Two BME280s on ESP8266 using ESP Easy
What do I need to do to connect to BME280s to the same ESP8266 using ESP Easy? I want to monitor temperature, humidity and pressure both inside and outside and would like to do this by using two BME280s and a single ESP8266. Is this possible?
Re: Two BME280s on ESP8266 using ESP Easy
I don't suppose you know who took the pictures of the plastic box/case used in these pictures?
Particularly where was it purchased from.
Yes it's my pictures Here's the box I got>>
@Grovkillen
Am I wrong or do these enclosures have a cable hole on top and bottom ?
Belgium and land of ESP ... counting
Not a cable hole per say but yes, holes. The plastic plug in the middle is to fixate the PCB inside the enclosure, not included with the enclosure.
- IMG_20180713_130557.jpg (2.1 MiB) Viewed 4199 times
- IMG_20180713_130605.jpg (2.07 MiB) Viewed 4199 times
Thank you.
I spent over an hour looking for similar cases on Aliexpress and couldn't find any as good value or suitable as this one.
