Problems with NodeMCU V3
Re: Problems with NodeMCU V3
everything checked. Windows restarted. same message. usb adapter broken? only have this.
The USB programer on the board you mean?
I found the problem!
I followed instructions as a beginner.
There was a USB TTL adapter recommended for flashing.
Flashing also worked. However, it did not work then.
Now directly connected via USB, everything works as described.
Thank you for your help!
Users browsing this forum: Google [Bot] and 102 guests
