Weird issue: can't use more than 3 switches - WeMos D1 MiniPro
amigaroxx
#1 Post by amigaroxx » 11 Jun 2018, 22:14
Hi Guys,
This issue drove me bonkers this weekend. I really hope you can help.
It sounds so simple: I have 3 doors, so I have 3 (identical) door switches. All of them work. I added and configured the first 2 switches as devices with ease (GPIO 00 & GPIO 02). No problems there.
When I try to add the third switch as device, I won't work. I can add the device (same configuration as the first 2), but it does NOT register any switching (1 or 0). I picked GPIO 16, just to be sure the pin did not have multiple functions (since I'm a noob). No luck. So, the trial & error began: I tried all the other GPIO pins, without any luck. What do I miss?
No, the switch is definitely not broken. I switched it around with the others, and that worked. Except that the 3rd device wouldn't not register any switching.
I'm running R120, since I flashed it flash.cmd found on this website.
Thanks in advance!
papperone
Re: Weird issue: can't use more than 3 switches - WeMos D1 MiniPro
#2 Post by papperone » 12 Jun 2018, 06:53
I've even 8 switches on the same device perfectly working so that's defintely possible...
Try to switch to the latest build or at least to R148.
amigaroxx
#3 Post by amigaroxx » 12 Jun 2018, 22:10
papperone wrote: 12 Jun 2018, 06:53 I've even 8 switches on the same device perfectly working so that's defintely possible...
Where can I find R148? I can only find R147 RC8 on the website..... sooo... :oops:
papperone
#4 Post by papperone » 13 Jun 2018, 06:53
amigaroxx wrote: 12 Jun 2018, 22:10
go for R147 but you can try as well latest 2.0 build...
