I've flashed a sonoff 4CH with espeasy.
It has worked in the past.
I'e put my project on hold because i had no time to workon it.
Today,i'v restart the sonoff but saw that it didn't connect to domoticz.
I saw that there is a new wifi "sonof-0".
I connected to that wifi with sucess but i can't reach thepage @ 192.168.4.1.
I've try to flash it again without sucess.
esp easy netscan can't findit.
I had the same kind of issue in the past with a esp8266,grovkillen provided me a tool to flash with a blanc firmware.
Could you provide me the sames firmware for the Sonof 4Ch ?
Of any idea how to fix the sonof ?
Thanks in adavance.
SOnoff 4ch espeasy issue
Re: SOnoff 4ch espeasy issue
You need the 4mb blank bin file you mean?
yes, the blank file.
I was not sure wich one to use .
1Mb of 4Mb ?
if i'ts the 4Mb, i think a already have , will test it
1Mb of 4Mb ?
Of not it's here: 1+4MB_blank_bin.zip
The problem connecting to the web-gui are from MQTT connection problems (within my environment)
Wait 2-3 minutes and try again.
Connecting serial send & serial receive (RX&TX) while rebooting erase the config (starting with some FW-version i don't remember)
Flashing the 1MB file may work too. (but not for me)
I don't use MQTT
Flashing with the blanc firmware and flashing again fixed the sonoff.
Users browsing this forum: No registered users and 128 guests
