power because the power is changing to mush time (to avoid a JSON push every 10 sec).
The interval on the WIFI device is 300 sec.
The interval on CSE device is 10 sec.
The only last issue is that my device is rebooting regularly.
Boot	Manual reboot (26)
Reset Reason	Hardware Watchdog
I think it's normal because the CSE code is in development / testing.
I have disabled it just now to see if the reboot continue or not for the next 48 hours.
I have never try to go in the code to debug the plugin..
I have download Visual Studio Code and PlaformIO plugin but when I load the source code I have some issue...
Have you try to go in the code to understand better how it work ?
Have a good week-end!
#57 Post by TD-er » 02 Sep 2018, 09:32
This hardware watchdog issue has been reported a lot by other users and for now I have not really a clue what is causing it.
sincze
#58 Post by sincze » 02 Sep 2018, 09:49
I did not see the HW watchdog.
Does it stop measuring and then reboot?
Or just reboot without any notice?
As a reboot results in a system that is -off- I should have noticed. :)
It is monitoring my stove. So not in use daily however switched on.
To avoid red bars in domoticz I push all data every 10 minutes at least. "":"0. Can of course be modified to every hour/day or so.
sincze
#59 Post by sincze » 02 Sep 2018, 12:56
Talk of the devil.. First hardware watchdog this morning at 11:46.
Would it be the 10 sec read-out?
Unfortunately the following does not switch the relais on after the reboot .. well after a reboot it switches on for 1 sec and then back off.
So maybe it starts with the rules from there.. Don't know yet.
 gpio,12,1
Same if I set the hardware GPIO to HIGH by default... it is the same result. On for 1 sec and then back off.
Djoe
#60 Post by Djoe » 05 Sep 2018, 09:06
@sincze
"well after a reboot it switches on for 1 sec and then back off"
I had a behavior like this a couple of week before, I have changed the mega version and the issue was solved.
Actually I'm testing mega-20180804 and the relay stay on after reboot.
@TD-er
The POW is my only device which have hardware watchdog.
I have try to disabled the CMS plugin : no better results.
I have deleted the CMS plugin in the device tab : no better results.
I have 2 other Sonoff Basic (with external sensors) + 1 Sonoff Touch (without external sensor) that reboot regularly (1000 to 4000 minutes uptime).
But there is no reference to a "Reset reason".. For instance:
Uptime 0 days 1 hours 38 minutes
Load 8% (LC=12409)
Free Mem 12896 (12112 - sendContentBlocking)
Boot Manual reboot (37)
I have only 1 Sonoff Basic (without external sensor) with a big uptime (more than 40000 minutes). The installed firmware is mega-20180503...
When I will have more time I will try to go in your code..... I hope it will not be a empty promise !
Users browsing this forum: Ahrefs [Bot] and 122 guests
